sharp lc-60le640u
+ More Options
Posts
  • Hornnumb2
    • Feb 2011
    • 214
    sharp lc-60le640u
    Working on this unit, I have check voltage to main board and are getting the 13 & 3 volts. I have check voltage to t con board and get 12v on first 2 and zero on last 2 pins. The unit does power on and has backlight but no Video or sound. I was just getting backlight but I have messed with ribbon cables on t con board and now I get some red lines on left side of screen.
  • Hornnumb2
    • Feb 2011
    • 214
    Re: sharp lc-60le640u
    Here are the boards.
    • Hornnumb2
      • Feb 2011
      • 214
      Replaced t-con for no change except to clear up the red line I caused, back to backlight but nothing else. I got some more reading from top of powerboard.
      1- 12.1v. PNL 12v
      3- -.009 GND
      5- 13.1v UR 13.2v
      7- 13.1v. UR 13.2v
      9- .010. GND
      11- .010. GND
      13- 3.31v. AC_DET
      15- 5.04v. BU 5v
      17- 1.15v. PWM1
      19- 1.3v. Dimmer
      21- 1.15v. OFL
      23- .000v. PWM2
      Any suggestions from that, I can check the readings on the bottom if needed. I am not sure about 17 and 23. Thanks
      • freakaftr8
        • Oct 2012
        • 3743
        Tcon is good. Panel is good. Sharp will fail if tcon cables are messed with while powered up. That's probably what happened. I suspect mainboard. Try heating up the mainboard with a hairdryer. probably bad bga under processor.
        • Hornnumb2
          • Feb 2011
          • 214
          Thanks for the advice, ordered a main board hope that fixes it.
          • Hornnumb2
            • Feb 2011
            • 214
            Well installed main board today with no change, I have a shop jimmy kit to rebuild power supply. I just know where to go from here. Thanks Michael
            • budwich
              • Jul 2015
              • 3097
              if you disconnect the tcon to panel cables, one at time (with power off), result do you get?
              • Hornnumb2
                • Feb 2011
                • 214
                White one side black the other and vice versa.
                  • 12206
                  • U.S.
                  Could try a firmware update/reapply.
                  • budwich
                    • Jul 2015
                    • 3097
                    somewhat expected (white).... is the white uniform when seen on both sides?
                    based on the card changes that you did so far, my guess would be a problem between the tcon and panel, potentially a smd component on the panel boards.
                    tracing the voltages from / at the tcon (labelled) and following those to the edge board might help.
                    • Hornnumb2
                      • Feb 2011
                      • 214
                      Hard to get a good pic of a white screen, but the look pretty close to same to me.
                      • Hornnumb2
                        • Feb 2011
                        • 214
                        I don’t know why it flipped one pic.
                        • budwich
                          • Jul 2015
                          • 3097
                          no problem... yes indeed they look ok. This appears to show that the panel itself is not a direct problem. However, some how the panel is not being driven.... either no signal or some operating voltage is not getting to the panel. Check the voltages on the tcon.
                          • Hornnumb2
                            • Feb 2011
                            • 214
                            Voltage going into t-con or out? I did measure the 4pin PL line and get 12v on first 2 and nothing on the other 2.
                              • 12206
                              • U.S.
                              See if you have voltage on each side of tcon fuse, negative meter lead on a ground.
                              • Hornnumb2
                                • Feb 2011
                                • 214
                                Not sure I can even do that with no screen display at all. I wouldn't think that would help considering the original board and replacement are doing the same thing.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  there should be a "multitude" of voltages labelled throughout the tcon... those are the ones that you need to measure / post.
                                  alas, you picture doesn't show any TPs unlike others... maybe the other side?
                                  • Hornnumb2
                                    • Feb 2011
                                    • 214
                                    Tp’s?
                                      • 12206
                                      • U.S.
                                      Well ok then supertech, if you can't you can't.
                                      • Hornnumb2
                                        • Feb 2011
                                        • 214
                                        I wasn't trying to be a smartass, I just didn't understand how I would be able to do an update without any screen display.
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • petersor
                                          Sharp RDENCA369WJQZ (Delta DPS-343AP A, Rev 01F) Power Supply Unit Schematic Needed
                                          by petersor
                                          Hi Folks,
                                          I'm filling some downtime trying to resurrect a Sharp LC60E88UN. It was easy to find the service manual online, but it doesn't contain the schematic for the power board (Sharp RDENCA369WJQZ / Delta DPS-343AP A, Rev 01F) Power Supply Unit. I've looked everywhere I can think of using both part numbers and can't find it. Can someonee with access to this document share it?
                                          Symptoms - no audio/video/backlight and blink code: 1 x power light followed by 1 x power and OPC lights together. Seems like a Lamp Error, but I'd like to check power supply components and...
                                          04-09-2020, 06:05 PM
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
