Sharp LC-70LE733U 1/1 won't turn on
  • capwizard
    • Jun 2016
    • 1991
    I've had a very bad experience with this kind of Sharp TV.
    I let customer know maybe it is the screen problem or it is the backlight problem it's not worth to repair so I charge $40 to check and reset the tv. And teach the customer how to reset the TV.
    Customer is a landscaper, hard worker. Let this Shap TV last a little bit longer then you go buy a new 4K TV. I said.
    My question is am I a chicken? I need to put food on the table. l don't have time to mess around with this TV. Am I right or wrong?
    • 12328
    • U.S.
    Re: Sharp LC-70LE733U 1/1 won't turn on
    Don't think I understand the question?
    • capwizard
      • Jun 2016
      • 1991
      Sharp LC-70LE733U 1/1 won't turn on when i press power, volume down and channel down TV works. I don't know how long TV will last. customer needs to keep on doing this for TV to work.
      i bail out the job.....I spend a lot of time on this kind of Sharp TVs and they never work right....all end up redo then give up....I never could fix one will last one year. i give up repair sharp tv.
      • budwich
        • Jul 2015
        • 3097
        Some of the codes don't really get you to a "pin point" of the problem, easily and fast which would result in a lot of time spent. Tough call, cause as you know from the forum, lots of these sets have been saved in various forms. Don't recall what the 1,1 flash code indicates.... But one thing to always check if you get the set to turn on and display, is to check the service menu and look at the counters / errors and go from there in determining best approach. Still further, sometimes zeroing the counters will get you out of the reset sequence for a while as things like "poor powering" could set the counter.
        • capwizard
          • Jun 2016
          • 1991
          Thank you. I will keep on contact with customer and update the status of the tv.
          Sharp LC-70LE733U won't turn on.
          after enter in Service mode press Ch down & Vol Down from LED back panel.
          Select 8/10 page by pressing up & down button from remote
          Select EEP , Press Ok button from remote
          EEP - will show running
          Switch off LED tv from main's and restart your LED tv will work properly.
          • capwizard
            • Jun 2016
            • 1991
            Update : I just had a courtesy phone call to Sharp 70" tv's customer. How's TV doing. he answered: the TV Worked faultless thank you for your service. But the I knew it in my heart if the electricity has an outage he needs reset this TV again.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              Some of these were too sensitive to backlight glitches. 1-1 is the backlight error code.
              They call me......."threadkiller"
              • thetonywarren
                Sharp 4P-B43EJ2U wont turn on
                by thetonywarren
                Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
                10-01-2025, 09:30 AM
              • JunkmanJimbo
                Sharp lc-55p6000u won't turn on
                by JunkmanJimbo
                Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
                09-28-2024, 12:56 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • Egidio85
                SHARP LC-40LE814E does not turn on 2 flashes
                by Egidio85
                hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                07-21-2023, 11:49 AM
              • Mitike
                SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                by Mitike
                Hello guys,
                I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                According to other sharp SM-s it is lamp error (I can't find SM for this model)
                And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                02-16-2020, 08:11 PM
