Samsung UN46ES6003FXZA panel question
  • DesertRat
    • Oct 2013
    • 81
    Hi Guys,
    Is this a heat stain or burn? I do have a horizontal line or box actually on the panel matching the height of this tab in the picture. Next question is, would this be repairable or is the panel toast?
    Thanks for your input.
    Edit:
    I think the second photo may answer the question. It looks like a burn mark on the top creating the horizontal issue.
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung UN46ES6003FXZA panel question
    of course, you can compare to others on the panel to confirm... but it would appear that the particular tab is bad.
    The set can be saved and provide an almost normal picture to most eyes by removing all of the tabs along that side that has the bad one. Lots of threads about removing tabs to save tvs. Read a few to get an idea of whats involved. The removal is a one time event as they can not be put back.
    • DesertRat
      • Oct 2013
      • 81
      Thank you budwich, I'll do some research here and see what I can find. That's a relief that it can be salvaged, even if it's only a one time event. It works fine otherwise, just that annoying block across the screen.
      • capwizard
        • Jun 2016
        • 1991
        The right way to fix this problem is to change the side tab which is easier than the one underneath the screen. Save this TV. in the future I will have articles how to change tabs by using DIY portable COF bounding machine.
        • DesertRat
          • Oct 2013
          • 81
          Although I appreciate what you're saying, I have a limited shop to work in. This TV belongs to a friend of mine and it's their primary TV, and the Superbowl is just around the corner! They need it fixed now, or word to get a new one.
          On that note, I am going to have to tell him that all attempts to repair this TV have failed. I did remove the tabs on the one side, gently removing them from the strip/panel. I put it back together, turned it on, and nothing but a blue screen that fades to white. No menu, no nothing, just blue then white. I've got to go give him the bad news.
          • capwizard
            • Jun 2016
            • 1991
            Oh my God! You did the same thing I had done it before. I hope you not remove all the side tabs at once.
              Originally posted by DesertRat
              Hi Guys,
              Edit:
              That IC is burnt, you try removing that tab since there is nothing to lose at this point.
              • DesertRat
                • Oct 2013
                • 81
                Thanks guys, for the help. Capwizard, I did remove the three tabs on the side at one time, instead of just the one as Budm suggests. My friend was very understanding and he's going to pick up a new TV tomorrow.
                That burn mark was there from the first time I went in to repair the leds (from the other thread on this same TV), I just didn't think too much about it at the time. I was focused on the led and power supply issues then. I'm sure I disturbed it in the process and only revealed the next problem he was going to have down the road, had I not disturbed it.
                  • 12323
                  • U.S.
                  Sounds like you did it right, wonder why it didn't work?
                  • DesertRat
                    • Oct 2013
                    • 81
                    Thank you nomoresonys, it's possible there could be something more going on inside the panel in a bad way. I did a test pattern and there was a pattern, but it looked like the wrong resolution, kind of like using 16 bit settings on your computer display instead of 32 bit. I tried a different main board, but still got the same resolution, even after a reset. So it may have been dying and I just helped it along.
                      Since that IC is damaged it may have taken out the IC's and power supply on the T-CON board that drive it.
                        • 12323
                        • U.S.
                        Good point budm, maybe it just needs a good tcon now?
                        • DesertRat
                          • Oct 2013
                          • 81
                          I tried a second tcon board after the removal, but got the same result. However, I can't say for sure that the second tcon board even worked, without any other issues. It was a used one and in unknown condition (only word of seller) at this point. It's worth a try, if I can find a "new other" type.
                          • DesertRat
                            • Oct 2013
                            • 81
                            Budm, thank you for the suggestion on the t-con. I had wondered about that myself, but I'm still learning. I appreciate all of your help and the other guys as well. I wasn't sure if there was any way it could have damaged something somewhere else in the system. But I did wonder after what nomoresonys said. I made sure there wasn't any residual material on the place where the tabs were removed. So why didn't it work for me too? Went through my head.
                            • budwich
                              • Jul 2015
                              • 3097
                              something is strange. Even on a fully working set, if you pull the tabs on one side, the set will function "normally".
                              What exactly did you remove. Can you post a picture of the thing you removed?
                              Further, did you check the other side tabs to see what they look like?
                              Still further, when one disconnects the tcon to panel cables (one side), that side would go white. You appear to indicate that the whole display is white (blue first).... this is strange. There is an issue somewhere else that wasn't not seen. In your case, if the tcon to panel cable is disconnect for the same side that you removed the tabs from, you are now likely to only see black because nothing will driving that side of the panel.
                              We probably should have ask for more picture of the display along with more testing beyond the "obvious" chip picture... :-(
                              • DesertRat
                                • Oct 2013
                                • 81
                                Budwich, a picture of removed is attached. I checked all 6 of them 3 on each side and the burnt one in the original post is the only one burnt (middle tab in picture), or showing even any small amount of heat. Note: the one with the torn portion, I made sure that all of it got removed, not just the larger portion in the picture.
                                The ones that connect to the buffer boards along the bottom all look good as well. No signs of overheating on any of them, or tears.
                                That is correct, if I turn the set on presently, I get a blue screen that slowly fades to all white. I cannot see anything on the screen indicating writing or a dialog box or anything. Just blue then white. I do hear the power up sound from the main board.
                                And don't worry about not having asked for more testing. I try to do a lot of research in the threads here before I ask a question. So I may have already done some of the testing you might ask, based on other threads. So don't worry about that part.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  :-( no problem... but there is still something strange.... or possibly different with a samsung panel maybe.
                                  BUT if you have more time, can you do a bit more testing / disconnecting cables?
                                  Can you disconnect the cable from the tcon to the panel for the side that you removed the tabs for... what happens to the display?
                                  • DesertRat
                                    • Oct 2013
                                    • 81
                                    I'll check this out and let you know the result. I've got some other things I want to check out too. Will let you know what, and how it turns out.
                                    • DesertRat
                                      • Oct 2013
                                      • 81
                                      Ok, with the ribbon cable disconnected on the t-con board for the missing tabs side, I get a black half screen on that side, with a blue/purple screen on the connected side. If I switch sides on connection with the missing tabs, I get a solid white screen. No indication of color but white.
                                      I did do some voltage testing on the t-con board and on (or near) the TP's there is a voltage reference for some but not all. In the picture I circled the one in question. On this TP I got a -6.31 volts instead of +11 as the reference suggests. The others matched closer to the references on the silkscreen. Is there anything else I can check on this board? I used a shopjimmy board instead of mine. I don't have a picture of the t-con board for the tv I'm working on. I don't see any brown spots or burnt components, so I just grabbed a shopjimmy pic. Hope that's ok.
                                      • DesertRat
                                        • Oct 2013
                                        • 81
                                        Here's the panel number:
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
