Fail in LED Output of Power Supply in LG 42LB5600
  • jfhojat
    jfh
    • Jan 2019
    • 7
    • ir
    Hi, I have LG 42LB5600 TV. When I power on without LED Strip, LED+ and LED- Voltage changing around 0 to 48 V just a few second but after about 4 sec it fixed to zero. I chassis LED- route and see 114 v diff in Drain of Q803 and LED+.
    I test Q803 Transistor and it seems OK. The Gate Voltage is Zero and the transistor is off. I Check D803 and every part to BD9486F (IC801) but the Dimout Pin has 0V. I cant find problem. Can anyone help me?
    Re: Fail in LED Output of Power Supply in LG 42LB5600
    Please report LED connector (connector in place) pin Voltage with ref to chassis GND.
    When making the measurement you need to leave the meter's probes in place then turn the TV on to see how high it jumps up to and then wait 10 seconds to see how low it goes down to.
    BTW, DRV-ON (BL-ON) control signal (>2.5VDC) is present when the TV is turned on, correct?
    You can also see the LED Voltage chart that shows the loaded Voltage.
    We also need to see the picture that shows how may wires there are on that LED connector.
    • jfhojat
      jfh
      • Jan 2019
      • 7
      • ir
      V(LED-)-V(GND)(Maximum in t=0~10s)= 0.2V
      V(LED+)-V(GND)(Maximum in t=0~10s)= 288V
      V(LED-)-V(GND)(t>10s)= 0.1V
      V(LED+)-V(GND)(t>10s)= 120V
      V(DRV-ON)-V(GND)=3.47V
      Voltage of output must be 208V,235mA.
      • R_J
        • 9624
        You have an open led string. The voltage goes high because there is no load (open led string) the circuit detects the open circuit and turns the boosted voltage off so it drops to 120v
          Originally posted by r_j
          you have an open led string. The voltage goes high because there is no load (open led string) the circuit detects the open circuit and turns the boosted voltage off so it drops to 120v
          +1
          • jfhojat
            jfh
            • Jan 2019
            • 7
            • ir
            Thanks.
            How can modify power board to reduce output voltage results no fail in new bought LED String in future؟
              LEDs' are driven by constant current source. You can modify the circuit by changing the value of the currents sensing resistor or look up spec. sheet of the LED driver IC to see if it has pin for current level setting to reduce the current or you can turn down the backlights level to about 50%
                • 12330
                • U.S.
                Not a difficult procedure, just need to locate the proper resistor/s to change out. https://www.youtube.com/watch?v=ogtfojsIZK8
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                • dragometin
                  Hitachi 40HYC42
                  by dragometin
                  TV Model: Hitachi 40HYC42
                  Power Supply: 17IPS71
                  MainBoard: 17MB95M
                  Panel: VES400UNDS-2D-NO3
                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                  Is there any variants on 17IPS71 power supply's?
                  UART output pins 10 and 12 on scart connector:
                  Code:
                  12:24:04.595
                  08-08-2024, 05:53 AM
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
