LG 55lk530-uc ford not turn on.
  • capwizard
    • Jun 2016
    • 1991
    Mistyping title does to ford...reality is cellphone or Google has changed automatically for me. Anyway. I did not pay attention to it.
    LG 55lk530-uc has red light and 3.3v STB voltage. Push power butten. Tv has 24v and inv-on(3.3v). But no ccfl backlight. Before I open the backlight how can I know it is the ccfl backlight problem. Can I test 55 inch tv only has two connectors with my cfl tester. I mean the cheap blue ccfl tester can drive all the ccfl lamps? And I couldn't find the tester.
    Ps. both ccfl driver board have no short.
  • CapLeaker
    Leaking Member
    • 8177
    Re: LG 55lk530-uc ford not turn on.
    What does the INV-ON pin say? If there isn't anything there, the backlights stay off. Maybe it doesn't get from the main board the command to turn on?
    • capwizard
      • Jun 2016
      • 1991
      I did double check the pin of inverter-on..when I push power button this pin went up to 3.3v then I push butten again tv will shuts off. Inv-on became 0v.
      • CapLeaker
        Leaking Member
        • 8177
        ...and you get nothing at all? Not even a 2 second to black? What about adim, pdim and err?
          • 12201
          • U.S.
          Try unplug cable from powerboard to mainboard, plug tv in turn on see if backlights come on and stay on.
            Fuses on Both master and Slave Inverter boards are good?
            You have Master/Slave inverter driver boards setup for push-pull lamps driving, so if Master is good but the Slave is bad then you will see backlights on the side where the Master inverter is come on up to the middle Horizontal of the screen for seconds.
            If the Master inverter driver circuit is good but output circuit is bad but the Slave inveter board is good then you will see the other half of the screen light up for seconds.
            So we need to know for sure if you even see 3-seconds to black or not and if the Dim and Error signals are OK or not.
            See page 42 for the topology being used.
            • capwizard
              • Jun 2016
              • 1991
              A-DIM, P-DIM #1 those make me confused, is that means Digital dimming and analog dimming. Why do they use this letter P for P-DIM #1 ?
              I will test later and let you know.
              • capwizard
                • Jun 2016
                • 1991
                I did check the fuses and bridged MOSFETs they are OK.
                can I test this tv backlight with CCFL tester?
                why i keep on asking this because the CCFL tester has been disassembled for scientific purpose research.
                  A-DIM = Analog dimming control.
                  P - DIM = PWM dimming control.
                  It will use one or the other but not both.
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
