Visio E5501-B2 no picture or sound
  • Rmasters3
    • Mar 2010
    • 126
    I've been given this set, the left front corner where the IR sensor board should be was broken and that board was missing. Replaced that board today and the LED light on the board lights with the remote, and remains lit. No picture or sound. If the Visio logo is supposed to light, it does not.
    Haven't had a chance to pull the back yet--but can some suggest what I should be looking for?
  • CapLeaker
    Leaking Member
    • 8351
    Re: Visio E5501-B2 no picture or sound
    probably an eeprom or a voltage regulator on the main board.
    • capwizard
      • Jun 2016
      • 1991
      You're a lucky man. It is the Vizio 056.04167.1071 Power Supply Board Cn202 connector has very bad solder joints. Resodler the cn202. Tv 99% will works. I've repaired 8 of them.
        https://www.shopjimmy.com/vizio/e550i-b2
        BTW, the correct model number is E550I-B2 (not 5501).
        • Rmasters3
          • Mar 2010
          • 126
          Thanks Gentlemen.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Remove the lead free solder and re-solder with leaded solder and it willbe good as new.
            • Rmasters3
              • Mar 2010
              • 126
              I want to be sure--we are talking about the power supply or main board? Thanks
                See this thread: https://www.badcaps.net/forum/showth...50I#post872360
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Its the connection between the power board and the led driver board. You can wiggle it and see it move.
                  • Rmasters3
                    • Mar 2010
                    • 126
                    Again, thanks. I'll be getting to this set in the next week and will advise.
                    • Rmasters3
                      • Mar 2010
                      • 126
                      Attached are pictures of the internals. Don't see a connector with soldered ends.
                        Did you read post 8 and go to the link?
                        • Rmasters3
                          • Mar 2010
                          • 126
                          Do I understand correctly that bridge connector between the two boards was replaced by the wires shown?
                          • CapLeaker
                            Leaking Member
                            • 8351
                            well... check em for cracked or cold solder joints on both boards. Just resolder them for now with fresh solder.
                            • Rmasters3
                              • Mar 2010
                              • 126
                              Thanks. Being a geezer, I am a lot more familiar with vacuum tube, hard wired stuff.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                The connection is on the back of this area.
                                • Rmasters3
                                  • Mar 2010
                                  • 126
                                  Resoldered those connections and it now works great. Thanks, gentlemen!
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    Can you find another one for me? and this TV is a smart TV.
                                    If you could consider a little bit donations and keep us going on...to badcaps here
                                    Any help will be appreciated.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      I've been offered a couple of these for free in the past, both picture and no sound. If someone offers me a free TV I try to tell them if I think its an easy fix. When I tell them I can generally fix one of these in 30min for $35 they just about soil their britches.
                                      I just sold one of these last weekend for $250.00 and three others for the same amount last year.
                                      Plastic gold these are
                                      They call me......."threadkiller"
                                      • Rmasters3
                                        • Mar 2010
                                        • 126
                                        And access to the boards is quick and easy. This last one was tossed by my neighbor but someone had broken the corner at the IR board, which I had to replace. I resoldered the connections (thanks again to the board members who made this so simple) and the set went to a good friend. He's my handyman and household fixer who has saved me big money over the years.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
