Samsung UN40H5203 Flashing Backlight
  • jason123
    • Oct 2015
    • 1068
    Happy holidays folks.
    I just got this Samsung with weird symptom. Powers up and the backlight flashes very bright at roughly 1 Hz. When I first got it, it flashed few times then stopped. When I opened up the panel, the majority of the LEDs where dead. I replaced them all put it back together and it's flashing again. I don't want to troubleshoot while flashing because the LEDs are ultra bright and will eventually die.
    Seems that the LED drive circuit doesn't have sufficient current limit?
    It's BN44-00769C power board. Has anyone seen this before? The backlight voltage at pin with LEDs disconnected is roughly 200 V and doesn't fluctuate with the LEDs disconnected.
    Re: Samsung UN40H5203 Flashing Backlight
    1) You indicated that the old LED's were dead, were they shorted out or open circuit?
    2) What LED's did you use for the replacement, spec?
    3) lift up one leg of the diode d9801? (next to blue disc cap C9842) in the LED driver section then check the resistance between the two legs of that diode in both directions, report the result.
    4) The LED's are connected in series and the LED power supply rating (printed on the board) is 151.8V @425mA with load, so 200V without load is correct.
    5) Provide the P/N of the LED driver SMD IC9805 on the bottom side of the board by the LED connector.
    • jason123
      • Oct 2015
      • 1068
      Hi budm
      Recall upon first few power ups, these were flashing, then eventually stopped. 2 strips had many shorted. the 3rd strip has several open.
      I use the 1W 3V LEDs (I've used them before on Samsung, very similar to the ones that were on the board, physically)
      One direction shows open (High Impdeance) and the other direction 4.62 MOhm
      Marking on the IC is 7014X
      • jason123
        • Oct 2015
        • 1068
        Anything else you can suggest looking into?
        • vinceroger69
          • Mar 2012
          • 6714
          maybe same as in this video disconnect pwm wire if your set is the same
          https://www.youtube.com/watch?v=sQn5QZ4SK80
          • jason123
            • Oct 2015
            • 1068
            Thanks. This TV is responsive to power button and the backlight flashes even if the main board is disconnected. I think it's LED strips or Power Supply. Maybe I used the 3V LEDs and I should have used the 6V instead?
            • vinceroger69
              • Mar 2012
              • 6714
              do samsung even use 6v leds i know lg do though whats the lcd panel number used in this set maybe then we can find the led specs
              • jason123
                • Oct 2015
                • 1068
                Here is the label on the panel.. not sure if it tells you the LED spec?
                  Were these your LED strips with 38 LED's total?
                  http://www.silvershoptvparts.com/sam...r-un40h5203af/
                  • jason123
                    • Oct 2015
                    • 1068
                    That's it eaxactly.. 12 leds center 13 top and 13 bottom.
                    • jason123
                      • Oct 2015
                      • 1068
                      You think its the LEDs that are causing the problem? All have been replaced and all light up. Would love to get this repaird asap. I ordered a ps board.. waste of money?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        3v leds would use 114v 6v leds 228v your power pcb states 151.8 v i hate issues with backlights i usually just replace the lot like you have and that fixes the issue maybe budm will have more ideas on what too check next
                        • jason123
                          • Oct 2015
                          • 1068
                          A new power supply board just arrived and it's doing exactly the same.. flashing backlight at 1 Hz or so... it's got to be the strings
                            Sounds like you have to get the LED strips out and wire them up out side the panel and hook up to the power supply board and see what is going on.
                            • jason123
                              • Oct 2015
                              • 1068
                              Just a quick update.. got a set of backlights from China ($38.00 + a couple of weeks) and it fired right up. All is good.. thank you
                                • 12192
                                • U.S.
                                So the first set of backlights you replaced were bad, were they new, if so could you share where you got them? wouldn't want to buy from them if they sell bad lights.
                                • jason123
                                  • Oct 2015
                                  • 1068
                                  No, the first set I installed where the original but with LEDs replaced.. They worked great outside the set with a tester.. so I'm not sure what was wrong with them.
                                    • 12192
                                    • U.S.
                                    Ok, I see, thanks, nice fix.
                                      May be you should try out the old set of LED powered by your power supply/LED driver board so you can see what is going on.
                                      LED tester only puts out 30mA so any bad connection, weak LED may not show problem until they driven by high current.
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        So my first step was to replace LEDS. Once i did, i tested with original power supply. They turned on blinking very bright. Got a new ps board. It did the same thing but i left the strings connected too ling while i was attempting to take measurements... eventually most leds shorted opened again...unfortunately unsalvageable at this point .. none related quick opinion.. up for sale for $20 is a samsung 50" 4k tv... any guess if this issue is fixable (color line and color bleeding on top)
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • ohren
                                          Samsung ue55nu7096u - no backlight - faulty LEDs?
                                          by ohren
                                          I'm looking at a Samsung model ue55nu7096u that I've only ever seen in a non-working condition, i.e. I don't know if the failure was progressive or instant.
                                          Symptoms
                                          No backlight at all — LCD and logic board are working normally. Resetting all settings and installing system updates has no effect.
                                          I tried reseating the connectors between PS and logic board, and PS and panel. No difference there.
                                          I could not find a service manual.
                                          Measurements when powered on
                                          Bulk cap: 388 V. Stable....
                                          04-04-2022, 02:58 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
