Philips 42PFL9732D slow startup
  • tiltkoko
    • Mar 2011
    • 26
    • Norway
    Hi.
    My Philips TV is very slow to turn on. When I first try to turn it on the light turns to blue (on) with no picture. I hear several double clicks (relay?), and after a few minutes it goes back to standby. If I try to turn it on again it usually works and I get picture etc.
    It has gotten a little harder and slower to turn on lately so I figured it was time to try to fix it now. So I opend it up hoping it was just some obviously bad caps to replace, but I did not find any..
    So whats going on? Where should I look now?
    The only thing I could see possibly wrong on the board was the dark area on the picture.
    Power board: 313 61714
  • R_J
    • 9535
    Re: Philips 42PFL9732D slow startup
    That dark area is just due to heat over the yeras that discolored the board, give some pictures of the complete board, Also have you checked any voltages? they could be labled near the connectors.
    It is likely a weak cap and could be one of the small ones that will look ok but bust be checked with a esr meter.
    Start by removing the board and check for poor solder connetcions on the board, especially where the heat is around those transistors, also check any connections to the transformers and parts mounted to heatsinks
    • tiltkoko
      • Mar 2011
      • 26
      • Norway
      Back home..
      Removed one 1000uf 25v cap. Measured 904uf, ESR: 0.31, Vloss 1.6%
      Most of the caps on the board is rubycon and nichicon, but this was a lelon.
      Could this be the bad cap?
      Going to replace it with a Panasonic FM.
      • tiltkoko
        • Mar 2011
        • 26
        • Norway
        So I removed a 50v 10uf lelon cap next. It measured an ESR of 6.3!
        I have a 50v 22uf FM. That is an ok replacement?
        • R_J
          • 9535
          It depends on where it is in the circuit, it will likely be ok
          • tiltkoko
            • Mar 2011
            • 26
            • Norway
            Still same problem after replacing some small caps.
            Circled the relay that's clicking when TV is trying to start.
            Found a PDF with some diagrams etc.
            https://mega.nz/#!bRFhzIZZ!7S2X77zwl...4mw_FoDsimmNyc (too big to upload) Diagrams from pg. 58
            Could it be the relay that is going bad, or some other component?
            Tried to touch up some solder joints etc too, but no change.
            The solder pads is breaking off super easy, but easy to follow the traces with a flashlight from the back side.
            Remember I had a technician here many years ago replacing the inverter boards under warranty. Opend and looked at the slave one that's easy to get to and caps looked fine etc, Rev 1.3 board.
            • R_J
              • 9535
              Do you have a stable +5V2 standby voltage? Looks like the standby supply is on the main board
              • tiltkoko
                • Mar 2011
                • 26
                • Norway
                TV wont go into stanby now. When I put in the power cord it goes directly into blue light. It starts clicking and after a few minutes it goes completely off with no light, so that's new.
                Measured 5V2 and 12V on 1P11 and they where stable and good.
                • tiltkoko
                  • Mar 2011
                  • 26
                  • Norway
                  Tried some more, and got some error code blinking. 5 long red and 3 short.
                  That mans: PNX 8535 doesn't boot (SW cause) from the manual.
                  Could it be that the problem is on the other main board?
                  7 lelon caps on the board. The big one is maybe a little suspect, can feel a tiny bit of bulging. I have ordered replacement 450v 68uf.
                  • R_J
                    • 9535
                    Those caps will show a bit of a dome due to the plastic disc on top, you can usually press it and if it goes down it will be ok. I doubt it would cause your problem.
                    • tiltkoko
                      • Mar 2011
                      • 26
                      • Norway
                      The voltage I have tested on the power board looks good, error code seems to link to the PNX8535 on the other board. So why not?
                      After pushing a bit on the top of the 450v cap I am even more sure I feel a bulge. It seems the board gets AC from the power board via 1P02 as far as I understand.
                      • tiltkoko
                        • Mar 2011
                        • 26
                        • Norway
                        Changed out all the caps on input board, it helped a tiny bit.
                        Noticed that the transformer circled is making noise. After the relay clicks on and off the sound goes up and down, else is a constant buzz.
                        What should I do next? ..
                        • CapLeaker
                          Leaking Member
                          • 8153
                          is there a time difference in starting, if the tv is cold versus when the TV is warm?
                          • tiltkoko
                            • Mar 2011
                            • 26
                            • Norway
                            It works 100% if warm. Only cold start from standby or completely off takes ages with relay clicking etc.
                            After changing out caps I get picture after fewer relay clicks, but it turns on with some static on half the screen and then relay clicks off and on a few more times before it works.
                            • CapLeaker
                              Leaking Member
                              • 8153
                              is the same true, if you warm the board up with a hair dryer, then turn it on? I'd say you problem is probably with the smaller caps.
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                smaller capacitors generally dry out first .
                                • tiltkoko
                                  • Mar 2011
                                  • 26
                                  • Norway
                                  changed out all of the caps on the input board and all of the lelon caps on power board. All caps on both boards are now high quality japan caps.
                                  They did not measure terrible, worst was ca 15% off in capacitance
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    pre heat parts of the boards until it comes on properly ..repeat as can be misleading . then if that worked home in with freeze spray ....
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • tuner2000i
                                      Philips 65PUS8518/12 distorted image after main board replacement
                                      by tuner2000i
                                      hello everyone,
                                      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                      07-15-2025, 01:15 PM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • spantor
                                      Activate power board Philips 40PFH40009/88 tv
                                      by spantor
                                      Hello partners.
                                      Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                      The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                      02-11-2024, 05:07 PM
