Lg49uj6200ua
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Lg49uj6200ua
    I have never heard of Skyworth. I take it that it is a lesser quality set?
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      Re: Lg49uj6200ua
      Standby voltage on the main PFC Caps is 162.5 Volts.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Lg49uj6200ua
        Here are pics of both sides of smps.
        LJ
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Re: Lg49uj6200ua
          Better picture of back
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Lg49uj6200ua Better Picture of back of SMPS
            I am sorry for the poor quality picture..I think this one is much easier on the eyes.
              Re: Lg49uj6200ua
              "Two main boards exhibit same behavior. A third main board would sometimes go into menu and even display PIP video and sound in menu on input selection screen. When input selected (HDMI) only audio came through, no display on full screen, this board took software update."
              It looks like you do have main board problem, especially not all of them acting the same way.
              "LED Outputs are both 64.75 steady instead of 66 volts." BL-ON is OK otherwise you will not get the LED Voltage.
              BTW, on the LED connector, what are the Voltages on each one of the pin with ref. to GND? The 64.5V is ref. to GND?
                • 12274
                • U.S.
                #27
                Re: Lg49uj6200ua
                So if I read it right, you never get a good inverter on signal?
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Re: Lg49uj6200ua
                  __________________
                  Yes Sir Bud. 64.75V to chassis. I can check them to the corresponding GND terminal on the same connector. Will do so and post.
                  INVON is 1.84V and I do get backlight.
                  So far both mains supposedly came from sets damaged in shipping yet they claim they are tested good. If they power up a set with a cracked panel, can it damage the main board?
                  My source for main board CPU replacement says no parts are available to repair the original main board.
                  Thanks to all for your assistance!! I appreciate it!
                  LJ
                    • 12274
                    • U.S.
                    #29
                    Re: Lg49uj6200ua
                    Did you try this: To reset settings, press and hold down the OK button on the TV panel for 10 seconds.
                      • 12274
                      • U.S.
                      #30
                      Re: Lg49uj6200ua
                      Another thing to try, with tv powered on unplug power cord from wall, wait 1 minute plug back in.
                        • 12274
                        • U.S.
                        #31
                        Re: Lg49uj6200ua
                        What is hooked up to tv? when I test I just use an antenna, sometimes a bad cable box can cause problems.
                          • 12274
                          • U.S.
                          #32
                          Re: Lg49uj6200ua
                          HOLD DOWN the power button on tv and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
                          • ljintexas
                            LJinTexas
                            • Jan 2015
                            • 669
                            Re: Lg49uj6200ua
                            I will try that Nomoresonys!!
                              • 12274
                              • U.S.
                              #34
                              Re: Lg49uj6200ua
                              A mysterious issue for sure.
                                • 12274
                                • U.S.
                                #35
                                Re: Lg49uj6200ua
                                Was just reading a case where the tcon was the issue on a tv that shut off shortly after turning on.
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  Re: Lg49uj6200ua
                                  If it were the tcon, I would not get LG splash screen and setup menu for language and time zone.
                                  • ljintexas
                                    LJinTexas
                                    • Jan 2015
                                    • 669
                                    Re: Lg49uj6200ua
                                    In answer to your question Bud, if I test LED+ to LED- I get 63.95 volts. If I check LED+ to PFC Main Cap -, I get 112 volts.
                                    I am convinced that the CPU on this main board has only base rudimentary firmware on it or has a physical problem.. If I plug a USB drive into it, it will read the drive, but will not ask me if I want to update. If I boot cold with USB drive in, it will read it, but still not ask me if I want to update.
                                      Re: Lg49uj6200ua
                                      "In answer to your question Bud, if I test LED+ to LED- I get 63.95 volts. If I check LED+ to PFC Main Cap -, I get 112 volts."
                                      When testing the LED connector Voltgaes you will test the LED connector pins against cold/chassis GND.
                                      • ljintexas
                                        LJinTexas
                                        • Jan 2015
                                        • 669
                                        Re: Lg49uj6200ua
                                        Then 64.75 V is the answer.
                                        Thanks!
                                        LJ
                                          Re: Lg49uj6200ua
                                          At this point you need to get known working main board.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • smic717394
                                            by smic717394
                                            07-25-2024, 10:16 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • hervou
                                            Philips PSU (715G7350-P01-000-002S) behaving funny
                                            by hervou
                                            I'm becoming crazy trying to fix the Philips TV of my old man (model 43PUS6201/12 - the TV, not my dad). I've read again and again discussions about this and similar TV models, on badcaps (thanks so much !). I see no other option than asking for your help.
                                            The symptom is simple : when I plug the power cord, the red "stand-by" LED does not light on anymore, and the TV powers-on neither with the remote control nor with the rear button. I guess at this point you immediately think at the 5V (or other voltage depending on the hardware) stand-by output......
                                            04-20-2024, 02:56 PM
