UN55B8000XF No Backlights/Picture on (only sound)
  • icekillah
    • May 2014
    • 55
    I got a UN55B8000XF Samsung That is not Showing an image on screen nor does it have backlights.
    When the tv is turned on i get the "Samsung" chime and can get audio via HDMI, also the red optical audio light does turn on, and the Standby light stays on and will take commands from the remote control. But no Backlights and No Image displayed(checked with flashlight). Disconnecting the TCON makes no difference. I have suspected the mainboard because when the mainboard is disconnected from the PSU the Backlights DO turn on. There is a repair kit for this PSU that has similar symptoms but not exactly the same. I have checked the output voltages from the PSU and can post all of them. Now for pin 1 the "Power On/Off" i only get .81 volts when the TV is on and of course 0 when its off. Is this normal? To me it seems to be low. Also get 12v on the Tcon fuses. It would be nice to know a testable Point of Failure, any ideas?
    Re: UN55B8000XF No Backlights/Picture on (only sound)
    "when the mainboard is disconnected from the PSU the Backlights DO turn on" That means the power supply, LED drivers, LED strings are OK.
    PWR-ON/OFF (PS-ON) >2.5V (typ.) = on, <1V = off
    How about BL-ON and Dim control signal level?
    So far it looks to be main board problem.
    You should upload the pictures of the whole back side of the TV showing all the boards.
    • icekillah
      • May 2014
      • 55
      Sorry it took me so long to reply I wanted to be thourough on these voltage readings. Please see pics. 0v for BL_ON when mainboard is plugged in and 2.9v when the mainboard is disconnected. 0.5v for p-dim when the mainboard is plugged in and 4.1v when the mainboard is disconnected. I was able to get the service manual and still have some stuff to try. Some of the DC regulators/transistors have unusual makings that I cannot lookup (see pic, are the pin layouts usually the same on this transistor?). I'll take it since there is 5v on the mainboard there is suppose to be a 5v to 3.3v regulator that is not doing it's job? No IC's on this mainboard really get hot, bga a bit but that is probably normal. Any other ideas to try?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK. So you do have a Main Bd. issue. Are you going to replace the main Bd.? or are you going to try and fix??
        • icekillah
          • May 2014
          • 55
          I would like to repair the mainboard, some of the DC regulators are on the back which will make voltage checks difficult to take. Would it be possible to check them via diode mode, with the mainboard removed from the TV? I am confident in my smd soldering skills, and this mainboard is very difficult to find online. I would upload the service manual for this TV but I am sure that would be against forum rules.
          • icekillah
            • May 2014
            • 55
            Re: UN55B8000XF No Backlights/Picture, (only sound)
            ok I am going to pull the main board out to test the regulators on the back, it looks like I am not getting 3.3v. I am going to use the 5v stby, the 5v stby(ground) from the psu. Do I also need to ground the main board to the chassis/panel? Am I missing anything?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I would be happy if you could upload the SM. It is not against forum rules. As for the 5V, I use a 9V battery with a 7805 regulator to power the Main Bd. and solder the battery Neg (-) to the GND on the Main Bd itself.
              • icekillah
                • May 2014
                • 55
                Sorry it took me so long to reply i had to go out of the country, but now am back and ready to work on this tv again. I tried to upload the pdf service manual but it was too large at 58MB, here is the download link:
                That is a nice trick for a steady 5V supply i guess the next step is to work backwards from the mainboard to psu connector and try to find my mainboard's 3.3v power rail? or should i just start by checking the MOSFETS/DC Regulators for 3.3 on their outputs? Where would you start?
                  • 12115
                  • U.S.
                  Theres a mainboard here BUT I'm not sure if its a match, it is on the shopjimmy substitute board list, will give both links. https://www.ebay.com/itm/Samsung-UN4...31n:rk:24:pf:0
                    • 12115
                    • U.S.
                    https://www.shopjimmy.com/samsung-bn...b8000xfxza.htm
                    • icekillah
                      • May 2014
                      • 55
                      That is very interesting, according to shopjimmy the following boards are Substitute Parts:
                      BN94-02640A
                      BN94-02640B
                      BN94-02640M
                      BN94-02640C
                      BN94-02640D
                      BN94-02640E
                      BN94-02640F
                      BN94-02640K
                      BN94-02640L
                      BN94-02979J
                      BN94-02640N
                      BN94-02640P
                      BN94-02640Q
                      BN94-02640R
                      BN94-02640S
                      BN94-02640T
                      BN94-02640U
                      BN94-02640V
                      BN94-02640W
                      BN94-02661E
                      BN94-02661F
                      BN94-02661J
                      BN94-02787C
                      BN94-02787D
                      BN94-02787E
                      BN94-02979A
                      BN94-02979B
                      BN94-02979C
                      BN94-02979D
                      BN94-02979E
                      BN94-02979F
                      BN94-02979G
                      BN94-02979H
                      BN94-02979K
                      BN94-02979L
                      BN94-02979M
                      Has anybody tried a mainboard swap from a 46" into a 55" ?
                      I still prefer repairing my current mainboard, but its always good to have a plan B. I'll be able to get to it tomorrow. Now if I find a short to ground on this power rail what voltage and amperage should i set my Adjustable Power Supply to? I know low volts and high amps (would 2 volts be too much? amperage cranked to full?)
                      • icekillah
                        • May 2014
                        • 55
                        OMG nomoresonys i ordered your ebay link for a 46 mainboard that was on shopjimmy's list and..... It worked! Thank you I would have never trusted shopjimmy's list. Good for Samsung making interchangeable parts, a long time coming. I do have to use a different Samsung remote control but worth it. I am still going to try and figure out what happened with the original mainboard but for now the set is up and running with no issues at all. Thanks again
                          • 12115
                          • U.S.
                          Glad it worked out.
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • stinger
                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                            by stinger
                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                            04-17-2024, 03:06 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • EazyBone
                            Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
                            by EazyBone
                            Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
                            Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
                            Now what exactly do I need to do in order to attempt to fix this issue?
                            do I have to take each one...
                            12-24-2023, 06:59 PM
                          • lapse
                            TCL 40S325-CA backlights, sound, no picture
                            by lapse
                            Hello, another TV found on the sidewalk here.
                            I have a TCL 40S325-CA ROKU LED TV. The backlights turn on, I can hear the typical Roku click sound when pressing the power button (no remote unfortunately) but nothing is displayed on the screen.
                            Power supply:
                            Main board goes into standby, so no reason to suspect anything here. Backlights turn on, etc..
                            Driver boards:
                            I have 12V going on both sides of the fuse on the panel driver boards.
                            VGH and VGL are around 1V when powered on.
                            No shorts to GND on any of the...
                            06-30-2022, 10:15 PM
