Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
    Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
    Now what exactly do I need to do in order to attempt to fix this issue?
    do I have to take each one off until the short is stopped? I would assume you test each ones resistance once off. Is there an easier way.
    Never actually found a short before on a panel so guidance would be appreciated. Or any experience with this
  • nomoresonys
    • 12274
    • U.S.
    Sometimes you can luck out and see a hairline crack on cap, look with magnifier if you can, there's some other ways but removing one at a time is not really that hard.
    • EazyBone
      • Jun 2023
      • 1353
      • United states
      I found the shorted cap, first one. Replaced it and no more short. Short was gone before I replaced it also just from the pads. Yet no dice. No picture still. Same caps only getting .013v along the whole line.
      • EazyBone
        • Jun 2023
        • 1353
        • United states
        This chip getting voltages of
        Top left down
        .006 (where the number 5 is)
        .006
        .533 fluctuating to .719 and back down repeatedly
        .367 fluctuating to .552and back down.
        Top right down
        Ground 0
        .181
        .295 fluctuating.384
        3.324 fluctuating very slightly 3.327
        All fluctuating is about every 1 seconds goes back and forth.
        any other suggestions or knowledge
        • stinger
          Samsung UN70TU6980FXZA no sound no picture but does have backlights
          by stinger
          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
          04-17-2024, 03:06 PM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
