Hitachi 50HYT62U Backlight brief flash
  • mutts
    • Jun 2018
    • 11
    Hi repairers I have a confusing one (for me).
    A friend has asked me to repair his 2 year old tv, is this a led driver fault?...
    Tv boots normally but no backlights other than a very brief flash. Tested with GJ2C tester all leds come on at 186v. During boot get 162v at connector, brief flash from backlight as voltage slowly rises to 236v, if the set is left on this drops to around 60v over the next 5 minutes.
    All diodes test ok, all capacity and esr of caps is good, lcd panel is unmarked and menu etc can be viewed with a flashlight. Psu is a Vestel 17IPS20, set has done 12.5k hours.
    I'm thinking that regardless of having 2.6v at each of the backlights 63 leds during boot the current is not enough.. and then the climbing voltage?? it's got me.
    If anyone more knowledgeable has any ideas I would be most grateful.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Hitachi 50HYT62U Backlight brief flash
    I still suspect bad backlight LEDs. From what I gather the LED Driver seems to be working.
    • mutts
      • Jun 2018
      • 11
      Yes that would make sense. I probably missed one or more when checking with the lcd still attached.
      Many thanks.
      • zomi
        • Nov 2011
        • 512
        https://tinyurl.com/yc4accjm
        these should be the strips for yours
        • mutts
          • Jun 2018
          • 11
          Thanks zomi, perfect.
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Did you strip the whole screen down and check all the led strips?
            Or just test them from the connector that connects with the power supply?
            • mutts
              • Jun 2018
              • 11
              They were just tested from the connector, stripping a large panel apart wasn't an option at friends house.
              • ducky29
                • Dec 2015
                • 369
                • Europe
                Well sometimes only few of the leds lit up and give you the illusion that the whole strip works.
                • budwich
                  • Jul 2015
                  • 3097
                  did you try unplugging the strings and then checking the initial open circuit voltage to see where it gets to?
                  • mutts
                    • Jun 2018
                    • 11
                    Yes, iirc it was around 80v.
                    • GAStuntman
                      • Dec 2017
                      • 65
                      Did you figure out the issue? I’m having the same problem with my tv. I opened it up & tested the LEDs & they all worked using the LED tester. I reassemble the tv & once the power button is pressed the LEDs flash and go back out. I have replaced the power supply board & the LED driver board.
                        Originally posted by GAStuntman
                        Did you figure out the issue? I'm having the same problem with my tv. I opened it up & tested the LEDs & they all worked using the LED tester. I reassemble the tv & once the power button is pressed the LEDs flash and go back out. I have replaced the power supply board & the LED driver board.
                        Did you use the LED tester to test the whole LED string from the LED connector side? What Voltage does it show on the LED tester?
                        • GAStuntman
                          • Dec 2017
                          • 65
                          I tested the LEDs all the voltage was good & all the LEDs did light up with the tester. I don’t remember the exact voltage reading on the LEDs. Normally with LEDs you can shine a flashlight into the screen and see the image. In my case that didn’t work. Like I stated before I have already taken the tv apart and tested the LEDs and they all worked. I’m thinking there maybe a shortage somewhere or something else is causing the tv to shut off the LEDs as a safety precaution.
                            LED tester only puts out 30mA compared to about 300 ~ 400mA when driven by the TV LED driver circuit. I do have LED tester that I use as a guide but not for 100% verification of the condition of the LED's. Bad LED will fail when driven at high current.
                            You can disconnect the LED connector from the power supply board and use your tester to light up the LED string and verify for sure if you do not have any image on the screen or not, if not then check the fuse on the T-CON board and see if you do have 12VDC at both ends of the fuse with ref. to chassis GND.
                            • GAStuntman
                              • Dec 2017
                              • 65
                              Thanks, I took the tv back apart & found one burnt LED. Replacing the bad LED fixed the issue.
                              • triplefour
                                TCL 75S421 has sound but no backlight not even a flash
                                by triplefour
                                TCL 75S421
                                PSU BOARD: 40-L402H8-PWD1CG
                                it shows not even a flash of backlight when powering up.
                                but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                with mb connected, PSON...
                                11-17-2023, 09:54 PM
                              • Superbee_dad
                                Sharp 80” long short flash backlight error - Help
                                by Superbee_dad
                                Hello Sharp TV experts
                                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                01-24-2025, 11:51 PM
                              • ekozeko333
                                by ekozeko333
                                🧠 What I’ve Done So Far
                                Flashed...
                                06-21-2025, 02:48 AM
                              • corrize
                                Nikon D800 camera - flash don’t work and capacitor don’t charge
                                by corrize
                                Hello, I'm stuck in troubleshooting…
                                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                10-01-2022, 10:02 AM
                              • DanPoka
                                by DanPoka
                                02-15-2025, 05:05 AM
