My Sony LED TV KDL46EX525 has white screen
  • saud52
    • Aug 2015
    • 24
    • Bosnia and Herzegowina
    My Sony LED TV : KDL46EX525 has white screen with top left TMP = 29 and top right TIM = 0. I can do what I want, press any key, wait after switching off, I keep coming back to the white screen. If I take the power and wait 60 s, comes first briefly the last set channel (with a bit too bright picture) and then the white screen again. Please see photo in attashment. I tried to do a factory reset, but it can not .Does my LED TV Sony have the software problem? How will I get out of this? For the recovery software and the manual, I would be really grateful.
    Request for quick help!
    Re: My Sony LED TV KDL46EX525 has white screen
    What is the history of the TV? Someone tries to update FW, software, etc?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Firmware is a good suggestion. However, I was thinking T-CON Bd problem??
      • Diah
        • Feb 2013
        • 6608
        no firmware issue neither T-CON. service menu Value has been changed by person.
        • saud52
          • Aug 2015
          • 24
          Dear! At the beginning, my TV has a Sony logo. After that briefly has a normal picture and then the display becomes milky white with these letters and numbers in up from the display TV has white screen with letters - top , left s written : TMP and top right s written :TIM . T-con is OK !
          TV works in agieng mode. I can not do a factory reset. Also, I can not enter Service mode.
          • Diah
            • Feb 2013
            • 6608
            you need first to put the TV in STB mode, then take the plug out from wall socket for awhile , bring the socket to wall back then inter with RC diagnostic mode.
            • saud52
              • Aug 2015
              • 24
              Dear Sir!
              Thanks!
              With remote control, my Sony can not go into Stby mode. It can not be turned off with manual controls. Always light green front LED.
              Answer from the Sony Service:
              "After talking to a Sony service technician, the appliance is placed in the factory test option, and the return from the service is not possible with the service remote.Only one solution-replace mother board."
              I do not believe in this. I think there's another solution? Did anyone know this solution in the world?
              • Diah
                • Feb 2013
                • 6608
                you need to post very clear photo of the MB from both side and ill be great if you shoot other photo on the eeprom most of them can be reset manually
                • saud52
                  • Aug 2015
                  • 24
                  Dear! On the display I only have what is seen on the photo. This is all! I know about eeprom reset, but this shit from the TV does not have a separate eeprom IC. EEprom with this Sony chassis is integrated into the main processor itself! What to do? Throw the TV in the trash?
                  • budwich
                    • Jul 2015
                    • 3097
                    try the firmware loading from a usb before you think of tossing the set.
                    does the remote work at all?
                    • Nycu
                      • Feb 2017
                      • spain
                      Hi.
                      I am having the same problem with a Sony KDL-55HX850. I don`t know the history of the TV because a friend gave it to me after he did not found the solution to it.
                      The remote only serves to power on the TV and then it does not react to it in any way. Jus stays with the white screen mentioned at the begining of this thread.
                      Also it is not posible to load the firmware.
                      • PopperSnapper
                        • Jul 2021
                        • 3
                        Just had this issue on my KDL-40NX703 after pressing the turn off screen button then the BD button.
                        On the remote, pressing and holding TV and Input buttons for a few seconds turned it off. Maybe this will apply to other Sony models? I thought I'd trashed my TV, but I started pressing combinations and hit the jackpot! lol
                        How did Sony let these button combinations slip through under normal use?
                        • Ihandyrepair
                          sony 55X850D black screen no front white or red led light.
                          by Ihandyrepair
                          Hi guys
                          strange one
                          I have a dead Sony 55X850D
                          when plug in, black screen, no front white or red LED, no back light no screen
                          Voltages I get
                          3.3v LD/power and main board
                          reg 12V
                          reg 19V
                          3.3v on power on pin
                          no Tcon on
                          no tcon 12v
                          no BL_on
                          I do get BL_ERR 2.0v
                          I tried to bypass it by ground it but still get same symptom
                          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                          or is possible the chip next to...
                          08-07-2024, 04:58 AM
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
                        • harp
                          White screen repairs
                          by harp
                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                          05-13-2024, 03:43 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • EazyBone
                          Sharp LC-65Q620U White Screen
                          by EazyBone
                          Another TV topic!!
                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                          08-21-2024, 12:56 PM
