Sharp LC-60LE650X - Temperature warning
  • Logic West
    • Oct 2018
    • 10
    I have a TV with the following symptoms:
    When powering on with the remote, it turns on and displays a warning msg in the bottom right corner "Temperature", then immediately goes back off.
    It was working fine until it was removed from the wall for painting and the fault started after it was put back up.
    I have removed the rear cover and inspected all the boards. The only thing that I could see that looked like a problem was the heatsink on the main board, which I think Sharp refer to as "main unit". It is soldered in place with a very thick thermal pad to transfer the heat. The heatsink was a little crooked and was fairly easy to wobble from side to side.
    I desoldered it to take a look at the thermal pad and it is in good condition. After resoldering it, it is very firm and doesn't wobble back and forth at all so I think the TV may have been dropped and damaged those solder joints. The same fault remains though. Could it be that I need to reset the error code or something? Or am I barking up the wrong tree?
    I appreciate any advice.
    Cheers,
    Alex
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Sharp LC-60LE650X - Temperature warning
    Fan failure
    • Logic West
      • Oct 2018
      • 10
      Hi Chris, there is no fan in this model. At least I can't see one. I have a sharp parts guide for it and I can't find a fan listed in there.
      • Logic West
        • Oct 2018
        • 10
        Does anyone know if that kind of error message could be from one of the boards other than the main board overheating? I mean, could the power supply board or the t-con board overheating generate that error or would it be something on the main board overheating?
          Can we see the pictures of what we are dealing with?
          Show the back side of the TV so we can see all the boards.
          Power supply board P/N and good clear straight shot pictures of the whole board?
          Main board P/N?
          • Logic West
            • Oct 2018
            • 10
            I took a pic of the rear but where I have the TV, the lighting is not great for photos so I took each board out and snapped them individually. I'm not sure which number on it is the p/n.
            Incidentally, I noticed that there appears to be some liquid running under the large BGA chip on the tcon board. I wonder if that is the source of my problems. That chip has a really thick thermal pad to couple it to the metal chassis of the TV so it must generate some heat.
            Thanks for your attention
            Alex
            • Logic West
              • Oct 2018
              • 10
              I have a proper sweep freq ultrasonic cleaner that I use for macbook logic boards. Can you think of any reason why the tcon board shouldn't be cleaned in the same way? I'll fire up the heater now cos the tank takes a couple of hours to heat up.
              • Logic West
                • Oct 2018
                • 10
                Never mind, I couldn't find any sign of liquid on the inside of the rear cover. It looks like the liquid under the BGA ship is just liquid that has leached out of the big thick thermal pad and it has come through the vias and onto the balls. I doubt that liquid is electrically conductive.
                  I doubt that will be the problem, the thing is if they have temperature sensor to detect over temperature problem, I cannot see how it will trigger so fast when TV changes state from standby to fully on, I would expect the bad past to slowly heat up but not instant to put TV into shutdown mode. So if you check the temperature on the boards when TV is in standby do feel any parts that gets too hot to touch? It may be that the sensor is faulty.
                  • Logic West
                    • Oct 2018
                    • 10
                    The fact that the problem started only after the TV had been unmounted and remounted to the wall made me think that something physically must have been damaged or dislodged. I looked over all the boards for anything resembling thermistors or sensors attached to heatsinks but I can't find any. SMT thermistors just look like resistors anyway so not easy to find them without a schematic.
                    Perhaps the TV flexed and a trace was broken or a SMT chip pad became disconnected. I'll put the boards back in and do as you say, it's a good idea.
                      You can try cooling the main board with compress canned air upside down or have the fan blowing on the main board for a while then power up the TV to see if the error will still show up or not right away.
                      "Perhaps the TV flexed and a trace was broken or a SMT chip pad became disconnected. I'll put the boards back in and do as you say, it's a good idea." you may be correct.
                      I am still looking through the pictures of the boards.
                      There is nothing in the user manual either about the Temperature warning message.
                      BTW: Sharp RUNTKB057WJQZ (DPS-168JP A) Power Supply / LED Board LC-60LE600U
                      is used in LC-60LE600U so I look at the service manual for the Temperature warning message:
                      It will show 4-blink code.
                      'Judged by monitoring temperature with the temperature sensor.
                      When the panel temperature is 63°C or more, caution is displayed.
                      If the panel temperature is 65°C or more, error standby is
                      activated.
                      [Released]
                      Reduce the value of TEMP CAUTION (temperature caution
                      threshold) and TEMP SHUTDOWN (temperature protection
                      threshold) in the adjustment process mode menu."
                      The main board of the LC-60LE600U, it has Thermistor TH3301 that feeds the main MCU IC, so you may want to look at your main board for part with TH** designator.
                      • Logic West
                        • Oct 2018
                        • 10
                        The boards don't get hot in standby. Cooling the mainboard didn't affect the symptom
                        I guess it must be either a broken connection or a faulty sensor. Do you think there is any chance that it needs to be reset to factory defaults if there is such a thing with TVs?
                          I did not find the service manual for your model to see how to do factory reset.
                          • Logic West
                            • Oct 2018
                            • 10
                            I found the manual for a slightly different model but the procedure requires you to be able to access the menus anyway so I wouldn't be able to perform it.
                            Thanks a lot for your help anyway
                            I think this one will be a real rabbit hole.
                            • DXseekerMO
                              Sharp LC-70LE757U, YouTube/web browser security warning, certificate not trusted
                              by DXseekerMO
                              Hello again everyone!
                              I have a Sharp LC-70LE757U. When I try to sign on to YouTube or access some apps I get a security warning saying "The server www.youtube.com presented a certificate issued by an entity that is not trusted, proceed anyway?" If I proceed this same warning continuously pops up.
                              If I factory reset the TV sometimes the apps will come up, and sometimes I have to factory reset the TV up to 3 times to get them to work. The apps will then work until the next day and I have to reset the TV again, sometimes up to 3 times to get them to work....
                              06-29-2021, 08:54 AM
                            • harp
                              Metod for removing glued heatsink from fragile component
                              by harp
                              I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                              06-23-2025, 02:01 PM
                            • CapLeaker
                              AcuRite 5 in 1 temperature sensor replacement repair
                              by CapLeaker
                              Got a new victim:
                              AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                              A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                              B: stuck at some temperature and maybe updating once in 12 hrs or so.
                              Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                              04-15-2025, 01:32 PM
                            • Ven
                              Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                              by Ven
                              I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                              The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                              I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                              If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                              07-08-2024, 09:32 AM
                            • asdas09
                              Temperature to remove chips from motherboard
                              by asdas09
                              What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                              I have device Sugon 202. I'm used also normal flux and rosin flux.
                              09-12-2023, 12:44 AM
