Samsun UN46F6300AF No Backlight but they test good
  • neilc6
    • Nov 2015
    • 1550
    TV tries to turn on but no backlight. Power supply is BN44-00611D. Board referenced in this thread. https://www.badcaps.net/forum/showthread.php?t=56046
    Unplugging cable between power supply and main board does not turn on the backlights. I pulled apart the panel and tested all the strips and they were all GOOD.
    Measuring the big filter cap, I am getting 270VDC which is low since 390VDC is expected. From other thread, checked solder joints on transformers, rivets and feedback resistors and they look good.
    Suspect SMPS IC ICP801 but can't read markings or find schematic. May have to order the shopjimmy repair kit. I have FAN7530 and FAN7930B chips from a previous repair but circuitry doesn't seem to match.
  • R_J
    • 9623
    Re: Samsun UN46F6300AF No Backlight but they test good
    I could be wrong but icp801 could be a SEM3050, Do you have VCC (pin8) on the ic?
    • neilc6
      • Nov 2015
      • 1550
      Stumbled into this post which was my identical problem. He has the wrong power supply board number which is why I didn't see it.
      https://www.badcaps.net/forum/showthread.php?t=66201
      Measured RS802 in circuit and it was pretty high so I replaced it with a 10 ohm resistor.
      Good news - power supply is working with backlights on.
      Bad news- image is dark top 1/3 of the screen. Too bad I didn't see this before taking apart the panel. Pretty sure I was careful enough not to damage it. Reseated tcon connections. Think it is the backlight, will need to check the connections.
      • neilc6
        • Nov 2015
        • 1550
        It does appear that the top strips are not getting any voltage.
        Checked voltages on power supply with nothing connected CNL802. The + pins may have 0.1V but essentially 0V.
        16 IF1 0V 15 IF2 0V
        12 1+ 0V 11 1- 0V
        10 2+ 0V 9 2- 0V
        6 3+ 282V 5 3- 0V
        4 4+ 0V 2 4- 0V
        Diodes D9201C and D9101C tested good in circuit as well as R9113 and R9213. Used boards are around $50 so it would be preferred to repair this one.
          Please recheck the DCV again at both ends of R9113, and R9213 against GND.
          The panel has two LED strings, one looks to be open circuit.
          • neilc6
            • Nov 2015
            • 1550
            R9213 and R9113 measure 282V DC on both ends with no load.
            I checked each LED strip individually when I opened the panel. They all tested good. Wasn't sure how they were wired. There are 5 pairs of blue/black wires coming from CNL802.
            With LEDs connected
            IF1 0V
            1+ 1V
            2+ 0.4V
            3+ 151V
            4+ 57V
            • neilc6
              • Nov 2015
              • 1550
              R9113 connects to 1+ pin so should get 282V on that pin. Remeasured and it is there and reheated the connector joints. Think I am losing continuity from 1+ to the LED strips since I can't measure it on the connector at the LED strips. The connectors are tricky to probe and determine the pinout since they are 2 level top snapping.
              R9213 connects to 4- pin through a ferrite bead.
              • neilc6
                • Nov 2015
                • 1550
                Fixed!
                IF2, 1+ and 1- pins showed no continuity to the LED connector so I soldered them directly to the back of the main board. These connectors were still a little flakey since pushing them on the LED side can make some strips go out. Mental note to keep these cables when salvaging broken screen TVs.
                Thanks again Budm for pointing me in the right direction - mainly looking for that 282V from the resistors and indicating there are wired as two sections.
                  Great, thanks for the follow-up.
                  • alfatv
                    • Sep 2020
                    • 353
                    I also had success with RS802, I posted my reply in original post and attached schematic that is close enough.
                    neilc6, thanks for pointing.
                    • chth96
                      How Can I test PWM DM0365R?
                      by chth96
                      Hello
                      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                      06-18-2025, 04:14 PM
                    • khelane
                      test active pfc power with lamp test
                      by khelane
                      Hello
                      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                      Is there a way...
                      06-03-2025, 01:00 AM
                    • irepair559
                      Ps4 1215a hdmi diode readings good everything good but no pic??
                      by irepair559
                      PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                      01-05-2023, 12:32 AM
                    • hemant_2222
                      Yamaha 2064 No sound but Test audio working
                      by hemant_2222
                      Hello Guys,
                      Greetings!
                      Hope you all are doing well.
                      I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                      PCM1681DBQR - IC263 and it worked fine.
                      Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                      11-01-2025, 11:20 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
