Samsung UE50EH5300 - bad picture, helping to diagnose for a friend
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    Dear BC community,
    I would like to help a friend to diagnose a faulty TV set trough the internet.
    I attach his pictures and a video of the problem. It has 5-10 cm good picture on top, below that point everything is ghosty, seems doubled.
    What he has done so far:
    -Measured voltages (also on T-Con), everything seems fine.
    -Carefully pushed the COF cables, no change.
    -Measured all the components on the buffer board (after T-con, before display), nothing is shorted or bad value
    And here comes the video:
    https://www.youtube.com/watch?v=ix8e...ature=youtu.be
    Pictures:
    This is the problem, demonstrated with text.
    TV Type
    Picture with left T-con cable disconnected
    Picture with right T-con cable disconnected
    T-con pcb
    I would say defective panel, but to be sure, called for your help.
    I haven't told him about the cof ripoff technique yet, will leave it for last resort.
    Cheers, Janos
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UE50EH5300 - bad picture, helping to diagnose for a friend
    Yes. That is a bad panel
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      Thank you very much.
      Cheers, Janos
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4462
        • Italy - Milan
        It's the same i'm trying to repair, check this, my suggestions are the same:
        https://www.badcaps.net/forum/showthread.php?t=71925
        my it's AUO panel for Hisense.. and yours?
        • ducky29
          • Dec 2015
          • 369
          • Europe
          His is AUO too
          • DIMITRIO
            • Jul 2017
            • 9
            • GREECE
            Check for dry joints in the panel board after the t-con.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4462
              • Italy - Milan
              No dimitrio, no...
              • yohnsee
                Semi-noob
                • Dec 2017
                • 198
                • Hungary
                Guys, thank you for your time and effort.
                Next my friend tries to remove the row drivers (if there are any) and we will see.
                DIMITRIO: he already checked for cold joints, corrosion.
                Cheers, Janos
                • budwich
                  • Jul 2015
                  • 3097
                  your pictures don't agree with the words... picture shows left or right disconnected, yet the pictures show the same side white... probably not possible. Re do your test to make sure what you are seeing before going too far with "tab removal".
                  suggest that you do some checking of the smd devices on the bottom edge boards (ie. capacitors / resistors) as something strange with your pictures.
                  • yohnsee
                    Semi-noob
                    • Dec 2017
                    • 198
                    • Hungary
                    Yes, I was also skeptic about those 2 pictures, but my friend says he followed my instructions word by word. Told him to redo the test, we will see (or not)
                    By the way, thank you for chiming in.
                    Cheers, Janos
                      https://www.badcaps.net/forum/attach...7&d=1537300095
                      Gate tab bond failure as shown in SONY training manual.
                      • yohnsee
                        Semi-noob
                        • Dec 2017
                        • 198
                        • Hungary
                        Thank you budm, I was afraid of that.
                        Cheers, Janos
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Wait probably I was a bit too quick to say bad panel. Could we see pics of the screen with the LEFT T-CON Bd FFC to Panel/Source Bd disconnected and and RIGHT cable connected and another pic with the RIGHT T-CON Bd FFC to Panel/Source Bd disconnected and LEFT cable connected? Of course you would have an input signal connected on AV or HDMI, etc.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4462
                            • Italy - Milan
                            Yes, better pictures are needed, the defect is alreeady said but need to be sure which side has bad gate driver, and tell also if the tcon is at bottom or on top.
                            • yohnsee
                              Semi-noob
                              • Dec 2017
                              • 198
                              • Hungary
                              Thank you guys, I would love to investigate this further, but my "friend" doesn't respond since yesterday. I can't reach him, and as long as it stays this way, we cannot move forward. Excuse me
                              Cheers, Janos
                              • yohnsee
                                Semi-noob
                                • Dec 2017
                                • 198
                                • Hungary
                                Hello everybody.
                                I have an update on the case, but not that we were looking for. My friend gave the set away. But before this, he was able to confirm, this display has no side tabs. Only test he could do is isolating the tcon cables, but he didn't have the time for that. So without end, case closed.
                                Cheers, Janos
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4462
                                  • Italy - Milan
                                  Next time ensure your friend have time and wish before post..
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4462
                                    • Italy - Milan
                                    In the sense that his tv could be still salvaged also without side tabs..
                                    • yohnsee
                                      Semi-noob
                                      • Dec 2017
                                      • 198
                                      • Hungary
                                      Don't worry, there will be no next time. I see how much effort was put into this by the people of this forum (once again, thanks to everybody) and still nothing to show up. One thing I learned: never again.
                                      Cheers, Janos
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        That is fine by me. If it happens again I will respond to the request. Good luck.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
