Samsung panel or ?
  • Blackeye
    • Sep 2018
    • 2
    • England
    Samsung panel or ?
    Hi... hoping someone has an idea what maybe wrong with my samsung ue43j5600k. I think its the panel but not 100%, so any help would be appreciated. Thx
    Pics are upside dwn for some reason..lol
  • MrMagoo
    • Jun 2015
    • 6
    • Oztrailya
    Re: Samsung panel or ?
    I will leave the diagnosis to the local gurus. But my observation is that the menu isn't affected by the stripes, so most likely not the panel but a main board? Are the stripes in same position when menu isnt on screen. Are they impacted by whats on the screen ?
      I would say definitely panel, the menu is affected by the stripes if you look carefully.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4463
        • Italy - Milan
        It's a common panel fault unfortunately, one gate driver. There are some solutions and i'm experiencing some tries theese days, i hope i can find a better cure. Please don't buy SAMSUNG tv! The simpliest way is to remove the faulty side tab, no need to remove all, first disconnect one side at a time of the tcon>panel ribbons, you'll see one way that has half good image, then remove the tab where the line is, of the side where the image were displayed wrong with the test. Another way conservative is to locate on tcon a silkscreen with one of those labels: VST,STV,ST,STVP,VSTP,VCST, on a tespoint, then locate on the connector of the bad side to which pin is connected to, cut a small stripe of adhesive trasparent tape large like a contact then mask the previous signal, this way leave a thin half line on the screen sadly, it is "possible" to remove it by cutting the shorted output on the faulty gate driver but it's needed a micro hand, micro blade and macro view!!
        • ducky29
          • Dec 2015
          • 369
          • Europe
          I would say that the panel is faulty
          • Michale32086
            • Nov 2011
            • 1453
            DOGPILE!!!!
            Panel issue..
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4463
              • Italy - Milan
              WHAT IS DOGPILE?! Is it SH*T or dumpster? if the screen has side tabs one solution is at hand and perfect screen, the second solution give also a decent image, you have to do prof. graphics with it??
              • Michale32086
                • Nov 2011
                • 1453
                Sorry, my quirky sense of humor.. Meant I was just joining the crowd, "piling on" that it's likely a panel issue...
                It may be a tab issue and, as such, your idea might work..
                I didn't mean to imply that it was a hopeless cause...
                Again, my apologies..
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4463
                  • Italy - Milan
                  I've said it because google did not translate DOGPILE...
                  anyway is not the common tab issue is a cof short circuit.. (mmm or some other secret inside it..)
                  • R_J
                    • Jun 2012
                    • 9588
                    Dogpile is a metasearch engine for information on the World Wide Web that fetches results from Google, Yahoo!, and Yandex, and includes results from several other popular search engines, including those from audio and video content providers. Wikipedia
                    It's been around since 1995, I used it years ago.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      In my usage, it was referring to a game we used to play when I was in 3rd grade (long long LONG before the Internet) where we gathered in a grassy field and simply piled up on top of one another.. It was a simpler time..
                      I feel so old....
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
                        09-07-2024, 05:50 AM
                      • Storyteller12
                        QN55Q60R Service Menu Panel Help
                        by Storyteller12
                        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                        01-13-2024, 01:57 PM
                      • triplefour
                        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                        by triplefour
                        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                        tcon is built into mainboard.
                        Only one cable goes to panel boards.
                        there is a cable from one panel board to the other that links them.
                        cost cutting measure that results in us having harder time to diagnose.
                        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                        07-28-2022, 07:59 PM
                      • NWArkGuy
                        Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                        by NWArkGuy
                        Well, I will be the first to admit that I screwed up...
                        In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                        I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                        I have 2 that I have found and have in my possession. ...
                        10-12-2023, 10:13 PM
