RCA LED55c55r120q
  • Brucetafer
    • Jun 2018
    • 133
    RCA LED55c55r120q
    TV is 2 years old, worked fine for the entire time, then last couple weeks it wouldn't turn on, it stayed red led standby unless I unplugged it and plugged it back in and then it would turn on.. then after a couple times it was unplug it 2-3 times, then 5-6 and now its stuck off completely.. I pulled and tested the test points and they are 5- 5V points 1 on off point and 2 - 12v points
    voltages as follows.
    12.56
    12.56
    GND
    GND
    GND
    5.07
    5.07
    5.08vsb
    4.56 on/off
    5.05
    5.06
    GND
    Replaced all the caps and did nothing..
    baked the main board did nothing..
    haven't frozen the main board yet
    no bad smells or anything.
    Re: RCA LED55c55r120q
    The connector has 13 pins, so what is the name of the missing that is not on your list?
    It may have EEPROM problem.
    http://www.shopjimmy.com/catalogsear...+LED55c55r120q
    • neilc6
      • Nov 2015
      • 1550
      Looks like that model may have EEPROM issues. With it unplugged, spray the SOP8 chip beside the main processor with an inverted can of duster to freeze it and then try powering on to confirm it. You shouldn't have baked the board (processor isn't even a BGA) and I've never seen bad caps on an LED TV (yet). There is an eeprom dump for that model on this forum as well if you search.
      https://ebay.us/M6P8T5
      • Brucetafer
        • Jun 2018
        • 133
        well i didn't notice it either, back of the power board upper right hand is a nice shit stain... i guess im going to just buy both boards since they are cheap..
        • Brucetafer
          • Jun 2018
          • 133
          sorry the rest were grounds..
            Can we see the pictures of the whole back side of the TV showing how all the boards are connected? I only see 'ON/OFF' signal pin but I do not see other control pins at all. Does the ON/OFF pin change state when power switch is toggled on and off?
            • Brucetafer
              • Jun 2018
              • 133
              currently its all torn apart, the on off signal does work to the main board. so at least I know that works.. the low voltage to the on off on the power board concerns me.. and the blown area on the back..
              https://www.google.com/search?q=rca+...Xiy68TSpEK6AM:
              • Brucetafer
                • Jun 2018
                • 133
                replaced the power board, and still dead, the main board comes either tomorrow or tuesday.
                I just noticed that I ordered 55120re01m3393lna35-q4 instead of the 55120re01m3393lna5-q4 same TV, will that make a difference? I see theres a TON of different boards that look exactly the same, that use the same power supply.. im guessing its the eprom is the difference? like when the tv turns on it has a different logo like PROSCAN instead of RCA? im new to the TV world, and it seems like a lot of the cheaper TV's all use the same manufacturer for their boards..
                  This kind of TV will use the same blank circuit board but he board will be stuffed differently to make many PCBA (Printed Circuit Board Assembly), you need to match the PCBA numbers as printed on the barcode sticker.
                  • Brucetafer
                    • Jun 2018
                    • 133
                    ok, well the seller wont accept a return, can I buy the proper eprom and try that? theres no other options to replace the whole board except one guy wants 125 bucks for it on eBay..
                      • 12196
                      • U.S.
                      RCA is pretty much crap, was curious and searched for 20 minutes, could not find any firmware for rca tvs, support seems nonexistent, I wouldn't invest much more than a new eeprom or a very cheap mainboard.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Not sure where you're located. Shopjimmy may sell the programmed eeprom, or eBay even.
                          • 12196
                          • U.S.
                          https://www.shopjimmy.com/catalogsea.../?q=55c55r120q eeprom on this page, bud posted it in #2.
                          • Brucetafer
                            • Jun 2018
                            • 133
                            well guys, you nailed it.. its was the eprom, changed it for the one on shop jimmy, and boom works like a charm... I replaced the burned resistor and cap on the old power supply that blew out matching the same as the new one, and the old one was bad as well.. so either way for 39 bucks we fixed it... thanks again you guys, you are the best!!!!!
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • novator2007
                              Help with finding ThinkPad T460 JTAG Points
                              by novator2007
                              Hello All,
                              I got a T460 with issue - No picture - Fan on full Speed and no Power LED Light.
                              Bios already reflashed
                              All standard voltage is present. CPU on emergeny(?) mode - max 30 c Grad.
                              By Schematc & BRD View I have found few Debug/Jtag points.
                              Just not sure which one is correct,
                              1.There is some(under lack) Test points near CPU - Schematic Page 6
                              2. J9 26p place for connector - Present: PCH_TMS/TDI/TDO/TCK/RSMRST
                              3. J8 26p place for Connector - XDP_TMS/TDI/TDO/TCK/RSMRST
                              I trying to find a correct...
                              08-02-2022, 07:49 AM
                            • SolomonMan
                              A Couple Quick Battery Questions...
                              by SolomonMan
                              All,
                              I have 4 laptops all the same HP Elitebook model. These are now close to 8-10 years old now but they all were high end software development machines (ie 16GB ram (32 max) and all now have been upgraded to 1TB SSD). They are used throughout my house (family).
                              I recently bought a Software Defined Radio setup (SDR) and I will use it with one of the laptops but the batteries appear to be all dead.
                              The replacements seem reasonable at the sub $30 range (some as low as $20 shipped).
                              So I am thinking of replacing them all.
                              So the question...
                              04-16-2023, 07:41 AM
                            • lmcancu
                              LED Strip test points and testing?
                              by lmcancu
                              Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
                              Thanks in advance...
                              03-20-2023, 07:52 AM
                            • migax miranda
                              hp 15s-eq0012np contact points on the "type C" charger input were torn off
                              by migax miranda
                              Hello, a "hp 15s-eq0012np" arrived to me, the only problem with it is that the contact points on the "type C" charger input were torn off. Can anyone tell me what the purpose of each "leg" of the connector is? Which ones are really necessary for it to charge the battery and turn on?
                              10-13-2024, 10:03 AM
