hp 15s-eq0012np contact points on the "type C" charger input were torn off
  • migax miranda
    • Jun 2024
    • Portugal
    Hello, a "hp 15s-eq0012np" arrived to me, the only problem with it is that the contact points on the "type C" charger input were torn off. Can anyone tell me what the purpose of each "leg" of the connector is? Which ones are really necessary for it to charge the battery and turn on?
  • mon2
    • 14758
    Post clear pics of the connector. The type c interface is well documented so details are available on the internet. Best suggestion is to flux and replace this defective connector. Share details before proceeding. The replacement connector may be available through Digikey or Mouser or AliExpress. This interface requires a mix of lines including CCx, Vbus, Ground.
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
