Blackscreen after couple of hours playing (PC)
  • nothinghyper
    Volt Seeker
    • Aug 2025
    • Poland
    Hi Everyone,
    After couple of hours playing a game i get blackscreen , i can still hear the sounds and i can move the character but the image doesnt come back until i reset the computer. I have tried running Furmark 1080p settings fullscreen for 7 hours and didnt encounter the same problem. It used to give me an error as driver not responding so i have installed only the driver itself and not the radeon software since than that message doesnt come up anymorre but i still have the same issue. Sometimes it happens after 30 mins gaming time , sometimes after 3 hours , sometimes even after 6 hours of gamin its just random.
    What might be the problem ?
    System :
    CPU: Intel Core i5-3470 (3.2 GHz base, 3.6 GHz turbo)
    GPU: AMD Radeon RX 580 8GB
    RAM: 16 GB DDR3
    Storage: 512GB SSD
    PSU: 650W​
    Motherboard: Gigabyte GA-H61M-S1​​
  • DynaxSC
    • Apr 2021
    • 473
    • Poland
    Can be anything, an hardware issue, overheating, or a software glitch in the driver, OS or the game software code itself. Try a different GPU, best the same make and model, if failure continues, then ist software. If failure does not come back, then its hardware. Try different driver, also older versions. Sometimes new drivers have recurring software bugs
    already repaired, but added again by accident by the developers. Could also be memory leaks, so free RAM available decreasing with play time until RAM is fully used, check memory usage with Task Manager eventually upgrade RAM, similar issue could be with missing disk space. Also your HW is quite old, so could be not powerfull and/or supported enough for actual OS and gaming software versions, I'd recommend to evaluate to upgrade this HW, at least motherboard, cpu to 8'th or better 10'th gen and ram to ddr4/32GB. Check what are the min. HW requirements for the game and your OS. SSD if it's SATA, then it would be also much better to have M.2 PCIe SSD (NVME) instead of SATA, this makes beside RAM capacity really the qualitative biggest difference in system performance.
    • JohnML1975
      LG 49UK7550PTA - after couple of hours screen starts to blink
      by JohnML1975
      Hello Forum team
      Have this TV; searched for the model and could not anything so thought I would share in here
      Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
      Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
      So I removed the covers, and could not see anything visibly
      Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
      07-25-2025, 10:48 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
    • charif
      Audio Driver for Thomson P14C4BK128
      by charif
      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
      Here are the details:
      • Model: Thomson P14C4BK128
      • Operating System: Windows 10 64-bit
      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
      Thanks in advance for your help!
      04-30-2025, 05:41 PM
    • bohaboha
      how to install gl usb2.0 uvc camera device driver on windows 10
      by bohaboha
      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
      any help?
      01-26-2025, 08:33 PM
