A Couple Quick Battery Questions...
  • SolomonMan
    • Apr 2019
    • 206
    All,
    I have 4 laptops all the same HP Elitebook model. These are now close to 8-10 years old now but they all were high end software development machines (ie 16GB ram (32 max) and all now have been upgraded to 1TB SSD). They are used throughout my house (family).
    I recently bought a Software Defined Radio setup (SDR) and I will use it with one of the laptops but the batteries appear to be all dead.
    The replacements seem reasonable at the sub $30 range (some as low as $20 shipped).
    So I am thinking of replacing them all.
    So the question is I see the same MAh values but some are saying 6 cell and others are saying 8 cell. The price difference to me negligible...a couple bucks with the 8 cell being more expensive.
    Now am I correct to make the assumption that these 14.8 Volt batteries with the same MAh value;
    They will last the same amount of time (laptop run time)?
    The 6 cell will charge faster than the 8 cell?
    The 8 cell will be heavier?
    Will they last the same amount of time (a few years at best)?
    Out of curiosity Why the difference in price?
    Final question, The old batteries can they be disassembled or useful for any kind of electronics projects?
    I have been on a series of battery replacement projects (drills/laptops) lately.
    The other battery project I have is a couple old Black and Decker Professional/Craftsman drills that their batteries seem unavailable.
    Thanks for all the help,
    Chris
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: A Couple Quick Battery Questions...
    there is a lot of things involved here but things like the quality of the individual cells makes a difference as well. You can't judge a cell by looking at it, so it's not clear which is a better solution.
    Part of the cell quality includes whether the advertising is accurate too...
    • harp
      • Jun 2022
      • 642
      • Planet Earth
      Pay attention to the original nominal voltage and cell configuration, usually if it 6 cell it is 3s2p configuration whitch gives nominal about 10.8v
      14.8v nominal is 4 cell in series... and 2 parallel giver 8 cell in 4s2p configuration.
      A few teardown videos
      https://m.youtube.com/@BGTechforYou/...query=teardown
        • Jul 2011
        • 6069
        Be careful of off brand battery packs because the majority of them using Chinese made batteries and there is no way of knowing and there quality is decent at best and terrible at worst
        I have had fairly good results with eBay sellers that have high feedback scores but look at the negative ones that are there laptops batteries and if you see a lot very short run times or do last long before not taking a charge any more
        “ Part of the cell quality includes whether the advertising is accurate too...” very important to consider
        • SolomonMan
          • Apr 2019
          • 206
          eccerr0r/Harp
          Thanks for the replies!
          So from the sounds the warranty and who you buy it from may help make the final decision as well.
          I know on the Drill battery cells, 18650 Lithium Ion batteries seem to be a very popular choice.
          Individually at the HAM/Computer Festivals these are popular and not pricey...the price online also reflect this as well. I believe for example the name brand (Sony) ones typically ran a dollar more and individual price was reasonable few bucks tops. Less if you bought in bulk.
          I do see where I can choose a Lithium Polymer for the laptop battery but the price of course almost triples. There only appear to be a few suppliers of the Lithium Polymer batteries.
          The more popular battery it appears is the Lithium Ion in 1,3, and I believe I saw a 5 year warrantied ones. The prices goes up as well (few dollars as years extend) but the one I was considering was a 3 year battery.
          The spec of the one I am considering;
          Battery type: Li-ion
          Voltage: 14.8V (Compatible with 14.4V)
          Capacity: 5200mAh
          Cell: 8 Cells
          recharge cycles 500
          Operation time: Around 2-3 hours
          How does the Recharge cycles play apart? I assume the more cycles the longer it lasts?
          So are these cells typically a standard voltage and then the arrangement decides the voltage output? Size the MAh?
          Should I disassemble the current battery to see its configuration to compare possibly against my possible purchased ones?
          I know that on the drills they suggest actually tearing down the battery and test each cell. Evidently they can go to zero and need some initial charge or they can also go bad.
          I guess many try refurbing...this is not my goal...but if I can use the old cells for something...I would. It appears I may be able to use them.
          Thanks,
          Chris
            • Jul 2011
            • 6069
            Maybe you can put new battery cells in a pack but be aware that some of these battery packs have a micro chip in that if you remove the battery cells from the board it will not work correctly after that however you can not tell which battery packs are that way
            • SolomonMan
              • Apr 2019
              • 206
              Sam_Sam_Sam,
              Thanks for the reply!
              It appears the fellow on ebay has been selling on it since 2016. Also he has close to 78000 rating. His percentage is 99.1%.
              His 7 negative out of 1455 in the past month, all of buyers feedback are under 200 and most of those are actually under 75 (new basically).
              I thought about rebuilding them but honestly once you figure in the cost of batteries and the risk of the charging board not working (saw that on youtube video provided previously in thread) It does not appear to be worth it.
              I am thinking I am going to buy the 3year warrantied, 8 cell, 30 day return ebay fellow. The next possible was a company on Amazon. They were 6 cell, 3 bucks cheaper, 1 year warrantied, 60 day return. The warranty and the sellers longevity/numbers are worth the 3 bucks alone to me.
              Thanks everyone for the help,
              Chris
              • mitsu2k
                • Aug 2013
                • 219
                The problem with eBay feedback is that eBay only allows you to leave feedback for a transaction that is I believe 90-120 days old. So that does not give very much for people to thoroughly evaluate and leave appropriate feedback after that time period. But I do agree that looking at and evaluating feedback is a must even if it is limited.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  You get about a year out of non genuine batteries.
                  3 years warranty ! good luck claiming back on that.
                    • Jul 2011
                    • 6069
                    This is why you try to get OEM battery packs if possible yes they cost more usually but in the long run you are better off
                    • SolomonMan
                      • Apr 2019
                      • 206
                      Unfortunately the OEM battery...looking across the web is easily 5 times the cost. And I actually used these machines originally for development...3-5 years was max...3 years things really seemed to degrade with the OEM batteries.
                      So If I plan to go past 3 years with these laptops (possible) then plan for the batteries to be replaced
                      Thanks,
                      Chris
                      • SolomonMan
                        • Apr 2019
                        • 206
                        Funny you should mention this...
                        During the Covid pandemic I order a replacement set of M18 Batteries for my Milwaukee shop drills. If anyone knows of these you will know these are not exactly cheap.
                        Anyways I bought 3. One OEM. Two knock offs as a test. All From memory had 5 year warranties on them. Of course the knock offs were half as much.
                        A year abouts go by. My one knock off battery no longer takes a charge. Its dead. All the other batteries I have (6) charge fine. So I reach back to the seller for suggestions/warranty replacement etc.
                        He basically ignores me. He had a rating I believe in the 54000 range. I tried and tried again and finally I brought Ebay into the issue.
                        They followed what they state in the below link;
                        https://www.ebay.com/help/policies/l...policy?id=4245
                        Basically when I called eBay I mentioned what happened and I also mentioned the Magnuson-Moss Warranty Act. He reviewed the situation. Stated he did not have the proper warranty paperwork in order. Also he had some negative marks already against his account mentioning similar. EBay gave him 48 hours to respond and also to get his auctions in order for the warranty.
                        In the end, the seller helped me "jumpstart" the bad battery and updated all his auctions. I have bought from the guy since as well.
                        I personally think what got him was his non response. Also I think the time period (Covid) did not help.
                        I should also mention its close to 3 years and I have not had any issues since with these batteries. The ones I need to work on are all old 12 Volt house use drills. These drills are hardly worth the effort for most of the shop task (compared to the M18) but the wife and the kids use them mostly.
                        Thanks,
                        Chris
                        • dmill89
                          • Dec 2011
                          • 2534
                          While that is certainly the ideal solution it is not always practical or even possible. This is especially true of older machines where replacement OEM batteries often either cost more than the laptop is worth or are outright unavailable.
                          Of course, aftermarket batteries are always a bit of a crap shoot, I've had more "good" than bad (though just about all lie about capacity), but have definitely gotten a few "duds", that were either outright DOA (of course these can generally be returned for refund/replacement, thought you might be out the shipping cost), or degraded significantly after a year or two (generally outside the warranty/return period).
                            • Jul 2011
                            • 6069
                            In principle I would agree with you about that aftermarket battery packs that it is crap shoot but the problem is that you do not have anyway to know what you are getting so buying not real cheap but not real expensive either some where in the middle
                            This is why when I buy battery cells or battery packs that are not marked as needed repair not tested I refuse to pay much for them especially tool battery pack that have no life in the fuel gauge if you are lucky you might get a working BMS protection board but do not count on it
                            I will buy tool battery packs that have this
                            • SolomonMan
                              • Apr 2019
                              • 206
                              All,
                              Well I ordered a single battery. I was going to buy more than one at this time but other priorities (Birthday/medical) got in the way.
                              Anyways on the check out for 3 bucks I could of added a 2 year insurance warranty.
                              I have done this 2 items...one worked in favor for me. The other time I have not had a issue with it....so another thing to keep in mind I guess.
                              I will let you know what I find in the old battery and how the new one works.
                              Thanks,
                              Chris
                                • Jul 2011
                                • 6069
                                How did these battery packs work out the non brand name ones
                                Yes I know that this is an old post I found this when looking for an old post of mine
                                • carrzkiss
                                  Cyberpower cps1500avr not charging batteries
                                  by carrzkiss
                                  Hello, all.
                                  Cyberpower Battery Backup Unit.
                                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                  Checking the voltage, it was down to 22v.
                                  I quickly removed everything...
                                  06-15-2024, 02:10 PM
                                • tmhobadcap
                                  Lithium ion cell voltage not going up after 3.8V
                                  by tmhobadcap
                                  I got a chromebook with battery problem. It was charging when plugged in. But the indicator just showed that the battery was below 10% no matter how long it was plugged in. I took the battery pack out. There are two cells in series. Each cell had a voltage of about 3.7V. I charged one of them with a lithium cell charger. I can see current going into the cell at about 500mA. After several hours, the voltage was just about 3.8V. I charged it again manually by connecting 4.2V to it from a power supply and set the maximum current to 500mA. I can see about 100mA going into the cell. But the voltage...
                                  02-03-2025, 01:30 PM
                                • howardc64
                                  Where do repair shops buy MB replacement batteries?
                                  by howardc64
                                  Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                  Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                  BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                  07-25-2024, 10:42 AM
                                • Astonished
                                  Fixing the Charge Circuit of the Batteries of the DC Motor
                                  by Astonished
                                  Hi friends of electronics
                                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                  Please help me fix this circuit.
                                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                                  01-28-2025, 06:24 AM
                                • dbuergi
                                  DIY: Modified smart charger for all types of batteries
                                  by dbuergi
                                  sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                  Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                  My first work was to bring my Samsung watch battery back to life with was not recognized...
                                  07-18-2025, 03:17 AM
