Vizio E601i-A3E - Lines In Display After Mainboard Replacement
  • grimacelord
    • Jan 2017
    • 354
    Hello again. This TV came in for no power, no standby light after a pretty nasty thunderstorm we had in here. I disassembled the TV and took some measurements on the power supply and determined that the main board was bad.
    I bought and replaced the main board and now the TV turns on just fine and everything works perfectly - yay! - but there are lines throughout the image on the display.
    Doing some more troubleshooting, I followed the steps outlined in this YouTube video by ShopJimmy that would determine if my LCD panel was bad or my T-CON board was bad. Following the instructions of the video and according to ShopJimmy, my panel was likely fine. So, I bought the T-CON board and replaced it. No change. Lines are still there.
    Am I looking at a bad panel basically or is there something else I can check? Thanks guys.
    Pics!
    EDIT: I just looked at the pics again and some were reflection effects showed up in a couple pics that makes it look like a cracked panel. It's not cracked. See post #2 for new pics
  • grimacelord
    • Jan 2017
    • 354
    Re: Vizio E601i-A3E - Lines In Display After Mainboard Replacement
    Clarification from Post #1 to show that the panel ISN'T cracked, that's just an illusion by reflection and what not.
    • vinceroger69
      • Mar 2012
      • 6714
      was the mainboard a exact match all number on both old and new boards the same
      • R_J
        • 9515
        Check the numbers on the white sticker, or post pictures of the old board so we can read the sticker numbers
        • grimacelord
          • Jan 2017
          • 354
          Yes both of the board numbers are the same:
          E6011-A3 MB BD
          1P-012BJ00-4012
          2012.11.21
          REV:1.2
          The little white sticker has the same top line on both boards, but after that, the numbers change. I assumed this white sticker was more of a uniquely identifying number for THAT particular board, like a serial number. For what it's worth, I attached pics of both.
          BTW, in the pics I attached, the first one is of the replacement board, the second is original. So it goes like:
          1. Replacement Board | 2. Original | 3. Replacement Board | 4. Original
          • grimacelord
            • Jan 2017
            • 354
            Also, please disregard the first pic from post #1. Somehow I managed to slip in a completely different pic of a completely different TV. It's been a long week. Ugh. So please disregard that one pic - all of the other pics are of this TV I am currently working on.
            • grimacelord
              • Jan 2017
              • 354
              Could I have just received a bad mainboard? The more I am looking into it, the less and less it seems like a bad LCD panel. I have seen tab-bonding problems on HDTV's before and these lines that I have on this TV don't look like that. The lines only appear within an image on the display (like menus and logos, etc). They're not clearly visible across the black areas of the screen. In other words, they DON'T look like this:
              Is there anything I can troubleshoot on the mainboard? Could the LVDS cables be to blame for this?
              • vinceroger69
                • Mar 2012
                • 6714
                possible bad mainboard, im not sure if a bad t con could cause this fault? for now i would clean all of the ribbon cables and maybe the sockets too hopefully a more experienced member may of seen this issue before.
                • grimacelord
                  • Jan 2017
                  • 354
                  So, I cleaned out both the sockets to each connector between the LVDS cables and the ribbon cables going to the T-CON board as well as the pins on the cables themselves. Reconnected everything and now, there is no image displayed on the screen at all. Upon first power on after cleaning, the screen had a definitive line going right down the middle of the display where one side was lighter than the other side. I powered off and reseated the the TCON board cables and then no image displayed at all, but the line was gone.
                  Backlight lights up, but it remains black. So there is definitely an issue there with something. I notice that one of the LVDS cables between the mainboard and TCON board doesn't snugly "click" into place like the other one does. It seems off a bit. I tried gently pushing on them while powered on to see if pressure on the cable affected the image, but it didn't. Tried that on the TCON ribbons too and the ribbons going into the panel. Didn't change.
                  It was the ribbon cables to the TCON board that seemed to change the way it was displayed on the screen after getting that line down the middle and then reseating them and then it went away. Bad cables or bad TCON?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    well the lvds cable should fit nicely in the socket etc so you need too try and find if it the lvds lead or tcon socket at fault, or just order replacement lvds lead and tcon most ribbon cables as long as no damage i just use contact cleaner and a q tip on the gold pins, the sockets i just spray contact cleaner in and use air duster too blow the socket out/dry,
                    • Mirenia
                      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                      by Mirenia
                      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                      03-30-2025, 06:47 AM
                    • Devonavar
                      Vizio M43-C1 - How closely do I need to match the mainboard number?
                      by Devonavar
                      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                      So, I've ruled out the PSU for now.
                      The reboot loop...
                      08-14-2022, 08:46 PM
                    • maricm
                      Vizio P65 with P55 mainboard
                      by maricm
                      IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                      Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                      And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                      04-23-2024, 08:25 AM
                    • x_orange90_x
                      Vizio V585-J01 dancing lines and image doubling
                      by x_orange90_x
                      I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                      Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                      Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                      I swapped...
                      06-12-2024, 07:57 AM
