Sceptre 47” led screen problem
  • Georgia088
    • Sep 2014
    • 109
    Hello and thanks in advance. I have sceptre led e475bv. The screen started having a very noticeable green tint to it. This went on for several viewings. It just did it again except when I turned off and back on the screen came up with lines all over the place. Every now and then I can read something, but not often. This is in all inputs.
    Is there anything I can check or do to fix the issue?
    I have folllowed the advice from the forum and troubleshooted some TVs before. I'm hoping I can do the same with this one.
    Thanks!
    Re: Sceptre 47” led screen problem
    I would re-seat the cables between T-CON and the main board to see what happen.
    • Georgia088
      • Sep 2014
      • 109
      Thanks! However, reseating the connectors didn't seem to help. Is there anything else I can try or test?
      Thanks so much!
        Can we see the screen shot to see what the picture looks like on the screen?
        History of this TV before it went out?
        We also need the pictures of the whole backside of the TV showing all the boards.
        • Georgia088
          • Sep 2014
          • 109
          For several weeks the tv had really green tint to picture. Then one day after start up it went from really green tint to lines all over the screen. Every now and then you could make out an image. Now it looks like this:
          Also attached is back of tv that shows boards.
          Thanks again bud!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Disconnect one of the tcon ribbons going to the panel and power up. Do you have half a picture. Then replace the ribbon and repeat for the second ribbon.
              Originally posted by dick_barton
              disconnect one of the tcon ribbons going to the panel and power up. Do you have half a picture. Then replace the ribbon and repeat for the second ribbon.
              + 1
              • Georgia088
                • Sep 2014
                • 109
                Ok. I took the cable off of what i believe is tcon board. The first gray picture is with one ribbon disconnected. The second (more green) picture is with both rbbons disconnected.
                Thanks again!
                  So you have cable 1 connected cable 2 disconnected only and you get no image on half of the screen, so what do you get when cable 1 disconnected and cable 2 connected?
                  • Georgia088
                    • Sep 2014
                    • 109
                    I get no image on half the screen and vertical lines on the other half regardless of which ribbon I disconnect.
                    Thanks again!
                      Need to do Voltage testing at various test points of the T-CON board next, we will need good clear straight shot and well focused of the whole top side of the T-CON board to be able to see the test points.
                      • Georgia088
                        • Sep 2014
                        • 109
                        Ok. And to give you a little more info. If I disconnect cable one and connect cable two: the screen has no vertical lines on either side, but the screen is two different colors divide directly down the middle. If I connect one and disconnect two. The screen has vertical lines on left side and blank screen on the right. The screen is always blank on the right no matter what is connected.
                        Pictures of tcon are attached.
                        Thanks!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4536
                          • Italy - Milan
                          Test in Volt the TP: Vin, Vdd, Hvdd, Vgh, Vgl, Vcore, Vcc18.
                          • Georgia088
                            • Sep 2014
                            • 109
                            Thanks. Let me make sure I am understanding correctly. I should power on the tv. Put the black probe on the chasis and red on each of those points you have listed on the tcon board? Is this correct?
                            Thanks again!
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              yes thats correct
                              • Georgia088
                                • Sep 2014
                                • 109
                                Forgive me for being stupid but I don’t see thes points on the tcon. I have “vcom vcomr-fb vst vgh even, vghf, gckl6, gclk4 gclk2 and z out. Am I looking at the wrong thing?
                                Thanks!
                                  http://assets.shopjimmy.com/media/ca...753s-top_4.jpg
                                  Look for stuff with V in front, I see VGL, VGH, VCC18, ect. using shopjimmy's pictures.
                                  • Georgia088
                                    • Sep 2014
                                    • 109
                                    So get voltages of the things with “vs” on the board and post them back here?
                                    Thanks!
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4536
                                      • Italy - Milan
                                      Sorry but you're not stupid but blind, if u carefully watch at the board as i have done in few minutes you'll see, nobody chase you.
                                      • Georgia088
                                        • Sep 2014
                                        • 109
                                        Ok you are right. I am both blind and stupid. I was only looking up around where the ribbons connect. Sorry! But here is what I got
                                        Hvdd- 8.1
                                        Vin- 11.8
                                        Vcc18 - 1.6
                                        Vdd- 16.3
                                        Vgl- 4.8
                                        V core - 1.6
                                        Vgh - 27.9 (I am not sure I put the probe in the correct spot for this one. As there was no spot to check very near the writing. I chose the closest point.)
                                        I really appreciate y’all walking me through this!
                                        Thanks!
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
