Anyone know how to initiate IN-STOP on this TV? Wanted to restore all factory defaults before I make any further progression on this TV. I've done the audio file method but only was able to initiate EZ-ADJ and IN-START.
LG 55LW5600 Solarized Picture T-Con Board?
Tags: None
Re: LG 55LW5600 Solarized Picture T-Con Board?
Before doing anything like that I think you should open this puppy up and take some voltage measurements on the T-CON Bd. they are the Vgma voltages. -
Got it opened up, will report back soon with voltage readings.Last edited by tvfixer007; 07-27-2018, 10:39 AM.Comment
1 16.08
2 14.02
3 13.34
4 12.30
5 10.31
6 8.40
7 8.02
8 5.91
9 4.05
10 3.039
11 2.372
12 1.666
13 .981
14 .002Comment
After measuring voltages I powered up the TV and now there's just vertical lines all across the panel.Comment
Did you short out any thing? All the cables back in correctly? I think those readings are good, though. Anybody wants to concur on this?Comment
I re-seated all the video ribbon cables lines still present. Absolutely no picture is displaying. I was extremely careful measuring the voltages. Never know though I could have caused a short somehow. Since the problem is now worse than it was it had to be my touch. lolComment
At least no you know you HAVE to get that new T-CON Bd, now....Comment
I'm thinking my panel is shot. I do have a cracked panel from another 55LW5600 I parted out would it be wise for me to see if that panel displays the lines as well? There was enough picture on the right side of the screen that I believe it can help me rule out if the panel is messed up.Comment
That other panel wasn't stored in a safe place and has no picture at all now. Guess I'll order the t-con board and cross my fingers.
Thank you for the Help Andrew and Diif! Will post back when I get the t-con board replaced! Also have another TV with power supply issue. Will post a new thread for that one.Comment
Yes. Please do appraise us when you get the new T-CON Bd. Good luck.Comment
I tried that. Just got the new t-con board and the lines are still present.Comment
Edit: I didn't notice at first but with only the right side connected the left side of screen is a bit brighter than the right side.Last edited by tvfixer007; 08-01-2018, 02:42 PM.Comment
well that's quite a bit different than "I get nothing with either side disconnected." You would be wise to post some pictures of what you are actually seeing with various cable disconnect scenarios to remove any "misunderstanding". Ensure that you are feeding a good signal along with also trying different menu screens to see show as much about what is happening on the screen. My guess would be an SMD capacitor on the bottom edge board might be bad.... but that's going on very little. Where did you get your tcon from? what's history on the set that caused the first post (ie. solarization).Last edited by budwich; 08-01-2018, 03:01 PM.Comment
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by iglitareHi,
Or is it always a bad/shorted... -
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... - Loading...
