Much confusion over one Panasonic TCP50S2 board
  • GLE3
    • Aug 2013
    • 8
    Hoping there is still someone around that works on Plasma's and knows specifics about the 50S2... I bought one used with issues and want to replace the A board. Service manual says board model number is TXN/A1LQUUS. So, I look around and find a used pull from a working set(came from a TCP50C2 but said it was compatible). I get it home and the board is identical..., except for the ribbon cable mount. To of the three are a different size. My S2 are wider than the board I received. After looking on the internet, other companies are selling the same thing.
    https://www.tvpartstoday.com/TXN-A1L...sh-a1lquus.htm
    What gives? If i can attach a picture of my board I will but would anyone know the issue here? Did they make two different boards for the same model year? Thanks in advance for any help!
  • R_J
    • 9553
    Re: Much confusion over one Panasonic TCP50S2 board
    It is likely the board would work "electronically" but the cables are different, Your model has the connectors mounted on the other positions that are available when it was manufactured to be used with a different main and cables
    So main board and ribbons would also need to be replaced
    • notch8
      • Jul 2018
      • 63
      Hey GLE3
      On a side note, I too bought a used a board from tvpartstoday, last week, for my Panasonic plasma tv, Tc-p50s30. They sent me a board with the tuner jack ripped out! IMHO, I don't trust them. Luckily I went through eBay so if tvpartstoday won't refund my money, eBay is supposed to. I'm waiting for refund.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        There is a TNPAXXXX number that your board would carry. That is the number you are to match. Ask for a refund and get another board from a different supplier. Once you tamper with the board they will not give you a refund.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          +10
          • GLE3
            • Aug 2013
            • 8
            Originally posted by notch8
            Hey GLE3
            Thanks for the heads up on tvpartstoday, their reviews are limited out on Google.
            In my case would that be a TNPHXXXX number? From what I can tell they are the same....
              'TNPHXXXX' number is the Blank PCB (Printed Circuit Board) P/N not the PCBA (Printed Circuit Board Assembly) P/N.
              Blank board can be stuffed in many ways to make a bunch of different PCBA's as you can see from the board that you bought which uses the same blank board but it is stuffed with parts for other TV model..
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                +110. So the TNPH No. matches And yes that is blank PCB No.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                  by sam_sam_sam
                  After all of...
                  07-13-2024, 08:14 PM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
