Sony KDL-60EX500 5x blinks - is it TCON?
  • jason123
    • Oct 2015
    • 1040
    Hi Folks,
    Just need an opinion on an issue with a KDL-60EX500.
    The STDBY Red LED comes on and blinks 5x. Responsive to power button, and switches to Green LED.. then after a minute or so, goes back to 5x blinks red LED
    Going through the training manual https://www.badcaps.net/forum/showth...60EX500+blinks
    I see it's a TCON board or A board if replacing TCON doesn't fix it. Parts are really expensive on this board so I'd rather not start swapping out boards.
    One interesting finding is that if I disconnect the Panel from the TCON, though the 5x blinks still show, when I turn it on, I actually hear the chime and backlight comes on. Does that sound like a TCON board still?
    Last edited by jason123; 07-25-2018, 07:33 PM. Reason: Clarification of Post Title
    Re: Sony KDL-60EX500 5x blinks - is it TCON?
    Did yuo verify that you have 12VDC at both ends of the SMD fuse on the T-CON board with ref to the chassis GND?
    Pictures of what we are dealing with?
    • jason123
      • Oct 2015
      • 1040
      Budm... i don't see any fuses on the TCON board. Any idea where it is? Photo attached
      • jason123
        • Oct 2015
        • 1040
        Funny i see a F101 in photo and yes that's a fraction of an ohm (short)... 12 v is present on the TCon when the power button is pushed. If panel is connected to TCon the 12 V goes up then goes off. If i disconnect panel,v12 v is 12.54V and stayes on with backlight and chime
          Try this, disconnect both ribbon cables between the T-CON and the LCD panel and everything else connected back up the see what happen.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            +110.....Looks like a bad T-CON, though.
            • jason123
              • Oct 2015
              • 1040
              That's exactly what i tried. When i do this i still get the 5 blinks but when i turn on tv i hear chime and backlight comes on
              • budwich
                • Jul 2015
                • 3097
                you need to only disconnect one tcon to panel cable at a time.... no tcon to panel cables connected probably isn't going to do much other than just turn on backlighting.
                • jason123
                  • Oct 2015
                  • 1040
                  If I have either cable from Panel to Tcon connected, the System doesn't turn on backlight or play the chime sound. 12 V behavior is the same if either Tcon to Panel ribbon cable is connected as when both are connected. Meaning if I have 1 or 2 ribbon cable connected to panel, the 12 V tries to come up but shuts off immediately.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    Looks a lot like Sony rebadged a Sharp and the panel took a shit! WTF Sony?
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • jason123
                      • Oct 2015
                      • 1040
                      is it the panel you think?
                      • budwich
                        • Jul 2015
                        • 3097
                        doesn't sound good but you should check some of the smd components on the edge boards at the panel in and around where the tcon to panel cables connect. IF an smd component (resistor or capacitor) is shorted there, it will cause the system to shutdown as the draw will be too great. One other question, when trying only one cable connected, did you try to a "force startup sequence" as depending on the error counters, the set may never attempt to start normally.
                        • jason123
                          • Oct 2015
                          • 1040
                          budwich, I'm not sure I understood the last sentence. What's a force startup sequence? I searched both manuals I have and there is no mention of it. Thank you
                          • jason123
                            • Oct 2015
                            • 1040
                            Got the new TCON - Same issues.. and the panel green boards don't seem to have shorted caps. I'm thinking maybe internal panel short? Parting out - if anyone needs parts, let me know Thanks for the help
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              You gave up too easily. But better luck in the future.
                              • Hakuu
                                by Hakuu
                                Hi There,
                                More Details
                                TV Model - LG OLED77G1PUA
                                07-12-2023, 02:37 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • huj3r
                                Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                by huj3r
                                Hi there!
                                I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                Photo of the situation after the black shadow dissipates:
                                After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                > This indicates HFR Communication error. [ HFR Communication...
                                08-15-2023, 10:55 AM
