Viewsonic VT2430 fluctuating 5V rail
  • R_J
    • Jun 2012
    • 9515
    Re: Viewsonic VT2430 fluctuating 5V rail
    The reason I asked about what the final fix was is that you did not mention that you changed any caps in your first post, So that's why trouble shooting took the path it did.
    Had we known caps. were changed on the main board, and then the throbbing led fault occurred I'm sure this could have been repaired a lot quicker.
    That why if you replace parts and the fault is now different, go back and check what you did first, sometimes it is a very simple mistake that's overlooked, we have all done it.
    I remember having to repair electronics from other shops and it was a good thing they never used flux remover, the first part of trouble shooting was to see what the previous person did, repair that and then fix the original fault.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 908
      Well I did replace those 3 caps you suggested C101, C108 and C110 which were 1500uf, so I thought that maybe the others smaller 10uf were a problem. I checked the ESR and they were all over 4 ohms, and that is when I changed a few.
      Maybe that fixed it, but I also created a short on C218 which was the main culprit for our subsequent problems. I agree, I should have checked my soldering on that one but didn't.
      Anyhow it is fixed now, and tomorrow I will be recapping the entire power supply with better brand caps, and then it will be put back into service!
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
        by momaka
        03-15-2023, 10:17 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
        Wise Wing F199 19'' LCD monitor - recapped
        by momaka
        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
        When I saw the Craigslist post, I wasn't...
        08-24-2020, 10:58 AM
