LG 42LG50 no backlight or display
  • Daveleone
    • Apr 2016
    • 267
    Hi all! I have an LG 42LG50 that, when plugged in, shows a flashing red LED on the front, then the backlight flashes for a brief moment, then the front LED turns a very dim blue. (similar to this thread: https://www.badcaps.net/forum/showthread.php?t=52947)
    Here are the connector pinouts with [expected voltage when on]:
    P201
    (left pins)
    23 N/C
    21 BR1 [1.7v]
    19 PWR_ON [2.8v]
    17 ERROR [0v]
    15
    13
    11 [5.1v]
    09 [5.1v]
    07
    05 [12.3v]
    03
    01 [16.5v]
    (right pins)
    24 N/C
    22 PWM_DIM [1.4v]
    20 ON/OFF [3.2v]
    18 ACD [5v]
    16 GND
    14 GND
    12 5V [5.1v]
    10 5V [5.1v]
    08 GND
    06 12V [12.3v]
    04 GND
    02 16.5V [16.5v]
    P204
    01 24v
    02 24v
    03 24v
    04 24v
    05 24v
    06 0v
    07 0v
    08 0v
    09 0v
    10 0v
    11 BR1 [1.7v]
    12 ON/OFF [3.2v]
    13 PWM_DIM [1.4v]
    14 ERROR [0v]
    P205
    01 24v
    02 24v
    03 24v
    04 24v
    05 24v
    06 0v
    07 0v
    08 0v
    09 0v
    10 0v
    11 BR1 [1.7v]
    12 ON/OFF [3.2v]
    I've checked the voltages at the power supply during power on, during the time when the backlight flashes, and after the backlight flash. As a convention, if I've listed a single voltage, that means that voltage is stable throughout the startup process. If I list multiple voltages it means the voltage changes during the cycle, with the format Vpower on->Vbacklight flash->Vafter backlight flash. I've underlined the values I think are suspect.
    P201 (top to bottom)
    (left pins)
    23 0v
    21 0v->1.87v (but quickly drops to 0.66v)->3.3v
    19 2.8v
    17 0v->0v->3.3v
    15 0v
    13 0v
    11 5.2v
    09 5.2v
    07 0v
    05 12.5v
    03 0v
    01 16.1v
    (right pins)
    24 0v
    22 0v
    20 3.4v->1.7v->3.4v
    18 5.0v
    16 0v
    12 5.2v
    10 5.2v
    08 0v
    06 12.5v
    04 0v
    02 16.1v
    P204 (left to right)
    01 24.8v
    02 24.8v
    03 24.8v
    04 24.8v
    05 24.8v
    06 0v
    07 0v
    08 0v
    09 0v
    10 0v
    11 0v->1.6v (but quickly drops to 0.66v)->3.3v
    12 3.3v->1.7v->3.3v
    13 0v
    14 0v->0v->3.3v
    P205 (top to bottom)
    01 24.8v
    02 24.8v
    03 24.8v
    04 24.8v
    05 24.8v
    06 0v
    07 0v
    08 0v
    09 0v
    10 0v
    11 0v->1.8v (but quickly drops to 0.66v)->3.3v
    12 3.3v->1.7v->3.4v
    My thoughts and questions...
    • Based on the stable voltages at P201 pins 2,4,10,12, and 18, and at P204/205 pins 1-5, I think the power supply is ok.
    • I took apart the panel and was able to see all of the CFL tubes light up momentarily, so the CFL tubes themselves seem ok. (I've attached a 2 jpg sequence of the bulbs powering up)
    • Obviously, the 3.3v on ERROR (P201 pin 17, P204 pin 14) means something went wrong.
    • Why does BR1 (P201 pin 21, P204 pin 11, P205 pin 11) go to 1.7v, then drop to 0.66v, and finally become stable at 3.3v (expected stable value is 1.7v)?
    • Why does PWM_DIM (P201 pin 22, P204 pin 13) remain 0v? Why does it never rise to the expected 1.4v?
    • Why does ON/OFF (P201 pin 20, P204 pin 12, P205 pin 12) go to 3.4v, then drop to 1.7v, then go back to 3.4v (expected stable value is 3.4v, so maybe that's ok since it is eventually stable at 3.4v)?
    • How to figure out if the problem is the main board, the t-con, the CFL driver/ballast boards, or the LCD panel itself?
    What would you recommend as next steps in hunting down the source of the ERROR? As always, your help is greatly appreciated!
    Thanks,
    --Dave
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42LG50 no backlight or display
    Check the T-CON Bd. The little white fuse might be open due to a shorted component on the T-CON Bd. Are there a blue LED on the Inverter section that comes on and then go off? Also are there any blue LEDs coming on, on the T-CON Bd.?
      You need to remove those two black shield from the inverter boards so we can see what they look like and how they are setup.
      • vinceroger69
        • Mar 2012
        • 6714
        faulty inverter transformer causing two second to black fault?
        • neilc6
          • Nov 2015
          • 1550
          Though not the same model, check this thread https://www.badcaps.net/forum/showthread.php?t=62591
          • Daveleone
            • Apr 2016
            • 267
            Thanks for the replies! Somehow even though I subscribed to the thread I didn't get notified. Anyways, I'll take some pics of the inverter boards sans shields tonight and post them, and I will look for/check the fuse on the t-con. Thanks!
            • CapLeaker
              Leaking Member
              • 8188
              Check and compare the output winding of the ccfl transformers on the inverter board with your DMM in Ohm mode. They have to be within 3% of each other.
              • Daveleone
                • Apr 2016
                • 267
                Pics attached.
                Could you please point me to the points I should test in the attached photo?
                Andrew - In the attached picture is the correct fuse the one marked FP1 on the attached image? That fuse tests GOOD. I didn't see any LEDs turn on on either the T-Con or the Inverter boards. The only LED I see is a green LED on the main board. It stays lit as long as power is applied to the TV.
                Thank you all for all the help!
                --Dave
                • Daveleone
                  • Apr 2016
                  • 267
                  Are the desired test points the copper pads next to each CFL connector? If so, the resistance between those are all in the range of 3.28-3.31kohms.
                    1) All the fuses on both boards are good?
                    2) http://www.shopjimmy.com/cmo-27-d020...verter-kit.htm what Voltages do you have on all the pins of the connector CN1 when the backlights go off? You can see the pin label for each pin so you must report the pin name and follow by the Voltage reading for each pin.
                    • Daveleone
                      • Apr 2016
                      • 267
                      Just to confirm that I'm not missing any - there are 4 fuses on each board, right? They all test GOOD.
                      After BL shutoff...
                      CN1 (Master)
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      GND 0
                      GND 0
                      GND 0
                      GND 0
                      GND 0
                      Status 3.27
                      E-PWM 3.39
                      I-PWM 16.0
                      BLON 3.3
                      CN2 (Slave)
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      VBL 24.8
                      GND 0
                      GND 0
                      GND 0
                      GND 0
                      GND 0
                      NC 3.27 (not sure if this is ok?)
                      NC 3.39 (not sure if this is ok?)
                      • lookimback
                        • Aug 2013
                        • 1489
                        Disconnect the ribbon cable which connects the T-con to the inverter and see if the backlights will work.
                        ------------signature starts here------------
                        • Daveleone
                          • Apr 2016
                          • 267
                          They do!
                          With the ribbon cable from the master inverter to the T-Con disconnected, the backlight stays lit (The cable from the main board to the T-Con is still connected). Of course, there is no picture on the screen.
                          What does that mean? Does it mean the the Master & Slave Inverters are ok and we can narrow the root cause down to T-Con, Main Board, or LCD Panel?
                            +1
                            You need to also provide the pin name of that connector that goes to the T-CON board.
                            • lookimback
                              • Aug 2013
                              • 1489
                              Originally posted by Daveleone
                              They do!
                              I had an LG 42LB5D, which is very similar, and it worked the same. I think I replaced the T-con on mine, but it was so long ago that I can't remember. Someone with a bit more knowledge than me will probably be able to tell you how to determine if it's the T-con or the master inverter.
                              Main board is probably OK. Power supply is OK. Slave inverter should be OK. This narrows it down to T-con and Master Inverter.
                                That T-CON controls the dimming function.
                                Since you can remove that cable and able to get the light source to come on, so if the main board, t-con, and panel are OK then you should see pictures on the screen.
                                • Daveleone
                                  • Apr 2016
                                  • 267
                                  +1
                                  On the T-Con the connector is named CON1
                                  On the Master Inverter, I don't see a name, but the connector pinout:
                                  DIM_OUT
                                  GND
                                  GND
                                  GND
                                  GND
                                  GND
                                  DIM_IN
                                  E1
                                  budm, do you think the Master/Slave inverters are ok? Or could the problem still lie in the Master inverter? If it's for sure the T-Con, main board, or panel, how to determine which?
                                  Thanks guys! Making progress!
                                    If you can disconnect that cable to the T-CON board then the backlights come on and stay on then your inverters/lamps are OK. As I indicated, you should now see the pictures on the screen. You TV has what is called dynamic contrast, the T-CON controls the backlight level based on video scenes.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      I was able to find my repair notes and the TV I had ended up having dry solder joints on one of the main board wire connectors.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        I suggested looking at the T-CON Bd. in post 32 of this thread. I am still thinking the T-CON Bd has a problem. Yes, probably dry solder joints on the T-CON and Main Bds. as lookimback suggests.
                                        • Alain Renteria
                                          LG OLED77G2PUA Not Powering On After Storm
                                          by Alain Renteria
                                          Got it for free on marketplace because it stopped working after a storm.
                                          When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                                          The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                                          Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                                          11-25-2024, 11:11 PM
                                        • chrometsuba
                                          LG Television - 42LG50-UA
                                          by chrometsuba
                                          Hi Everyone,
                                          Trying to diagnose a TV that does not power on. The crystal clocking the main application processor looks suspect to me, I have attached a pic of what my scope is detecting on the crystal pins.
                                          This should be a 54mhz device, but obviously isn't running properly.
                                          Before I order a replacement part, is there anything else I should check that might be causing this erratic clock signal?
                                          Thanks...
                                          06-07-2021, 12:54 PM
                                        • dannysporea
                                          47LW6500 Debug Help - Power Board or Mainboard?
                                          by dannysporea
                                          My TV suddenly stopped working and when trying to turn on, just the standby lights come up and the screen does not light. I opened it and tried to debug based on a training manual I found on these boards for a similar TV, but the voltages do not match so I am not sure how to identify the problem. Here is some info:
                                          LG 47LW6500-UA
                                          Power Board: EAX62865401/8 / EAY62169801
                                          Main Board: LA12C / BCM35230 / EAX63969205(0) / EBT61399411
                                          So here is what I did so far:
                                          TEST1
                                          - Removed P502 on the main board
                                          05-01-2020, 01:19 PM
                                        • Seb932
                                          LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
                                          by Seb932
                                          i'would like to fix my not working LG 49UB850V tv.
                                          Symptoms:
                                          -AC plugged in, Standby LED not working
                                          -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
                                          Checked already:
                                          -Powersupply Output in Standby => 3.5V ok
                                          -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
                                          Any suggestions what to check next?
                                          Thanks in advance!
                                          09-14-2023, 06:28 AM
                                        • justice171
                                          Help Needed with LG TV Power Board Repair (Model No: OLED 55EG9A7V, Board No: LGP55B7-170P)
                                          by justice171
                                          I'm currently troubleshooting an issue with my LG TV (Model No: OLED 55EG9A7V, Power Board No: LGP55B7-170P) and would appreciate your guidance.
                                          When I press the power button, the standby LED flickers three times, and the relay clicks multiple times before stopping. During this time, I measured the voltages:
                                          • Over P201: I receive all the correct voltages.
                                          • Over P202: I only receive 12V, but the 24V is missing.
                                          The 24V is used to power the display board (Tcon) via the flex cable, but even when I disconnect the flex cable, the 24V is still not present....
                                          09-24-2024, 12:36 AM
