Insignia NS-32lcd washed out colors
  • nosaj
    • 53
    I have a Insignia NS-32lcd tv I recapped about 6years ago dumpster salvage.
    Recently the colors started looking washed out. Tried several different source inputs, cable, antenna, vcr, etc and they all looked washed out. Picture is sharp but colors faded. Any suggestions on what to possibly look at?
    Thanks,
    nosaj
  • neilc6
    • Nov 2015
    • 1550
    Re: Insignia NS-32lcd washed out colors
    AS15F failure on Tcon board. Post picture of your tcon to confirm.
      • 12330
      • U.S.
      Is that the full model number?
      • nosaj
        • 53
        Yes and it was made in 2004. It was recapped in maybe 2011. I'll open it up tonight and take pics of the TCON board.
        Thanks,
        Jason
          • 12330
          • U.S.
          Tcon here, looks like it's used in many model and brands, as always triple check the numbers and the numbers on the white sticker, in this ad you can plainly see the numbers on the sticker. https://www.ebay.com/itm/Akai-LCT320...AAAOSwceNZUvNj
          • nosaj
            • 53
            Here it is I believe.
            Thanks,
            Jason
              No that is not it. Please show the pictures of the whole back side of the TV showing all the boards.
              T-CON board will be under the metal shield.
              http://www.shopjimmy.com/catalogsear...gnia+NS-32lcd+
              • nosaj
                • 53
                So that would be the top left board?
                Jason
                  https://www.badcaps.net/forum/attach...8&d=1529195447
                  The LVDS cable on the right side of that board goes to the T-CON board which looks like under the metal cover that board is mounted to.
                  Big top left green board is the Main board.
                  Look at shopjimmy to see the board's names.
                  There are many version of this TV model.
                  • nosaj
                    • 53
                    Here's pics included. Would this board work?
                    https://www.ebay.com/itm/Chimei-V320...-/190872683394
                    Thanks,
                    Jason
                      • 12330
                      • U.S.
                        • 12330
                        • U.S.
                        • nosaj
                          • 53
                          First one I linked was 5 dollars and change, why didn't you grab it?
                          At the time I hadn't uncovered the Tcon board and what you linked didn't look like anything I could see. Budm told me where it was and once I uncovered it , it was gone.
                          What is the difference between v320b1-l01-c(what I have)
                          and V320B1-C03(what you linked to)?
                          Thanks for your help,
                          Jason
                            • 12330
                            • U.S.
                              • 12330
                              • U.S.
                              NOPE, wrong one.
                                • 12330
                                • U.S.
                                Jason
                                Was wrong board.
                                  • 12330
                                  • U.S.
                                  You need to look for the part number or substitute part number: Part Number: 35-D003848
                                  Substitute Parts: 35-D004737
                                    • 12330
                                    • U.S.
                                    Not all will work, a lot of them only have 2 ribbon cables, yours has 4.
                                      • 12330
                                      • U.S.
                                      NOPE, wrong one.
                                        • 12330
                                        • U.S.
                                        This should be a match: https://www.ebay.com/itm/Insignia-NS...oAAOSwWGxaz4rc
                                        • x_orange90_x
                                          LG 55UP7000PUA washed out and dim
                                          by x_orange90_x
                                          So I've got this 55UP7000PUA that has a very washed out and dim image. I've played with all of the settings, turned brightness to 100 as well as panel backlight, made sure no eco settings are on, etc. It looks like the backlight is at 50% or even less. I've been reading online that this is a pretty bad model with poor contrast and image retention issues, but I haven't seen anyone say it's dim like this. I've seen quite a few LGs with bad backlights before and they are usually blue. This doesn't appear blue, just washed out and dim. I've likewise never seen ANY backlights simply dim as a failure....
                                          11-07-2025, 05:43 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • silikon77
                                          Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                                          by silikon77
                                          Hi!
                                          Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                                          Found some advices watching youtube nad came up with this:
                                          It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                                          I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                                          See attached picture.
                                          I tried a few combinations to block individual clock...
                                          01-02-2025, 02:26 PM
                                        • mecha1166
                                          Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                                          by mecha1166
                                          I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                                          07-03-2024, 05:03 PM
