Insignia NS-32lcd washed out colors
  • nomoresonys
    • 12330
    • U.S.
    Re: Insignia NS-32lcd washed out colors
    This should be a match too, they are both from the same seller: https://www.ebay.com/itm/Akai-LCT328...kAAOSwkvdacOZZ
    • nomoresonys
      • 12330
      • U.S.
      There's a lot there to choose from, I just listed the cheapest first, just be sure you match Part Number: 35-D003848
      or
      Substitute Part: 35-D004737
      • nosaj
        • Dec 2014
        • 53
        ok it's on the way thanks so much for your help
        • nomoresonys
          • 12330
          • U.S.
          No problem, hope it solves the issue.
          • nosaj
            • Dec 2014
            • 53
            Putting it back together . The flat cable 8pin goes from the power supply to the invertor board about 15in maybe one end the plastic crumbled off so it's bare conductors I would like to find a replacement because I really don't want to put it back like that.
            Any suggestions where I might find one?
            Thanks,
            Jason
            • nomoresonys
              • 12330
              • U.S.
              #26
              https://www.ebay.com/itm/INSIGNIA-NS...AAAOSwu2VZZQSU
              • Fallen Wolf
                =3
                • Mar 2008
                • 7
                #27
                Originally posted by nosaj
                Putting it back together.
                It's been quite some time, did the new t-con board fix your issue?
                I'm having the same issue with the same model of display/t-con board being used, so I just ordered a new t-con board from China (searched for "V320B1-L01-C" on fleabay and found one for less than $10 including shipping, so I guess it's worth a try).
                I'll try to remember to post an update when my replacement t-con board arrives (might take 1-2 months tho due to shipping from China...).
                • nomoresonys
                  • 12330
                  • U.S.
                  #28
                  Ok, feedback is always appreciated, all I can do is assume that either the tcon or lvds cable fixed nosaj's tv, no feedback from him/her on that.
                  • nosaj
                    • Dec 2014
                    • 53
                    I was not able to fix it as other connector cables the plastic had endured some heat and the plastic crumbled on the connectors leaving the pins . I did not feel comfortable just putting the pins on there with no insulation between them and wasn't able to get another set of cables . so I tore it down for parts an diseminated them.
                    nosaj
                    • nomoresonys
                      • 12330
                      • U.S.
                      #30
                      Ok, sorry to hear, thanks for report.
                      • Fallen Wolf
                        =3
                        • Mar 2008
                        • 7
                        #31
                        Update: My replacement t-con board arrived today, but unfortunately it didn't fix my issue (same fault as before using HDMI).
                        Seems like I misdiagnosed my TV here as other analog video inputs aren't looking as bad as HDMI (I only checked HDMI cause that's what I have readily available as a signal source).
                        Lesson learned for me: Don't jump to conclusions and also test other signal sources as well.
                        I guess this is where I call it quits with trying to fix this TV here.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #32
                          Ok, so if hdmi is the only problem and your hdmi cable is confirmed good, probably only need a mainboard.
                          • x_orange90_x
                            LG 55UP7000PUA washed out and dim
                            by x_orange90_x
                            So I've got this 55UP7000PUA that has a very washed out and dim image. I've played with all of the settings, turned brightness to 100 as well as panel backlight, made sure no eco settings are on, etc. It looks like the backlight is at 50% or even less. I've been reading online that this is a pretty bad model with poor contrast and image retention issues, but I haven't seen anyone say it's dim like this. I've seen quite a few LGs with bad backlights before and they are usually blue. This doesn't appear blue, just washed out and dim. I've likewise never seen ANY backlights simply dim as a failure....
                            11-07-2025, 05:43 AM
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • cajoeg
                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                            by cajoeg
                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                            02-10-2025, 04:01 PM
                          • silikon77
                            Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                            by silikon77
                            Hi!
                            Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                            Found some advices watching youtube nad came up with this:
                            It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                            I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                            See attached picture.
                            I tried a few combinations to block individual clock...
                            01-02-2025, 02:26 PM
                          • mecha1166
                            Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                            by mecha1166
                            I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                            07-03-2024, 05:03 PM
