Westinghouse WD40FW2490 not powering up
  • R_J
    • 9588
    Re: Westinghouse WD40FW2490 not powering up
    .8 drain to source is is not good but it may not be the component that is shorted. Yes, center pin is connected to tab. Have you checked the large diode to the right of Q2054, also check the resistance across that large cap next to the diode. You could lift the source pin of that Q2054 but sometimes you can damage the transistor. so check the other parts first
    • Mr_Slim
      • Jun 2018
      • 23
      OK, in circuit, the big diode measures about 2.8 ohms in both directions. The same with the Cap. I pulled the diode (marked "HER304") and it still measures the same out of the circuit. The cap now measures more like a cap should, with the resistance changing as it charges/discharges.
      • R_J
        • 9588
        Looks like you found the problem, you can replace it with one thats a bit better like a HER306, HER307 or HER308
        • Mr_Slim
          • Jun 2018
          • 23
          One more step down the road...
          I replaced the HER304 diode with an HER308 and was still getting a short across it. I was able to lift the source leg of Q2054, which is an MDD14N25, and the short across the diode went away. With the source leg lifted, Q2054 was still a short between source and drain (the big tab), so I figured I might as well go ahead and order it. It finally arrived today (from the UK), and I installed it.
          I now get a Red light on the front panel once I plug it in, and hitting the power button gets me a Blue light. I now get 4.9V on the connector with the 5 volt pin and 11.9 on the connector with the 2 x 12 V pins, so Im making progress.
          I also can see that the led in the Toslink connector is also on.
          I'm still not seeing anything on the display when I try the menu or source buttons.
          What's my next step?
          John
          • Mr_Slim
            • Jun 2018
            • 23
            A quick little update.. I tried the "flashlight test" and I am able to see the Westinghouse W logo when it powers on and the Scanning channels menu, so it appears to be a backlight issue.
            • Mr_Slim
              • Jun 2018
              • 23
              Does anyone have any suggestions on the next steps in troubleshooting this issue?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                So what voltage do you have on the red and white lead going off to the backlights in standby and when you come out of standby?
                • Mr_Slim
                  • Jun 2018
                  • 23
                  I finally got back around to looking at this again.
                  The red and white wires on the black sleeved connector (in post #3), which I believe is the connector going to the backlight measure as follows to chassis ground:
                  Standby
                  Red ~ 2 V DC and slowly draining
                  White ~ 30 V DC (with several that were 40V ish..)
                  On
                  Red 12V DC
                  White 1.5V DC
                  Any suggestions would be appreciated.
                    • 12274
                    • U.S.
                    #29
                    Whats the voltage across the filter cap when powered on?
                      There is a lytic cap (KF printed on it) laying on its is side close to the LED connector, put meter probes on each leg of the cap to check the Voltage when TV is off and when TV is turned on, you must keep an eye on the meter to see how high the Voltage jumps up to when TV is turned on and then wait 10 seconds to see how low it goes down to.
                      • Mr_Slim
                        • Jun 2018
                        • 23
                        Ok.. got a little egg on my face.. after doing the measurements, I was putting the back cover on again, and I noticed a connector that was hanging loose, coming out of the back of the LCD display.. The backlight came on after turning it on this time, and I can get into the menu. I'll need to find a replacement remote, but I think I'm good.
                        Thanks everyone for your help!
                          • 12274
                          • U.S.
                          #32
                          Lol, I think we've all done that, more than once, good to hear its fixed.
                          • captainKKK
                            • Sep 2018
                            • 287
                            I have same curbside special model, board model ST6308RTU-AP1. Turning on only displays the Element logo. Do not have remote. Only the power button on the panel turns it on but not off. All inputs not tested, because cannot switch inputs using the panel buttons. Have plugged active VGA and HDMI with no change. Large cap 172 vdc before pushing power button. Large cap 165 after pushing power button on panel. Only normal ELEMENT logo shown with full back lights. CN2054 shows 12vdc and CN2055 has 5vdc. D2012 has 12.3 vdc between both legs and chassis when powered on, temp is 105F. Main aluminum heat sink has 98F. Any ideas?
                            • captainKKK
                              • Sep 2018
                              • 287
                              Example, see pic
                              • captainKKK
                                • Sep 2018
                                • 287
                                https://www.eserviceinfo.com/
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  You have a few voltage regulators on the mainboard you could check. What is the number on the top of the 8 pin iC near to U6? Possible EEPROM reading issue.
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • ShadowAi12
                                    ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                    by ShadowAi12
                                    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                    • The board enters a "ready to power on" state after plugging in the PSU.
                                    • Pressing the power button increases power draw.
                                    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                    Measurements:
                                    (taken after pressing the power button, while the board is attempting to start)
                                    • H_SKTOOC#
                                    06-11-2025, 01:05 PM
                                  • slimmy182
                                    MacBook M1 Pro 14" 2021 A2442 (820-02098) — U2020 getting hot, board not powering on
                                    by slimmy182
                                    I have a MacBook Pro M1 14” (board 820-02098) with a broken LCD panel (matrix damaged).
                                    The board does not power on — when connected to power it draws about 5.1 V / 0.474 A (~2.45 W) and stays at that level, with no fan spin or display activity.
                                    Using a thermal camera, I noticed that U2020 heats up to over 70 °C shortly after connecting power.
                                    According to the schematic, U2020 is a SN74AVC2T45RSWR (Texas Instruments) 2-bit bidirectional level shifter.
                                    There are no visible signs of liquid damage anywhere on the board.
                                    Given the broken LCD,...
                                    08-15-2025, 02:57 AM
