LG 65UH5500 Momentary Flash Of BackLights
  • Pitoniak
    • Jan 2017
    • 26
    • Usa
    #61
    Re: LG 65UH5500 Momentary Flash Of BackLights
    I have the same lg65uh5500 with these symptoms:
    Power tv on no lg logo flash and nothing shows with flash lite test.
    Power button flashes three times.
    Red lite on main bd.
    Led test 54.1v on all pins of led driver bd connector.
    Power bd has 90v on four pins 12.67 on three pins and 3.3v on stand by pin.
    Led driver bd connector to main bd show drive on and stand by .6v next two pins 12.67v.
    Removed fail wire to ps bd at connector no change.
    On main bd connector Has 12.67 on two middle pins And 3.3v on last pin.
    What should I check next?
    • Pitoniak
      • Jan 2017
      • 26
      • Usa
      #62
      [QUOTE=Pitoniak;937921]I have the same lg65uh5500 with these symptoms:
      • jjanssen7
        • Nov 2012
        • 252
        see post #49&50
        • Pitoniak
          • Jan 2017
          • 26
          • Usa
          #64
          Problem was the main board
          Was getting no “Drive on “
          voltage from the main board to the led driver board.
          R&R main board on line for $126.
          • Pitoniak
            • Jan 2017
            • 26
            • Usa
            #65
            Replaced all leds from shopjimmy, before replacing leds turned tv on with fail wire disconnected and all leds turned on. After replacing all leds I turned tv on with fail wire disconnected and now 4 strips on upper right doesn't turn on. Swapped led positions with known good leds and they won't turn on. Need the check wires to driver bd first. But this is all pointing to another main bd again? Is there anything else I need to do or test?
            I was not sure if that main bd I originally replaced was brand new!
              • 12206
              • U.S.
              #66
              Did you check that the strips lit up before you installed them?
              Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. :POOF:
              • Pitoniak
                • Jan 2017
                • 26
                • Usa
                #67
                Again I swapped the position in a known good position and they lit up
                • Pitoniak
                  • Jan 2017
                  • 26
                  • Usa
                  #68
                  Something is making all of these lg65uh5500 fail the same. I wonder if it is a defect main bd icu chip that lg is using or is something else. We know for fact the leds are crap. That’s way I replaced my leds with shopjimmys improved leds or so they say. Or maybe something on the led driver bd? Scratching head?
                  • jjanssen7
                    • Nov 2012
                    • 252
                    They are overdriven. There are 6 circuits on your LED driver board. I've had some success lowering the power output at the driver board and turning down the backlights in the service menu. No comebacks on the 5 or 6 I've done like that so far.
                    • Pitoniak
                      • Jan 2017
                      • 26
                      • Usa
                      #70
                      That’s the first thing I did when I replace the main bd is lower the the back lites . I think that is the main reason why thiese tv fail when new customers don’t turn back lites down.
                      Question how did you lower the power out put?
                      • jjanssen7
                        • Nov 2012
                        • 252
                        https://www.badcaps.net/forum/showth...light=65uh5500
                        See post 18&19 of that thread and adjust for your tV. yours have 6 LED drivers, so you will be removing 6 caps. That thread was for the 50" version of your tv.
                          Originally posted by Pitoniak
                          That's the first thing I did when I replace the main bd is lower the the back lites . I think that is the main reason why thiese tv fail when new customers don't turn back lites down.
                          Show us good clear straight shots of the whole top and bottom side of the LED driver board.
                          • Pitoniak
                            • Jan 2017
                            • 26
                            • Usa
                            #73
                            Originally posted by budm
                            The 7.5vDC for the 13V STBY may be normal in standby mode, since there is no separated standby power supply so they may keep the Voltage low just enough to run the main board, and when PS-ON is present and then the PFC Booster circuit kicks in then the 13V and the 80 will be normal.
                            That is why I ask OP to see what DC V he has on the main filter cap since the PS-ON is present.
                            Where is the main cap or what is the uf of the cap you are talking about??
                            • Pitoniak
                              • Jan 2017
                              • 26
                              • Usa
                              #74
                              Lg65uh5500
                              What I finally found out about this tv's failure is the led connector to the led power board plug in connection is a bad wire connection to the led power board pins. I removed each wire from the connector and carefully crimped them tighter.
                              I did replace all leds with a set from shopjimmy previously. I too was getting a group of 4 leds strips not lighting up after replacement. That was caused by the bad connector pins connection. I also decided to do the resistor mod on the led power board and tested about 53.1volts with led tester on each set of pins on the led connector.
                              FYI…You can power up this tv by disconnecting the fail wire at the power board connector. And then trouble shoot.
                              Hope this help others in troubleshooting this tv.
                              • ekozeko333
                                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                by ekozeko333
                                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                🔥 The Problem Started After Suspected ESD/PD Fault
                                I experienced a power issue or ESD event through a USB-C charger
                                After that, the NX20P5090 power switch was visibly burned and was replaced
                                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                🧠 What I’ve Done So Far
                                Flashed...
                                06-21-2025, 02:48 AM
                              • corrize
                                Nikon D800 camera - flash don’t work and capacitor don’t charge
                                by corrize
                                Hello, I'm stuck in troubleshooting…
                                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                10-01-2022, 10:02 AM
                              • philtvman
                                LG 65UH5500 Momentary Flash Of BackLights (Occasionally)
                                by philtvman
                                Had the issue where the screen flashes for a second when plugged in, but turns off instantly. It won't do it again until the power is dispersed from the boards (unplugging and holding power button down). Figured it was likely just a bad LED somewhere based on the symptoms and other threads I found here. When watching it flash, it was clear there were a couple strips not coming on at all.
                                I cracked it open to check the LEDs and every one of them turned on with the tester (which was pretty annoying to be honest). I plugged the set in with the dispersion panels off to see exactly which...
                                03-05-2019, 09:34 PM
                              • JunkmanJimbo
                                RCA led50b45rq tv backlights flash then shuts down
                                by JunkmanJimbo
                                First of all I looked at the other posts on this model but didn't really see a solution. This is where I am so far. I have replaced the power supply and the mainboard (both used). I'm still having the same problem. The tv standby light comes on, I push the power button, the backlights flash and the tv shuts down. The tv can't be turned off unless I unplug and reconnect the power cord. I have tested the backlight strips with an LED tester and all of them are working fine. I can unplug the led connector from the power supply and the tv turns off and on like it should. Also with it unplugged, and...
                                05-23-2022, 04:07 PM
                              • abajor
                                Canon VIXIA HF S10 A read data from inernal flash memory.
                                by abajor
                                Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                I think my best shot is to figure out a way to read the internal flash memory outside...
                                07-20-2024, 12:04 AM
