LG 65UH5500 Momentary Flash Of BackLights
    Re: LG 65UH5500 Momentary Flash Of BackLights
    BTW, does this TV has WiFi since it is smart TV?
    If it does, what happen if you disconnect it?
    • nomoresonys
      • 12274
      • U.S.
      Originally posted by budm
      The 7.5vDC for the 13V STBY may be normal in standby mode, since there is no separated standby power supply so they may keep the Voltage low just enough to run the main board, and when PS-ON is present and then the PFC Booster circuit kicks in then the 13V and the 80 will be normal.
      That is why I ask OP to see what DC V he has on the main filter cap since the PS-ON is present.
      This would explain a lot of half voltage readings we have been seeing here on lots of posts.
        Since you indicate that the Backlights did flash on for seconds, then you should unplug the TV and put black probe on the chassis, keep red probe on the 80V pin then plug the TV in and watch to meter to see if it jumps up to 80V or not, repeat the same test on the DRV_ON pin.
        • nomoresonys
          • 12274
          • U.S.
          Could try force on power supply to see if the 13 comes up, need to unplug from mainboard before test.
          • Michale32086
            • Nov 2011
            • 1453
            BTW, since you do have PS-ON, what DC Voltage do you have between the two legs of the main filter caps?
            390v
            An 80v pin on the DRIVER board does jump to 80V and then drops to 55V...
            The DRV ON pin "jumps" to 50mV, then goes haywire but never above 1V and then holds steady at .9V
            No change after disconnecting the WiFi adapter..
            • Michale32086
              • Nov 2011
              • 1453
              Hmm, try unhook leds, then see if tv turns on and off with power button.
              With the LED array unplugged, the TV still won't stay off..
              Either by using the remote or holding the power button til shutdown...
              The TV always comes back on...
                You have main board problem at this point, you should be able to turn off the TV if the power control function of the main board is good.
                Usually if there is error signal such as bad T-CON, Backlights circuits, etc, the main board will be forced off, yours is stuck on.
                • Michale32086
                  • Nov 2011
                  • 1453
                  Originally posted by fcisolutions
                  Do you think it is the mainboard or the driver board. I am getting the same issue. Can you get any sound .
                  Haven't gotten any sound, but I am likely on an input other than TV so I wouldn't expect sound...
                  Let me see if I can switch it to TV and get a static sound..
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Yea, I'm beginning to think it's a Main board problem too..
                    I could have swore I checked and saw it had a latent image.. But I get one of the backlights on using my LED Power thingy and power up the TV and get no image at all...
                    That seems to seal the idea that it's a main board issue...
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Found a replacement Main Board for a decent price...
                      Will follow up, once it arrives..
                      Thanx to all for the assistance and advice...
                      • nomoresonys
                        • 12274
                        • U.S.
                        #31
                        Ok, was mainboard test, mainboard failed.
                        • Michale32086
                          • Nov 2011
                          • 1453
                          That's my guess as well.. I'll know in a few days
                          Thanx again..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            And the plot, as they say, thickens...
                            I got the replacement Main board in...
                            Hooked it up and powered up the TV.... Same problem.. LEDs flashed for a second and then went off... :^(
                            Something weird happened though... In the brief moment where the LEDs were on, half the display panel was white and the other half, I *thought* I saw the regular LG start up graphic...
                            The white part of the panel indicated to me that the TCON board connector was not inserted properly..
                            Powered everything down and inserted the TCON connector properly..
                            Still have the momentary flash of the LEDs, but now there is nothing on the display panel.. Not even a latent display..
                            So, now things are exactly as before.... Nothing on the display panel, not even latent'ly... And only a momentary flash of the LEDs... And, I should note, the TV cannot be turned off...
                            As much as I hate to do it, I am thinking I am going to have to crack open the display panel and check the individual LED strips..
                            Bumper...
                              OK, I am confused, in post #1 indicated the Display is fine just no backlights,so what happen if you put old main board back in?
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Yea, I might have been mistaken about that initially...
                                Subsequently (a few days ago) I used my LED Power Supply to turn on a segment of the LED Array and then powered up the TV but I never got anything on the display...
                                So, either I just assumed that I got a display image based on my assumption it was an LED strip issue (possible)... Or I actually did have a latent image initially and my subsequent tinkering frak'ed that up (equally possible)...
                                I am leaning more towards I made a wrong assumption....
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  If I got a latent image, then a bad LED strip would make sense..
                                  But not getting a latent image makes me lean towards a bad MAIN board.. Or, should I say ANOTHER bad MAIN board.. Which is possible, I spose...
                                  Is there a way to jumper or short some connections on the Driver/Power board to force the LEDs on?? Leaving the MAIN board totally taken out of the loop???
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Ohmigod!!! Ohmigod!!!
                                    In an effort to confirm once and for all that the LEDs are not the problem, I hit on the idea of taking each pair of wires off of the DRIVER connector and place them on the DRIVER board one pair at a time..
                                    Each pair gave me the same thing.. An LED strip/area came on then flashed off... So, that told me that the LED array is NOT the problem..
                                    After I had tested the last pair, I put them back into the connector and then plugged the connector back into the DRIVER board...
                                    Powered up the TV and, I'll be at some beach, the LEDs came on and stayed on!!!!
                                    I thought to myself, I said, "Self!? Well, ya fixed the LED issue, but you still don't have an display.."
                                    And, some beach again, I sure had a display!!!???
                                    Apparently, it's all linked together.. You can't have a display if the LEDs aren't coming on and staying on...
                                    So, not one to look a gift horse in the mouth, I am gonna count this one as a win!!
                                    Thanks again to all who helped out...
                                    • nomoresonys
                                      • 12274
                                      • U.S.
                                      #38
                                      So it was just a loose connection on the led wires?
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Apparently so... I physically pulled the wires from the DRIVER board connector and then replaced them after testing..
                                        I can only assume that on wire wasn't seated properly and/or wasn't making a good enough contact with the plug...
                                        Sometimes it's the simple things..
                                        • Michale32086
                                          • Nov 2011
                                          • 1453
                                          I don't think your problem and my problem are the same..
                                          One way to confirm that is to take a powerful flash light and shine it into the screen at an angle...
                                          Turn the TV on.. If you see a latent image, then your problem is likely a bad LED strip... Those are a major bear to change, but is doable if yer careful..
                                          If you don't see a latent image, then the problem is likely one of the boards. Most likely the Main Video Board..
                                          If it IS a Main Board issue and if I can confirm that my old Main Board is good, I'll be happy to sell you the replacement board I got (which I know works fine) at the cost I paid for it...
                                          • ekozeko333
                                            by ekozeko333
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • philtvman
                                            LG 65UH5500 Momentary Flash Of BackLights (Occasionally)
                                            by philtvman
                                            Had the issue where the screen flashes for a second when plugged in, but turns off instantly. It won't do it again until the power is dispersed from the boards (unplugging and holding power button down). Figured it was likely just a bad LED somewhere based on the symptoms and other threads I found here. When watching it flash, it was clear there were a couple strips not coming on at all.
                                            I cracked it open to check the LEDs and every one of them turned on with the tester (which was pretty annoying to be honest). I plugged the set in with the dispersion panels off to see exactly which...
                                            03-05-2019, 09:34 PM
                                          • JunkmanJimbo
                                            RCA led50b45rq tv backlights flash then shuts down
                                            by JunkmanJimbo
                                            First of all I looked at the other posts on this model but didn't really see a solution. This is where I am so far. I have replaced the power supply and the mainboard (both used). I'm still having the same problem. The tv standby light comes on, I push the power button, the backlights flash and the tv shuts down. The tv can't be turned off unless I unplug and reconnect the power cord. I have tested the backlight strips with an LED tester and all of them are working fine. I can unplug the led connector from the power supply and the tv turns off and on like it should. Also with it unplugged, and...
                                            05-23-2022, 04:07 PM
                                          • spmetroil
                                            Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                            by spmetroil
                                            I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                            The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                            I have a CH341A programmer and I already attempted the following steps:
                                            1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                            2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                            3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                            08-19-2025, 09:23 AM
