Samsung un48js8500
  • Martin0101
    • Feb 2018
    • 21
    Samsung un48js8500
    I have a samsung tv un48js8500 that when i plug it to the power outlet o get a black screen but the standby light blinks 6 times.. I switched the tcon and main boards and still have the same issue. If i disconnect the main board from the power board i get nothing but the clicking on the power board.. if i disconect the tcon from the power board i get backlights on and standby light blinks.. anyy helpp
    Re: Samsung un48js8500
    For us to help we will need good clear pictures of the whole backside of the TV showing all the boards, and the straight shot pictures of the whole top and bottom side of the power supply board so we can read the printed texts on the board.
    It is hard to do long distant troubleshooting without seeing what we are dealing with.
    What is the history of the TV? Any works were done to the TV before?
    The more details we get the better chance of finding the cause of the problem.
    What is the power supply board P/N? BN44-?????
    • Martin0101
      • Feb 2018
      • 21
      Power supply board number is BN44-00833A
      • Martin0101
        • Feb 2018
        • 21
        Pic
        • Martin0101
          • Feb 2018
          • 21
          Power board
          • Martin0101
            • Feb 2018
            • 21
            Tcon
            • Martin0101
              • Feb 2018
              • 21
              Main board
                So you remove just the small cable from the T-CON to the power supply board the backlights come on and stay o, correct? That means at least the LED backlights and the LED driver and the power supply for the backlights circuits are OK, and at this point you can turn the TV on and off without problem, right?
                That small cables from T-CON provide the backlights dimming control so it sounds like those control signals from T-CON are stuck low ( you can verify by checking those PWM pins DC Voltages on the power supply board with and without the connector CN9003 in place.
                Did you also try replacing just the T-CON board only without replacing the Main board?
                • Martin0101
                  • Feb 2018
                  • 21
                  Yes backlights come on when i remove the small cable fron tcon to power board.. but here is another problem.. i cant turn on or off the tv doing this steps... yes i try first just replacing the tcon and had the same problem.. so thats when i decided to get a new main board and still the same
                  • Sleddriver
                    • Sep 2010
                    • 32
                    OP: I'm currently working on a 48J5000 set, with a BN44-00852A PS. Yours is much more robust than mine! No doubt due to being an 8000 series rather than a 5000.
                    • Martin0101
                      • Feb 2018
                      • 21
                      How do i know what the problem is ?
                        • 12181
                        • U.S.
                        Pics. are out of focus.
                          • 12181
                          • U.S.
                          http://www.shopjimmy.com/samsung-bn4...wer-supply.htm If your board matches, test all pins on CNM803, theres a legend/map located just below the big number 48 on the board, tells you what the pins are, test in standby and when you hit the power button, report both conditions, example pin 13-A13v, 0 v standby, 13 v tv on, something resembling that, meter set at 20 vdc, black probe to ground, chassis of tv is ok, red probe to pin.
                          • Martin0101
                            • Feb 2018
                            • 21
                            I have already bought new power board maind board and tcon board and same problem
                              • 12181
                              • U.S.
                              Here's the test you need to do, nobody can help you if you can't follow simple test procedures.
                                • 12181
                                • U.S.
                                Where did you get these "new boards" from?
                                  • 12181
                                  • U.S.
                                  Here's the test you need to do, nobody can help you if you can't follow test procedures.
                                  • Martin0101
                                    • Feb 2018
                                    • 21
                                    I get them from ebay
                                    Okie i will do that
                                    • Martin0101
                                      • Feb 2018
                                      • 21
                                      Okie i will do that
                                        • 12181
                                        • U.S.
                                        Ok, so their "new" from ebay possibly "used boards" that's why they need to be tested.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          09-07-2024, 05:50 AM
                                        • valvashon
                                          Samsung UN65KU6290F PS board blows fuses
                                          by valvashon
                                          Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                                          Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                                          11-27-2023, 01:09 PM
