Samsung UN65KU6290F PS board blows fuses
  • valvashon
    • Oct 2020
    • 108
    Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
    Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged the TV in. Still nothing on the board looks burnt or melted. Nearly a dead short when measured (post fuse blow) across the + and - terminals of the bridge rectifier. Shouldn't be too hard to find what has shorted out but if anybody has any ideas I'd appreciate them. Pretty sure it's a power supply board problem given the explosive way the test fuse blew immediately upon power being supplied to the board.
    Did a search on here finding some problems with the larger Samsung UN series of TV's but nothing like this.
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Check qm801cs/802 and see if they read shorted. Known defect in other boards, try it out
    • valvashon
      • Oct 2020
      • 108
      I was going to check all the TO220 devices today anyway but thanks for the heads up on the problem MOSFET devices. QP802CS is the shorted one, dead short across all legs. Others check OK but I will replace its companion QP801CS. Do we know if it's the brand of the MOSFET Samsung used (MagnaChip) or is the design of the board just hard on whatever MOSFET is in there? DigiKey carries Infineon Technologies MOSFETs and I will cross to one of those and just shotgun all 4 MOSFETs on that board if the MagnaChip ones are problematic.
      Again, thanks for the help!
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Not sure on answer, but yes replace both. Apparently a common failure. Then replace fuse and might be good to go. Make sure after replacing to check those blue caps around it also, if you have them might be good idea just to change them
        • lotas
          • Jan 2016
          • 4845
          • Russia
          If these mosfets burned out, then the PWM that controls them was probably also damaged and you need to look at all its wiring (smd low-resistance resistors, diodes, zener diodes...) they are located on the back side of the board. If you do not replace them, the new mosfets transistors will burn out instantly.
          • valvashon
            • Oct 2020
            • 108
            The only other component that I have found that failed (besides the one MOSFET) was the common cathode dual rectifier just ahead of the MOSFETs in the circuit. One side/diode was shorted corresponding to the shorted MOSFET.
            I have ordered the dual rectifier from eBay as I did not find a good cross at Digi-Key. That part number is SF10A600HPI by AUK. The Digi-Key cross was electrically compatible but in a larger case that would have required board and heat sink modification.
            I did find an acceptable substitute for the MagnaChip MOSFET at Digi-Key. The part number is Infineon Technologies SPA11N60C3XKSA1.
            Fuses are Littlefuse 0215008.MXESPP, 8 amp ceramic slow blow.
            I have ordered extras of all of these in case it's more than the MOSFETs and the dual rectifier. I put down the part numbers in case it helps another Bad Caps member in the future.
            Dual rectifier will be here at the end of December and I will post again with the results then.
              • 12328
              • U.S.
              Simple to make dim bulb tester/current limiter, saves you from burning up components and fuses: https://www.youtube.com/watch?v=SKK6...W-EQh9LrN5i5YC
              • PontyPCs
                • May 2016
                • 16
                • United Kingdom
                QM801 and 802 are the PFC boost. Check the gate feed resistor and diode before replacing and powering on
                • valvashon
                  • Oct 2020
                  • 108
                  Click image for larger version  Name:	IMG_3907.jpg Views:	0 Size:	2.72 MB ID:	3170004
                  Click image for larger version  Name:	IMG_3906.jpg Views:	0 Size:	2.10 MB ID:	3170005
                  Click image for larger version  Name:	IMG_3909.jpg Views:	0 Size:	1.31 MB ID:	3170006
                  This TV is working again after a sum total of $7.86 worth of components, two FET's, a dual diode and a fuse. Of course I had to or did order extras and will be stashing some of those inside of the TV in case it happens again or some of the othiser FET's fail. The part numbers I used as replacements are listed above.
                  Thanks to everybody for their help on this. I am hoping that the information in this thread will help others in the future.
                  Val
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    Thx for reply.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                      09-07-2024, 05:50 AM
                      Surface Mount Fuses Fundamentals Datasheet
                      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                      10-07-2024, 06:07 AM
