Panasonic th-58pz700u 1 blink, help plz
  • woodie21516
    • May 2018
    • 3
    I have a 2008 th-58pz700u plasma that I love. It recently decided to turn on and then turns off after about 5 seconds. If I unplug the power cord from the wall and plug back in the TV will turn on automatically and then turn off after 5 seconds. The front LED power light blinks 1 then 3 seconds later blinks again 1 time. I replaced the DG board with a working DG board and I get the same symptoms. If I press the front power button for 10 seconds and power it on, it does the same thing, instead flashes 12 times. So I replaced the H board. This is all according to the service manual.
    Was curious if anyone has any other options you would recommend. I did order a new D board as that will be the next board I am going to replace.
    Thanks much for any help you can provide.
    Todd
  • woodie21516
    • May 2018
    • 3
    Re: Panasonic th-58pz700u 1 blink, help plz
    The troubleshooting diagram actually doesnt make sense to me. I attached the diagram.
    I unplugged the d3 connector from the D board. I plug in the tv and it automatically turns on, but there is no power light. The part I dont get is the second part of the question. "No raster with SC and SS LEDS on"? I search high and low on the two boards and I dont see any led lights, which I assume would be pretty obvious. So YES the tv turns on automatically, but NO leds on the SC and SS board are on. So do I goto to the Yes or No part of the diagram. If I choose Yes, well I already replaced the DG board. If I say no, replace the D board, which is on order right now.
    To me the question is asked very oddly.
    Todd
    • aaronwt6
      • Apr 2013
      • 855
      • US
      I just wanted to chime in and let everyone know that I sent Todd over for some advice after he purchased the replacement DG board from me and was unsuccessful with the repair. The H board came from elsewhere but attached is a picture of the TV I had here that the DG board was removed from. It had only local screen defects on the upper portion and I ran the TV for multiple hours prior to selling the boards. The D board came from this as well. Hopefully some of the plasma guru's have an idea as I was confident from the flow diagram that the DG board was going to take care of it.
      Thanks,
      Aaron
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Just wanted to let everyone know that the problem was remedied with the replacement of the D board. All's well that ends well.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Another D board or the one you sold?
          • aaronwt6
            • Apr 2013
            • 855
            • US
            The one he bought from me. His original DG board as well as the one I sold him were both functional.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • tiku
              Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
              by tiku
              Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
              I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
              09-05-2021, 05:02 AM
