Samsung 460CXN - Power Supply Issue
  • R_J
    • 9514
    Re: Samsung 460CXN - Power Supply Issue
    QP802s and QP801S are basically switches, they are turned on and off by the signal on their gates (pulsed at 65Khz) They are normally open.
    Turning them on and off causes the voltage on this side of TM802S coil to be boosted from 160 volts supplied by the bridge to around 300 volts dc across CP810/CP817
    Since the bad fet is shorted to the gate it might be wise to also replace UP801
    • pantherts
      • Mar 2009
      • 73
      Resistance between source and drain on QP802S is an OL.
      • pantherts
        • Mar 2009
        • 73
        Okay, I understand now. That makes sense. Thanks so much for the explanation.
        • pantherts
          • Mar 2009
          • 73
          Any way to reliably test UP801 in power off mode to see if it's shorted inside?
          • R_J
            • 9514
            got a scope to check the output pulse? it might be ok but if it is not you could blow the fets or the supply just won't work
            • pantherts
              • Mar 2009
              • 73
              Nah, no scope available. Alright, I'll get an order together. Thanks so much for your assistance with this. I'll check back in again.
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • Nicktronic
                Samsung Power Supply Board BN44-00874F
                by Nicktronic
                Hey everyone,
                This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                Anybody...
                03-17-2025, 06:20 AM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • C152Heavy
                by C152Heavy
                Summary for TL-DR readers:
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
