Samsung 460CXN - Power Supply Issue
  • R_J
    • Jun 2012
    • 9588
    Re: Samsung 460CXN - Power Supply Issue
    QP802s and QP801S are basically switches, they are turned on and off by the signal on their gates (pulsed at 65Khz) They are normally open.
    Turning them on and off causes the voltage on this side of TM802S coil to be boosted from 160 volts supplied by the bridge to around 300 volts dc across CP810/CP817
    Since the bad fet is shorted to the gate it might be wise to also replace UP801
    • pantherts
      • Mar 2009
      • 73
      Resistance between source and drain on QP802S is an OL.
      • pantherts
        • Mar 2009
        • 73
        Okay, I understand now. That makes sense. Thanks so much for the explanation.
        • pantherts
          • Mar 2009
          • 73
          Any way to reliably test UP801 in power off mode to see if it's shorted inside?
          • R_J
            • Jun 2012
            • 9588
            got a scope to check the output pulse? it might be ok but if it is not you could blow the fets or the supply just won't work
            • pantherts
              • Mar 2009
              • 73
              Nah, no scope available. Alright, I'll get an order together. Thanks so much for your assistance with this. I'll check back in again.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                After all of...
                07-13-2024, 08:14 PM
              • Nicktronic
                Samsung Power Supply Board BN44-00874F
                by Nicktronic
                Hey everyone,
                This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                Anybody...
                03-17-2025, 06:20 AM
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
              • notallbad
                TCL 55RP620K power board issue
                by notallbad
                Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                0% p_dim at 1.65v and a_dim at 1v
                50% p_dim at 3.3v and a_dim at 1.65v
                100% p_dim at 3.3v and a_dim at 2.88v
                Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                Leds are 2 rows of 15 6v leds.
                On inspection of the power board found diode MBR3200 shorted so replaced with...
                07-12-2025, 05:45 AM
