Sony Vizio E601i-a3, logo comes up then light blue screen
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    I have yet to obtain this TV but the report is the logo comes up when it's turned on then goes to a light blue screen. I'm more looking for an idea of what may be up than a solid diagnosis.
    I have a Vizio E601i-a3 with a broken screen for parts. I'm not sure the parts in that TV are relevant but I'm inclined to go look at this thing just for that reason.
    So would anyone have any ideas what to look for?
    They call me......."threadkiller"
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony Vizio E601i-a3, logo comes up then light blue screen
    With the 'little' information given, I would say T-CON Bd., Panel or Main Bd. in that order.
      So is it Sony or Vizio?
      Try to find out what the history of the TV as to what happen before it went bad, anyone try to fix it before, anyone try to do an update FW and then it failed, etc.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        t-con was replaced, those panels look like they are kinda crappy from what I hear.
        Well actually I bet its a Funai. Report: TV was working, went in to brush teeth, came back out and no picture. T-con replaced and nothing changed. No firmware updates applied. Problem is constant.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          I'll be going to look at it tomorrow and I'll know more then. Just glad to know it could be a display issue. Thanks for letting me know that!
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            And it looks like the only thing Funai and Vizio have in common are lawsuits. Sheesh
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              If replacing the T-CON Bd didn't return picture then I would say it 90% bad panel, which might be fixable as there are some ceramic caps on the long panel board/s that short out and blank the picture information.
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                Re: Vizio E601i-a3, logo comes up then light blue screen
                Thank you for that! Is there any way to confirm that easily in the field, like disconnecting one of the ribbon cables out of the t-con or something?
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  Looks like I'm on my own, guess I'll do the best I can.
                  • budwich
                    • Jul 2015
                    • 3097
                    you can always try this... is it easy "in the field"... guess that depends on how much space you have.
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      I think space will be OK. I'm not sure if I'll do that or not, depends on the problems that present and the price for the unit. If its super cheap I'll probably wind up with it anyways.
                      Thanks budwich for the reply.
                        To do any inspection at your bench or out in the field you will have to:
                        1) Do good visual inspection on all the boards, top and bottom side, see if all the connectors are in correct place or not and if they are seated properly.
                        2) See if any modification was done.
                        3) Verify if the correct parts were installed by the seller or not, and if the parts are actually good.
                        4) Check Voltages, which means you have to know how the TV works.
                        5) Go on line to see what the common failure or complaint it has on that particular model.
                        6) Go to shopjimmy to see how much the replacement boards will cost and if they are available.
                        7) Etc.
                        It is not simple if you really try to figure out if you will want to buy that broken TV to fix or not.
                        So basically you are on your own once you go out there in the field, but it is matter of common sense and from building up the experience, like I always said ' You can not be really good at something until you learn and understand the basic first'. People ask me to to teach them how to fix TV but they do not even know what the Diode, Transistor, MOSFET are or how they work but want to jump into repairing the TV down to component level without knowing how to TV functions let alone how to use the meter properly.
                        BYW, safety is the FIRST priority.
                        • budwich
                          • Jul 2015
                          • 3097
                          X2.... isn't that why the internet is here... every one can become an "graduated technician"... :-)
                          I am actually surprised that there aren't more reports of electrocuted DIY'er wannabes in the news.
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            It has a bad panel. I did not buy it. For now I'll stick with the cheap and freebie stuff and try not to have a shocking experience.
                            You all helped me make a good decision here and for that I thank you!
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Sorry didn't see this post until now. Most likely yes a bad panel some shorted chip on film or a bad capacitor on the panel will most likely cause this problem. Could be a losing game if you devested any money into it
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                I'm glad I didn't buy it then for sure!
                                • mauda
                                  Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                  by mauda
                                  I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                  Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                  05-21-2023, 11:56 PM
                                • Bob1394
                                  Vizio M65-C1 | Logo appears for 10 seconds then off
                                  by Bob1394
                                  I have used the search, and am stumped.
                                  My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                  I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                  https://www.badcaps.net/forum/showthread.php?t=81088
                                  https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                  Observations
                                  1) [Interaction] Power turned on via TV button (or remote)...
                                  02-08-2023, 01:03 PM
                                • Super360
                                  Vizio E701i-A3 Vizio logo flashing then turns off
                                  by Super360
                                  Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                  07-25-2024, 07:06 PM
                                • reassor
                                  Sony kd70xf8305 very very slow android logo with sound
                                  by reassor
                                  Hi.
                                  Power is ok
                                  Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                  Should i force update? If so how?
                                  I did reset.
                                  Mainboard Looks pristine.
                                  Very wierd.
                                  10-30-2023, 05:59 AM
                                • Ihandyrepair
                                  4 red flash led 65X950G boot Sony and android logo but then black
                                  by Ihandyrepair
                                  HI guys
                                  I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                  here is the issue
                                  I have Sony and android logo. but then 4 led red flash lights front of the tv
                                  I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                  but then I get black screen and 4 red flash light at the front LED
                                  but I get 3 led flash on the LED driver board.
                                  I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                  so I tried...
                                  07-11-2024, 01:45 AM
