sharp lc52d62u LCD TV no 12V coming out of PSU all other voltages ok
    Re: sharp lc52d62u LCD TV no 12V coming out of PSU all other voltages ok
    Also i thought 12V was the trigger to kick on the inverter boards not TCON but i could be wrong
    IC5702 is KIA 378R12PI
    other pinout on psu board connect small one is as follows
    PD cn5703
    PS_ON pin 1 2.91v
    AC_DET pin2 3,3v
    GND pin3 0V
    PNL_POW pin4 0V
    BU5V pin5 4.98v
    GND pin6 0v
    also on main board 4pin connector that goes to inverter to trigger on has no voltage, but i suspect this is due to Main board not racing 12V power on
      If you force the PSU on, are all power rails o.k.?
        do you mean by shorting PS_ON and AC_DET
          Or PS_ON to GND
            Originally posted by frankriz99 View Post
            Or PS_ON to GND
            That one.
              Jump ps_on to ground, then see if you have the expected voltages.
                https://www.youtube.com/watch?v=mUvclBfaMXg Video demonstrating procedure.
                  You don't have to remove the board tho, just disconnect all the other boards.
                    ok took whole new PSU out of tv and put it on the bench shorted PS_ON to ground.
                    PSU became active here are my voltage (note 12V still not there)
                    13.45v
                    13.45v
                    0V
                    0V
                    10.21v
                    10.21v
                    0v
                    0v
                    0v -should be 12V
                    0v - should be 12V
                    0V
                    5.99V
                      you always need put the pin out name with the voltages measured. Is there a BL_on?
                        CN5702
                        13.45v pin 12 AMP_13v
                        13.45v pin 11 AMP_13v
                        0V Pin 10 GND
                        0V Pin 9 GND
                        10.21v pin 8 10V
                        10.21v pin 7 10V
                        0v pin6 GND
                        0v pin5 GND
                        0v pin4 PNL 12V (-should be 12V)
                        0V pin3 PNL 12V (-should be 12V)
                        0V pin 2 GND
                        5.99V pin1 6V
                        CN5703
                        Pin1 PS_ON 2.91V
                        Pin 2 AC_DET 3.29V
                        Pin3 GND 0V
                        pin 4 PNL_POW 0V
                        pin 5 BU5V 4.98V
                        pin 6 GND 0V
                        also i notice on main board (not PSU) there are 2 solid RED led on, and one constantly flashing red led
                          Looks like it may be right, does not look like you activated bl_on, right? you just jumpered ps_on and ground if that's correct theory then it looks like the powersupply is ok.
                            http://www.shopjimmy.com/sharp-rdenc...pply-board.htm pic. of powersupply if that's it.
                              'pin 4 PNL_POW 0V' Main board is not sending the control signal to run on PNL12V which is supplied by the switched 12V LDO IC5702 KIA 378R12PI.
                                CN5702
                                0V Pin 10 GND
                                0V Pin 9 GND
                                10.21v pin 8 10V
                                10.21v pin 7 10V
                                0v pin6 GND
                                0v pin5 GND
                                0V pin 2 GND
                                5.99V pin1 6V
                                CN5703
                                Pin1 PS_ON 2.91V
                                Pin 2 AC_DET 3.29V
                                Pin3 GND 0V
                                pin 4 PNL_POW 0V
                                pin 5 BU5V 4.98V
                                pin 6 GND 0V
                                Are these Voltage you are showing are done with all the connectors back in place? Or it's done with PS-ON pin connected to GND which then doe not make sense since you still show PS-ON 2.91V. Please clarify.
                                It looks to me the PS-ON has to be high for the rest of the power supply to be turned on based on your Voltage readings.
                                  BTW, we still need to upload pictures of the whole backside of the TV showing all the boards, the other thread you made the Photobucket had blocked your pictures.
                                    is there anyway to assert the PNL_PWR to see if inverter will fire up.
                                      photobucket wont work without browser extension .
                                      try uploading here or a different place than photobucket
                                        here are pics attached again
                                          BTW, service manual has error codes on page 6-17, -18.
