Sharp LC52D62U Pwr Supply RDENCA184WJQZ
  • rviani
    • Dec 2022
    • 12
    Anyone know the correct output voltage of this board to the inverters? This board is used in many 42" to 62" Sharp Aquos (2005 - 2010 era) TVs. Also known as ZEBRALC605-4001CC.
    SOMEONE must have this data - help gratefully appreciated.
    Thanks in advance.
    Ron
  • nomoresonys
    • 12323
    • U.S.
    Re: Sharp LC52D62U Pwr Supply RDENCA184WJQZ
    this is the same tv as your other thread right, you don't need to create another thread, can you see why? because all the other progress or details about what has already been done is lost and it will just take longer to sort out, so just post in original thread, it will bump up to the front.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
      07-01-2024, 06:34 AM
    • timtrace
      Won't stay powered on - Sharp LC52LE700UN with RDENCA336WJQZ DPS-286AP power supply
      by timtrace
      Greetings - first post. I'm awed that a forum like this exists. It's a dream come true. I'm not even kidding.
      I've got a 13 year-old Sharp LC52LE700UN television that's developed a problem of powering itself off after 30-45 seconds. If I pull the mains cord and reconnect, it will come back on right away without so much as a button push...then turn off after 30-45 seconds.
      Service manual S37X3LC46E77U is attached to this post, as well as a front and a back picture of the RDENCA336WJQZ DPS-286AP power supply taken after completing my work.
      Each time that the...
      05-14-2020, 09:24 PM
