Sharp LV-60LE633U inverter output voltages
  • organman
    • Mar 2023
    • 12
    Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
  • organman
    • Mar 2023
    • 12
    Re: Sharp LV-60LE633U inverter output voltages
    I have posted a question and have not received a reply as yet. There has been several views. Have I posted incorrectly?
    • nomoresonys
      • 12284
      • U.S.
      Read the sticky by Budm 3rd one down from top, read it all, then post the pictures, clear straight on shots of each board and one of the whole back as to see how everything is connected, we can not see your tv from here, my gypsy crystal ball is busted.
      • nomoresonys
        • 12284
        • U.S.
        Ask nicely and maybe one of the backlight pros will help you test them, some boards have expected output voltages in a map/legend, not sure about yours, because you posted no picture.
        • organman
          • Mar 2023
          • 12
          Thanks will do.
          • organman
            Sharp LC-60LE633U Inverter output voltages
            by organman
            Thanks...
            03-22-2023, 06:47 PM
          • Joekhoe
            Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
            by Joekhoe
            Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
            I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
            The replacement as follows:
            1. IC7905 : TNY264PN (first found exploded)
            2. Q7915 : BT169D (exploded too)
            3. IC7901 : 1608B (controller ic)
            4. IC7601 :...
            09-17-2020, 05:52 AM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • gjgib
            Help reading schematic voltages input/output
            by gjgib
            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
            05-06-2024, 08:11 PM
          • scottsman76
            Samsung UA40D5000PR Pulsing output voltages
            by scottsman76
            Hi Guys
            I Have this Samsung smart tv that needs repair.
            with everything connected i get pulsing A5V at the PSU connector. if i unplug the main board then all voltages pulse on the output connector.
            I dont get any voltage on the LED connector.
            there is also an audible click around the mosfet marked below
            The connector to the Buttons all voltages pulse (3v)
            I have searched and found a similar problem but there was a stable 14v, but was also not repaired.
            I checked and replaced the mosfets with no effect.
            Any ideas where...
            03-30-2023, 10:33 AM
