I have a sharp lc52d62u lcd tv... TV click and tries to turn on( clicking) have steady green power light . checked all voltages on PSU and i noticed the 2 pins that should be providing 12V are providing 0.24V, any idea where the fault may be on PSU?
sharp lc52d62u LCD TV no 12V coming out of PSU all other voltages ok
Tags: None
Re: sharp lc52d62u LCD TV no 12V coming out of PSU all other voltages ok
We need hi-res pictures of the whole board, it must be good enough to see the traces on the bottom side of the board and clear enough to read the texts on the top side of the board.
Right now I cannot even read the board P/N to do the research on it.
Is this the exact matched to your board?
http://www.shopjimmy.com/sharp-rdenc...pply-board.htm
Sharp RDENCA184WJQZ (LC605-4001CC) Power Supply Board
We also need the pictures of the whole back side of the TV showing all the boards so we can see how they are connected together.Last edited by budm; 03-22-2018, 09:57 PM.Never stop learning
try this again
https://pixady.com/file/directDownlo...FiuozjvDOtEMvm
https://pixady.com/file/directDownlo...g1XZgEgJOptQyjComment
on a hunch i replaced the whole PSU we a new one from shopjimmy
part# 184wjqz
i have all my voltages now except pin3 and pin4 that give me 0.24V and should be 12V
I hear tv clicking and trying to turn on now, but no pic or sound.
any idea why i am not getting the 12V out of the new PSU now on Pin3 and 4Comment
no change, still get 0.24v on pin 3 & 4, for some reason 12V is not being turned on.Comment
Service manual:
http://elektrotanya.com/?q=showresul...oria=&kat2=allNever stop learning
BTW, you have 3 connectors on the cold side and I do not see any pin label to tell us what each pin is for, so pin 3 and pin 4 of which connector?Never stop learning
2nd connector from the top left (PH)
3&4 pin on that connector starting from to bottom of connectorComment
did you remove load from 12v supply ? maybe short killed first board .Comment
what does the 12V drive? where would i remove the load for 12V, another observation is on the main board there is a red LED that is flashing constantlyComment
Do you have the pin names for that PH connector? Where does that PH connector go to?
The 12V may be a switched on non-switched 12V.
Most 12V is used for T-CON and audio amplifier.
Please show us the pictures of the whole backside of the TV showing all the boards.Never stop learning
INever stop learning
It is not helping having two threads for the same TV.
https://www.badcaps.net/forum/showth...262#post814262
Stick with with one thread.Never stop learning
PH
Pin1 6v OK
pin2 GND OK
pin3 PNL12v 0.24V
pin4 PNL 12v 0.24V
pin 5,6 GND OK
pin7 10V OK
pin 8 10v OK
pin 9,10 GND OK
Pin11 AMP13V OK
pin 12 AMP13V OKComment
Pin 3 and Pin 4 look to be switched 12V for the T-CON board.
There must be other pins on that power supply board's connectors that is for the control signal to turn on the PNL 12V switcher.
Do you have other connector pin names? Please list them since I do not see them printed on the board, that will make troubleshooting easier. The more details you provide the better help you will get.
What is the P/N of IC5702?
My post #4 with the link to SJ, is that the same exact board you have?Last edited by budm; 03-23-2018, 09:03 PM.Never stop learning
I was reviewing the service manual schematic provided in a previous post in this thread
it shows all the connectors
p10-48 it looks like its looking for the 12V pON signal to come from the main board?Comment
by CapacitorialHello guys,
I have a Philips 240B7QPJEB. The monitor seems completely dead.
I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
The weird thing is, that the Power LED is powered over the TCON board.
On The TCON...-
12-28-2024, 02:12 PM -
by organmanGreetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
Thanks... -
Thanks -
by rvianiAnyone know the correct output voltage of this board to the inverters? This board is used in many 42" to 62" Sharp Aquos (2005 - 2010 era) TVs. Also known as ZEBRALC605-4001CC.
SOMEONE must have this data - help gratefully appreciated.
Thanks in advance.
Ron -
by JoekhoeHello all, I'm Joekhoe, a newbie here
and ask your masters permissions and solutions for the problem i'm facing at the present.
I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
The replacement as follows:
1. IC7905 : TNY264PN (first found exploded)
2. Q7915 : BT169D (exploded too)
3. IC7901 : 1608B (controller ic)
4. IC7601 :... - Loading...
