RCA remote control not working
  • cheech3629
    • Sep 2016
    • 32
    I was given an RCA RLDED5098 , a couple of LED`s had failed.I replaced them and the set works fine. However--i wasnt given the remote control for it---i have tried ten different RCA remotes and two new universal remotes with no luck.
    How can i know for sure it is the IR receiver that isnt working?
  • nomoresonys
    • 12331
    • U.S.
    Re: RCA remote control not working
    Turn off the television. Plug speakers or a set of headphones into the television set and turn on the TV again. With the TV on, remove the headphones or speakers since this will reset the IR receiver. On many televisions, the IR receiver is automatically turned off when there are headphones plugged in. If that works you can probably skip the rest.
    Clean the IR receiver using a lint-free cloth damp with distilled alcohol. Alternatively, you can use specialized screen wipes used for cleaning flat-screen monitors. The IR receiver will be located somewhere on the front of the TV set. If you can't find it, refer to the instructions. You should find a diagram explaining where everything is located.
    Turn off and unplug the television and remove the grill or front-panel from the front of the TV. Carefully remove the IR receiver from the television. It should be plugged into a port in the main circuit board of the TV. If it is soldered into the circuit board, do not try to remove it. Using the cloth and distilled alcohol, gently clean the connections between the IR receiver and the TV. Plug it back in and put back the front panel of the TV.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      look at the IR receiver with an oscilloscope while pressing a button on a remote control. I am guessing that you just don't have the right code for the TV. There are tons of threads with RCA's not working with these el cheepo universal remotes.
      • R_J
        • Jun 2012
        • 9624
        If the universal remote has a code discovery mode, try using that to see if you get a response from the tv, Its possible the only thing RCA is the name tag
          Can we at least see the pictures of the IR board?
          • nomoresonys
            • 12331
            • U.S.
            https://www.ebay.com/itm/RCA-Control...YAAOSwe~Nal3IH
            one there for 12 bucks free shipping, says something about make sure the numbers match in the ad.
            • cheech3629
              • Sep 2016
              • 32
              i had another rca so i took the IR receiver from there and soldered it onto my tv, set two universal remotes to code search and neither one shut off the tv.it was only 9 dollars for the remote for that exact TV so ill wait for it to show up. I dont have an oscilliscope
              • nomoresonys
                • 12331
                • U.S.
                Usually the IR sensor on the IR board go bad, pretty easy to replace, check you tube there's a lot of videos on it.
                  You can see if the IR receiver has activity or not by using DC V meter to check the signal out put of the IR receiver, it should fluctuate when ANY remote controller is sending the IR beam to the IR receiver.
                  • wolf1976
                    wireless receiver for 6 speeds fan control with remote control
                    by wolf1976
                    hi i have a receiver that is destroyed from the overvoltage i guess
                    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                    the motor fan has not label
                    i have an other receiver operational
                    In your opinion can i measure the voltage at the output ?
                    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                    thanks in advance...
                    07-23-2025, 03:12 PM
                  • CdDvdFlash
                    DSE GE6878 possible TV receiver dying remote not working well
                    by CdDvdFlash
                    For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                    07-03-2024, 03:55 AM
                  • piipo
                    Old Privileg 5.1 speakers remote control question
                    by piipo
                    Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                    09-18-2024, 01:55 AM
                  • hemant_2222
                    Schematic for Denon Remote Control RC1156
                    by hemant_2222
                    Hello Everyone,
                    Hope everyone is enjoying their repairs at hand!.
                    I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                    I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                    Please refer to the attached picture, i think the voltage divider is missing...
                    10-06-2023, 02:05 AM
                  • dfear
                    hitachi 75hl16t64u - not responding to remote control
                    by dfear
                    I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                    It came in for a power issue which I have finally resolved by replacing the power supply.
                    The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                    Anyone have a clue how to fix TV?
                    FYI: I have checked the remote work s by pointing it at my camera on my phone....
                    09-02-2024, 12:15 PM
