DSE GE6878 possible TV receiver dying remote not working well
  • CdDvdFlash
    • Jan 2020
    • 35
    For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy a receiver board, I havnt taken the TV apart yet to inspect if the receiver board has a dry solder joint or dying capacitor. Thank you.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8289
    Stick an oscilloscope on the IR receiver on the TV and verify the range of the remote. I’ve seen instances of this from bad batteries in the remote (even they still measured 1.5V each, but couldn’t handle the current draw from thee remote) to bad capacitor on the IR board and over to dirt on the IR.
    • jesterace
      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
      by jesterace
      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
      Tried installing latest firmware but no change.
      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
      10-26-2022, 02:20 AM
    • wolf1976
      wireless receiver for 6 speeds fan control with remote control
      by wolf1976
      hi i have a receiver that is destroyed from the overvoltage i guess
      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
      the motor fan has not label
      i have an other receiver operational
      In your opinion can i measure the voltage at the output ?
      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
      thanks in advance...
      07-23-2025, 03:12 PM
    • cstout
      DeLonghi AC Remote only accepts 3V
      by cstout
      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
      I can't find any schematics...
      06-03-2024, 03:53 PM
    • edugimeno
      HiSense 55A7500F won't obbey to remote after power on
      by edugimeno
      Hi! I have this TV set that does the following:
      1) I press the red power button on the remote
      2) The TV turns on normally
      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
      Then after it's off, it would again accept the TURN ON from the remote and same again
      BUT:
      -The remote does show the correct IR beam while observed thru a phone camera
      -The TV works fine while using the MiRemote...
      03-14-2023, 11:22 AM
    • rustinjust
      Please help, where can I get a remote for my subwoofer?
      by rustinjust
      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
      Is there...
      10-28-2023, 03:43 AM
