ESTAR LEDTV40D2T2 Firmware
  • antas
    • Jul 2014
    • 148
    • Ireland
    Any chance to get a firmware for E-Star LED TV 40D2T2. SR.NO.: VIT02C40480583 ?
    I have here strange problem. Looks like the BACK button is pushed and is on hold. When you get to the MENU, all thinks goes back. Volume shows 0 because of operating back button somewhere... Thinking about to refresh the firmware to factory condition. Thank you, guys, in advance.
  • maxvalutech
    • 804
    • australia
    Re: ESTAR LEDTV40D2T2 Firmware
    Don't know the set so does it have buttons on it for operation if so is one stuck mainly CH or Vol.
    • antas
      • Jul 2014
      • 148
      • Ireland
      Yes, it has operating buttons on the side of the TV. But even I disconnected, this board with buttons, from the mainboard-no changes at all. Looks like one of the buttons is stuck. But how and where, because all buttons are disconnected from the mainboard. And remote control, at this moment, still without the batteries in it.
      • antas
        • Jul 2014
        • 148
        • Ireland
        Reinstalling the Firmware could help or not? Any help, guys, please?
        • antas
          • Jul 2014
          • 148
          • Ireland
          Any help, guys?Any Firmware or bin file, please?
            • 12144
            • U.S.
            https://www.estar.eu/products/tvs/estar-ledtv32d1t1
            Probably best shot would be call or email, see if they have firmware available.
            • diif
              • Feb 2014
              • 6978
              • England
              You might have some luck searching for tp.ms3463s.pb801. That board is in a few TVs.
              • antas
                • Jul 2014
                • 148
                • Ireland
                Thank you, nomoresonys for the answer. I will try to e-mail them too.
                Thank you, diif. I have downloaded a few bins, but they are from different models (for 32 inch TVs) Would those bin files suit for my model?
                  • 12144
                  • U.S.
                  If the screen size is the only difference it MIGHT work, I'd ask in the email or call.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Back up your old one first and give them a try. Even if they are wrong you should at least be able to test your theory of it being a firmware issue and not something like a faulty IR sensor causing your problem.
                    You can then write your old bin back. Your problem could be a faulty EEPROM maybe.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      maybe try freezing/heating the eeprom it may get it working long enough to carry out a factory reset
                      • antas
                        • Jul 2014
                        • 148
                        • Ireland
                        I have sent a few emails and have all the negative answers-they cannot provide a Firmware. They just offering repair services... I got the same letters from 3 places...
                        The chip itself can be faulty? Not just a Firmware inside of the chip? If so, can I replace it with the same coded chip from donor board?
                        Will check IR sensor too, but the issue goes on, even when IR is disconnected from Mainboard...
                        maybe try freezing/heating the EEPROM it may get it working long enough to carry out a factory reset
                        Thank you. I'll try it.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Yes, they can become faulty, they have a maximum number of read/write cycles.
                          I had one on a similar board although mine was stuck in a boot loop.
                          As long as it's for the same sized screen it should just swap over, the code inside has to be the same.
                          • antas
                            • Jul 2014
                            • 148
                            • Ireland
                            Do you mean the numbers on the chip (25Q64CSIG) or the Firmware code (BIN) inside of the chip?
                            • antas
                              • Jul 2014
                              • 148
                              • Ireland
                              I tried to erase the chip on the programer-it's not erasing the chip. You can read the chip, you can save (I have saved it now), but not erasing at all. Is that means the chip itself is broken?
                                • 12144
                                • U.S.
                                "I have sent a few emails and have all the negative answers-they cannot provide a Firmware. They just offering repair services... I got the same letters from 3 places..."
                                Yes, can be a pain, better to get a very popular brand tv, that way if the companies website don't have it, you might be able to find it online much easier, I know it's sold in Europe because you have one but I never heard of Estar before now.
                                  • 12144
                                  • U.S.
                                  So the freezing or heating did nothing?
                                  • antas
                                    • Jul 2014
                                    • 148
                                    • Ireland
                                    The chip is on the programmer now. Can't check the difference. It should be heated enough because I took it with the airgun from the mainboard.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      The 25Q64CSIG indicates the size of this common chip.
                                      The firmware (bin) is what is read, so needs to be the same.
                                      Not being able to erase the chip suggests it could be faulty.
                                      • antas
                                        • Jul 2014
                                        • 148
                                        • Ireland
                                        Thank you, diif. So I need to get a 25Q64FVSIG chip from somewhere because it can't be erased (I trying and trying on the programmer, but without the luck). Those letters (FVSIG) are very important or the chip can be without those letters at the end? Just 25Q64? Or has to be 100% the same (GD25Q64FVSIG)?
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • gurj1979
                                          Ubiquiti firmware help. US-8-150W POE
                                          by gurj1979
                                          Hi guys.
                                          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                          Got New chip and writes good.
                                          THE PROBLEM...
                                          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                          Does anyone have a Good Firmware I can have?...
                                          07-22-2024, 05:13 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
