Panasonic TC-60PS34 Dead As The Proverbial Doornail...
  • Michale32086
    • Nov 2011
    • 1453
    Re: Panasonic TC-60PS34 Dead As The Proverbial Doornail...
    Dead as the proverbial doornail..
    • freakaftr8
      • Oct 2012
      • 3743
      These. Any of the four
      • Michale32086
        • Nov 2011
        • 1453
        Ditto...
        • Michale32086
          • Nov 2011
          • 1453
          Got it..
          One sec...
          • Michale32086
            • Nov 2011
            • 1453
            And more of the same..
            • freakaftr8
              • Oct 2012
              • 3743
              Ok it appears the PFC circuit is dead. Is there 120v coming from the separate board below it at.connector P52?
              • Michale32086
                • Nov 2011
                • 1453
                Well, THIS is interesting...
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  maybe test all four and see what readings you get
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Putting the probes thusly, I got 0v
                    I'll check the other caps...
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Looks like it's only the bottom one that is giving me voltage..
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        whats the psu part number maybe we can locate a schematic
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Here is the board..
                          So many numbers..
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            When you check for 120 V you were on AC for that check correct? I mean obviously are getting voltage or you wouldn't have DCV against that 1 cap. I would say half the board is working but you mentioned you have 5 V DC on pin 6 which makes me think that the rest of the board comes live after main board acknowleges signal in causes PS on to go high.
                            It may be a main board problem I would try playing some heat around the board to see if it is a BGA problem to start
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Not the first time. But I just redid it under AC and it's still 0v...
                              I was beginning to wonder about the Main Board.. I have seen instances where there was no power around and it was the Main Board that was the culprit.
                              Lemme check that..
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                You have no 120v AC in at P52?
                                Edit: Scratch that p56 is where you should have your 120v P52 is switched by mainboard PS-on.
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  OK, officially weird....
                                  I did a "reflow" on the Main Board.. It's often more of a hail mary, but it has gotten good results..
                                  It's also great for heating up pizza and last night's chicken..
                                  So, I did a reflow on the board..
                                  hooked it back up to the TV, and hit the switch on the power strip...
                                  SUM BEACH!!! I got relay clicks!!!
                                  So, I shut it down, pulled off the volt meter and hit the power strip switch again.. Was rewarded with a couple relay clicks..
                                  Used the remote to turn on the TV and VIOLA!!! We have power...
                                  Display came up.... Then I heard a click and it died..
                                  Now it's back to what it was.. Dead as a doornail..
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    There you go! somethijng on that board likes heat. I would take a heating gun with a pencil tip and go around areas to find out where the problem lies
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Thanx... I'll have to pick it up in the morning..
                                      I'll follow up the results..
                                      Thanx to all for all the help...
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Aww right.. Final (hopefully) disposition on this..
                                        I bought another Main Video Board.. Unfortunately, it wasn't the exact same model, but the TV did come on, albeit with a wanky screen display.. But it DID turn on, so it confirmed that the Main Video Board was the problem..
                                        I did a hail mary reflow on the original video board and I'll be deep'ed in sheet, it worked!!
                                        I even found a matching stand for it!!
                                        So, all in all, a good outcome..
                                        Thanx to all for all the assist and replies..
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          Nice! Great job!
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                            11-24-2024, 11:27 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • Super360
                                            Panasonic TC-P50G10 DEAD
                                            by Super360
                                            Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                                            12-27-2021, 11:40 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
