panasonic TC-L58E60 has scrolling picture
  • nwcs
    • Dec 2015
    • 311
    • usa
    I am not sure if I am dealing with a bad panel or tcon or even main board. I replaced one led strip in this tv and the picture came up no problem while on it's back. I put it back together and now I have a scrolling picture but if I bring up the menu that is fine. If I remove the left tcon cable to the screen the scrolling is gone. This makes me think it is either a bad tcon or panel. This all seemed to happen after I plugged in a HDMI cable. I would appreciate any help or suggestions.
  • budwich
    • Jul 2015
    • 3097
    Re: panasonic TC-L58E60 has scrolling picture
    do the same "tcon cable removed" test where you get a good picture. Feed in a known video test pattern (color bars is good) and look for details. Do the same with the opposite cable.... go from there.
    further, put your glasses on and carefully check the tcon to panel cables to ensure that the contacts are all good and are seated properly... :-)
    • nwcs
      • Dec 2015
      • 311
      • usa
      I will do that and get back to you, thanks.
      • nwcs
        • Dec 2015
        • 311
        • usa
        Did what you suggested and even swapped the tcon cables to the panel and still same issue. I had not seen the tv working fine prior to putting the tv on its face to put the plastic parts and the stand on I would suspect a bad panel. I am half tempted to get a tcon to see if that fixes it.
        • nwcs
          • Dec 2015
          • 311
          • usa
          A update that might help a little. I had a tcon here and the cable to the panel so I put them in and same problem. I lifted the clip on the bottom flat cable to the main board that goes to the tcon and if i flex it I now get horizontal lines in the picture as well as rolling which is I guess normal.
          • MagicSmoke
            • Feb 2011
            • 275
            Does the OSD and or menu scroll also or just the actual picture being displayed?
            Looking at first pic it seems like the time/date bar is ok but picture is scrolling, if that's the case I would be inclined to suspect the mainboard or corrupt eeprom maybe.
            One other thing needs noted about plugging in HDMI cables or devices to the TV while either is powered on. This is a big no no, every manual I have read states to turn off both TV and device being connected. I don't think most people think about this when connecting things to the TV.
            • budwich
              • Jul 2015
              • 3097
              ok... but you didn't really follow up with what I asked. test both sides doing a test with some sort of input / display that people know exactly about so we can determine if we see any "hints" of issues with perhaps the panel or otherwise. Anyways, as others have posted, the internal stuff looks find. Your observation about removing one tcon cable and the display is "fine" is probably misleading as what you were inputting had no display information on the other side of the screen.
              • nwcs
                • Dec 2015
                • 311
                • usa
                Sorry budwich I did do what you suggested just not take pictures of it so tomorrow I will do it again and post the pictures. The OSD and the meu does not scroll and I am inclined to think the same about the main board.
                • nwcs
                  • Dec 2015
                  • 311
                  • usa
                  Well we had a little snow so none of my employees can make it in to help me put the tv up so I can post the pictures. I will do it tomorrow as long as it does not snow again. Darn lowered cars
                    • 12074
                    • U.S.
                    I don't have to go to work if it snows a little? now that's a dream job
                    • nwcs
                      • Dec 2015
                      • 311
                      • usa
                      Yea, one guy has a really steep dirt driveway and the other guy cant get snow plows out to his area and drives a sports car. I drive a 4 wheel drive FJ so I have no problem.
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        Here are the pictures with the flat cables removed first one is the left side and second one is right side and the third one is left again. looks like the right side is darker than the left. And a little snow is 6" or so. We just do not get much snow here.
                        • budwich
                          • Jul 2015
                          • 3097
                          doesn't look good for the right side of things. Not sure of how the panasonic panel is setup for this model / size. are there edge boards on both sides? neither side / just tabs? IF there are side edge boards, there might be an interconnecting clampable ribbon cable going from the bottom edge board to the side. IF so, you can try unclamping / disconnecting it and see what the result is.... you might get lucky.
                          • nwcs
                            • Dec 2015
                            • 311
                            • usa
                            Just tabs.
                              Bad panel: Gate tab bond failure.
                              https://www.badcaps.net/forum/showth...ht=tab+bonding
                              • nwcs
                                • Dec 2015
                                • 311
                                • usa
                                Darn, Well I have nothing to loose so I will pull the panel out again and hope it fixes it but at any rate I can get the led strips out.
                                • Fly_Among_Stars
                                  VIZIO E70-E3 Half picture with half TCON
                                  by Fly_Among_Stars
                                  I have a VIZIO E70-E3.
                                  Symptoms: Black screen, no picture, but LED backlights are working.
                                  I probed the power board and voltages are as listed on the board.
                                  Main board appears fine, too.
                                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                  There are two separate ribbon cables feeding the LCD.
                                  If both are connected, the screen is black.
                                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                  04-24-2023, 08:20 PM
                                • FZG
                                  Panasonic AG-1000B VHS player with bad picture quality
                                  by FZG
                                  Hello!
                                  I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                  Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                  I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                  Also, what mechanism is this?
                                  Any feedback is appreciated!...
                                  05-06-2024, 07:16 AM
                                • Bazfletch3
                                  Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                  by Bazfletch3
                                  Hi all
                                  While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                  I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                  From there I envisaged that the backlighting wasn't working, however...
                                  01-08-2024, 10:18 PM
                                • shelby5041
                                  Samsung LCD TV no picture backlight on no 12v at tcon
                                  by shelby5041
                                  hi
                                  i have a samsung lcd tv
                                  it powers on with sound and backlight but no picture
                                  all voltages from PS are good 12v 3.3v and 5v
                                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                  no 12v at the tcon fuse
                                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                  the odds of having 2...
                                  10-08-2021, 08:21 AM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
