Panasonic TC-P55ST30 Interpreting SU-SD tests
  • FastEddie52
    • 18
    Re: Panasonic TC-P55ST30 Interpreting SU-SD tests
    I thought that might be a problem but since they had the same suffix, I thought it would work. The P50ST30 has a AC version of the board according to various sources. The P55ST30 does use the AD version. How the AD got in the P50 is a mystery to me. How does the manufacturer keep these straight if they are not interchangeable between models?
      The 50" and 55" panels are different. The A board controls the plasma discharge; with the wrong board, problems could happen, such as maldischarge (misfiring pixels) or SC/SS failure. I can't be sure if your 14 blink symptom is caused by it, though.
      • FastEddie52
        • 18
        This is actually the "Solid Red LED Failure (Locked Mode) that was was implemented for the 2011 model. Attached is the troubleshooting flowchart. So you disconnect SC2, SS11, and SC20. Is the led blinking? Yes then is it blinking any other number times beside 6? Yes (8). Then Replace A boardand check Vsus and P15v for short circuit. (The flowchart is attached) This is what led me to replace the A board in the first place. I am going to get another one since nothing else shows up as a fault.
        • FastEddie52
          • 18
          I bought a new main board for the TV and installed today. Nothing has changed, so I am at a loss for what is wrong
          • budwich
            • Jul 2015
            • 3097
            Based on my limited experience with a 50s30, how about trying just an sc2 disconnect with everything else connected.... what is the result? I guess the question is... are you counting your "toes" correctly? :-)
            • FastEddie52
              • 18
              With SC2 disconnected, I get 7 blink error
              • budwich
                • Jul 2015
                • 3097
                OK... the other guidance that I got was then to check each of the fets and diodes on the board using the black lead on the large contact ("top") and measuring resistance at each of the other legs? do this for all and compare your results? Anything stand out?
                • FastEddie52
                  • 18
                  are you talking about the heat sink or the middle leg? Use diode or ohms setting?
                    With the surface-mounted transistors
                    https://www.google.co.uk/search?q=to-263&tbm=isch
                    (TO-263 type)
                    and the smaller "DPAK" type, the tab pin is connected to the middle pin, so you can use either.
                    • pascalo
                      • May 2014
                      • canada
                      #30
                      For check the su and sd board there is a video for if you are more visual
                      https://www.youtube.com/watch?v=-JVLWpcIxJQ&t=16s
                      • FastEddie52
                        • 18
                        Update on my TV. I sent the SC Board out to be repaired, but the repair shop could not find the problem. So I bought a used SC board and that fixed the TV. I bought 2 A (main) boards thinking that was the issue. I guess I will resell them on ebay. Thanks for for all your help.
                        • boydsc
                          • Jul 2018
                          • 10
                          • US
                          #32
                          Does anyone happen to know what kind of resistance reading I should have across the SC2 plug on the SU board ?
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #33
                            Put your meter in continuity mode.
                            Black prope on ground ( screw hole ) and slide the red prope against the ribbon connectors...beep is bad. Best way to test.
                            • boydsc
                              • Jul 2018
                              • 10
                              • US
                              #34
                              ok when done that way I get 4 to 5 beeps along the ribbon connector. I was told that measuring across the SC2 connector which is the power connector for that board I should not get a beep or there is a dead short somewhere on that board. which I did get a beep. I removed Q401 and Q402 from the board and the short went away. I think those are transistors. Could these be my only problem on this board ? I've never heard the ribbon check tho.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                #35
                                It is best to start your own thread with pictures of the boards. There must be more short on the board beside those 2.
                                https://www.youtube.com/watch?v=51SZsfH60EY
                                • BigPete
                                  Panasonic Heatpump Dryer Repair
                                  by BigPete
                                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                  Unfortunately the whole machine has to come apart to fix it.
                                  I have...
                                  11-01-2025, 06:40 PM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                  11-20-2024, 08:52 PM
                                • AquaMan Ua
                                  by AquaMan Ua
                                  05-17-2025, 09:40 AM
                                • stecos
                                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                  by stecos
                                  Hi everyone!
                                  For my passion for technology I'm now collecting several...
                                  11-28-2022, 11:39 AM
                                • aa10aa10
                                  Panasonic Toughbook CF-33 mk1 BIOS repair
                                  by aa10aa10
                                  Good day,
                                  I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                  I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                  01-21-2025, 06:13 AM
