Sharp LC-60LE600U Won't turn on
+ More Options
Posts
  • theojt
    • Jun 2017
    • 48
    Original Owner said they used it about 25-30 times and then it just wouldn't turn on anymore, no other information.
    When I plug it in, the chevron LED will come on for a few seconds and then go out. I do see a very brief flash of the backlights.
    I have 5V BU (see all voltages below) on Pin 15 and I have 2.2V AC_DET on Pin 13. Everything else on the Power Supply "PD" 24-pin connector reads zero or very close to it.
    If I disconnect the LED connector from the Power Supply (top edge of PS board) and perform a Reset, then I see all voltages for connector PD as recorded below (and I noted that AC_DET was slightly higher than it was before). These voltages are present for about 20 seconds, then the chevron LED begins a steady 1 second blink and the power supply shuts down. If I attempt a Reset with the LED leads connected, nothing happens. I have not observed any blink codes other than the steady 1 second blinking chevron.
    I attempted to read the resistance of the LED strips but my DVM probes are too big to get into the small pockets on the connector, I'll address that tomorrow.
    I'm thinking the Power Supply is probably good since I see all the required voltages before it shuts down (and I didn't find any diodes that were bad and all the electrolytic caps also read good with an ESR meter).
    With LED connector removed, before the PS shuts down, I read the following on the PD connector (on the right-hand edge of the PS board)
    Pin 1 PNL12V = 12.1V
    Pin 2 PNL12V = 12.1V
    Pin 3 SGND
    Pin 4 SGND
    Pin 5 UR13.2V = 13.2V
    Pin 6 UR13.2V = 13.2V
    Pin 7
    Pin 8
    Pin 9 SGND
    Pin 10 SGND
    Pin 11 SGND
    Pin 12 SGND
    Pin 13 AC_DET = 3.3V
    Pin 14 PS_ON = 2.1V
    Pin 15 BU5V = 5.0V
    Pin 16 PNL_POW = 3.3V
    Pin 17 PWM1 = 3.2V
    Pin 18
    Pin 19 DIMMER = 0.0V
    Pin 20
    Pin 21
    Pin 22 ERROR = 3.2V
    Pin 23
    Pin 24 STB = 3.2V
    Looking for concurrence that the PS is good, and any advice on what/how to check next.
    TIA!
    Re: Sharp LC-60LE600U Won't turn on
    Where are the Voltages reading for pin 21 OFL (bl-on), pin 23 PWM2?
    • budwich
      • Jul 2015
      • 3097
      as a "quick test", you might consider unplugging one of the tcon to panel cables, with power off (with everything else plugged in) and power up and see what happens... display? response? Do the same with the other side cable? any difference? Depending on the outcome, might save you a lot of time.
      • theojt
        • Jun 2017
        • 48
        budm: Sorry, I should have mentioned - those pins are not present on my board (see photo of connector).
        budwich - I started with one side, noticed no change; will do the other today.
        • maxvalutech
          • 804
          • australia
          I think I would try to force the backlights on with main disconnected. This would probably require force PS on first. What does budm think about the voltage on pin for PNL on (panel backlights ? ) and Dimmer ?
            OK, I just look through my notes: STB = BL-ON, the 'OFL' pin is not BL-ON.
            So from the look of it you do have all the correct command Voltages but I still need to look for my notes on the pin 22 ERROR pin to see if HIGH = NORMAL or HIGH = bad.
            • theojt
              • Jun 2017
              • 48
              I think I found your reference (budm) at https://www.badcaps.net/forum/showth...t=59988&page=2
              Check your post #24.
              My problem, is that they all go away after a few seconds. I'll collect resistance readings on the LED connector tomorrow. I also found the Service Manual (attached).
                So all the Voltages are normal.
                • theojt
                  • Jun 2017
                  • 48
                  Yep, for a brief period of time when the backlights aren't connected and a Reset has been performed.
                  • theojt
                    • Jun 2017
                    • 48
                    I measured the resistance with the LED connector (top edge of PS) plugged in as well as the peak voltage before the PS shutdown. Below are the readings:
                    Resistance
                    Pin 1 = 97.4K
                    Pin 3 = OL
                    Pin 5 = 97.5K
                    Pin 7 = OL
                    Pin 9 = 67.4K
                    Pin 11 = OL
                    Pin 13 = 66.6K
                    Pin 15 = OL
                    Pin 2,4,6,8,10,12,14 = NC
                    Peak Voltage (Note: Each pins voltage dropped to less than 1v very quickly after plugging in the TV)
                    Pin 1 = 85V
                    Pin 3 =
                    Pin 5 = 85V
                    Pin 7 =
                    Pin 9 = 77V
                    Pin 11 =
                    Pin 13 = 85V
                    Pin 15 =
                    So it looks like it may be bad LED(s) on the strip connected to Pin 9.
                    More observations:
                    If I disconnect the left panel connector from the TCON (see pic attached) and the LED connector is unplugged, the TV stays energized (I waited several minutes and then shut it off). Pin22 seems unstable this way though - I noticed it jumping between 1.8-2.4 but I'm guessing that it may be turning fully On & Off and I just don't see that. Disconnecting the right TCON connector didn't seem to have any effect. But if both are disconnected and the LED strips are connected, the Power Supply shuts down.
                    Also, if I plug in the LED connector and leave the left TCON panel connection off, then I see the right 1/2 of the screen light up (raster, no signal but bright and even) before the PS shuts down.
                    It appears I have a bad TCON board. I may also have a bad LED strip but I'm not sure. The resistance seems in line since I read somewhere that there are short and long strips in this TV (that would account for the 97K vs. 67K readings) but the 77V peak seems to be an anomaly. When both TCON connectors are plugged in, and I see the backlights flash on briefly, there is a dark area about 1/3 of the way in from the left edge. That could be nothing or it could be a bad LED/strip.
                    I guess I need to get a TCON and then see what that yields before tearing down the set to get to the LEDs (I want to avoid that).
                    Any other suggestions or tests anyone can suggest? Anything I overlooked before ordering a TCON board?
                    TIA.
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • ktmmotocross
                      Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                      by ktmmotocross
                      Acer 515-54G
                      DA0ZAWMB8G0
                      Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                      i dont uderstand this. Charger ic BQ24780S
                      ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                      What is pulling my ACDET down when i apply power even without BQ ic...
                      12-02-2022, 12:03 PM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
                    • gavenb
                      Sharp LC-80LE661U 80 inch
                      by gavenb
                      Hi folks!
                      I have a LC-80LE661U that had some interesting issues.
                      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                      11-12-2023, 02:05 PM
                    • SONY_E-WASTER
                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                      by SONY_E-WASTER
                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                      does...
                      12-26-2021, 05:46 PM
